Old 10-19-2011, 11:28 AM   #26
Dillon79scotts
Re: recommened fuel pressure
Originally Posted by usmcchevy View Post
If he has a 99-03 with the regulator built into the fuel rail he will get less press at idle. 04+ should have 58psi at all times.
its a 2000
Dillon79scotts is offline   Reply With Quote
Old 10-19-2011, 04:01 PM   #27
Street Smart
Street Smart's Avatar
If you look up a 2000 truck its 55-62psi key on engine off.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 10-19-2011, 04:10 PM   #28
Street Smart
If you can set the gauge up so you can see it while you drive that would be the best. It`s good to know what the pressure is when it feels the worst. If you know someone with a good scanner, or HP tuner maybe you can data log to see whats going on.
Old 10-20-2011, 12:24 AM   #29
Dillon79scotts
when the pump is priming, key on engine off it will hit about 55. then go to 50 and slowly fall off after hours of sitting.
i had my gauge up while driving. im seeing about 45 at idle, 53 54 at full throttle i believe.
another thing im noticing is my pump changing tone, even at idle then i look at my fuel filter before the pump, and my fuel is all sloshy looking (foamy and air raided) the pump gets louder almost like its sucking air. what might cause this?i was thinking it may be my fuel filter before the pump restricting? its a oreilys fuel filter made for carburated i think it is. a clear plastic with paper filter inside
any input on all of my questions would be great.
Old 10-22-2011, 12:39 AM   #30
Dillon79scotts
today i tried taking the filter off trying to cure those other issues stated above. made no difference. truck will still stall every few minutes, sometime it will pull itself back up and sometimes it will try but cant.
watched my fuel pressure gauge as this happened. didnt drop or gain anything.
got multiple videos to upload
best ive got is link to video didnt know how to make it show here
http://imageshack.us/clip/my-videos/694/s7iu.mp4/
(this one is a start up after it had died and i cycled the key to run the pump again. notice it was missing off start up, had to bump the throttle and it stopped.
http://imageshack.us/clip/my-videos/828/3fi.mp4/
(this time i had it running again, it stalled out and i didnt cycle the key, i just started cranking again)
last video is picture of my fuel pressure as its doing this
http://imageshack.us/clip/my-videos/27/ax0.mp4/
all input on this; thanks in advance
Old 10-22-2011, 12:26 PM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
either way, that carb filter is the wrong choice for the application...better off with the correct parts anyway.
As for the air sucking noise you mentioned; I scanned back through the thread but didn't see what your fuel pump setup was.
Any chance you have a loose fitting somehwere before/at the intake side of the fuel pump? When running the pump would create suction, so if you have a leak just before the pump it could possibly suck in air and foam up the gas. I'm on a limb since I think if there was a leak just before the pump, you would be able to notice it dripping when off...unless the leak were so small that the fuel evaporated before actually dripping down .
Kinda guessing at this point.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-22-2011, 12:36 PM   #32
Dillon79scotts
Not a single sign of a leak anywhere and that's what I would think with the fuel lines. The videos I hope would help
Old 10-23-2011, 11:38 PM   #33
Dillon79scotts
anything?
Old 10-24-2011, 07:03 AM   #34
Street Smart
Fuel press. seems alittle low but I think there`s more to it then that. Can you check sensor readings and see if there`s any codes. You should look for vacuum leaks too, unused ports that are open maybe?
Old 10-24-2011, 10:36 AM   #35
Dillon79scotts
sensors are all reading last time i checked. fuel trims are moving like they should. vacuum leaks i couldnt find any
Old 10-25-2011, 01:34 AM   #36
Dillon79scotts
is there any live data i should look at specifically? or any ideas
