Old 11-27-2011, 12:45 PM   #26
ProjectGMC84
Re: My 84 gmc swb project
got word the other day my 383 short block is ready, just gotta go pay the balance and pick it up. can't wait to get it together. also fought with the upper control arm bushings for an hour and a half but got all 4 air hammered out. also did a little more touch up with the blaster in the pumpkin to get the grit out of all the nooks and crannies.
ProjectGMC84 is offline   Reply With Quote
Old 11-27-2011, 12:56 PM   #27
SBTork
Garage wrench
SBTork's Avatar
cool project, it looks like you have a really good start so far, keep truckin' away
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-28-2011, 01:07 PM   #28
notyo_cheez
Cool Re: My 84 gmc swb project
Uhh, unless your new control arm bushings came with new outer sleeves (the poly ones don't AFAIK) you just shot yourself in the foot. Even the OEM MOOG bushings don't have the outer sleeves.
AutoZone has a bushing tool kit that presses out the old bushings and leaves the outer sleeves intact. It also presses in the new ones opposite of removal, and you'd have been done in less than half the time it took to hack them out with your air chisel...
notyo_cheez is offline   Reply With Quote
Old 12-14-2011, 10:25 PM   #29
ProjectGMC84
ok. sorry for delay. been busy with work and house renovations. found out my donor block wasn't able to be punched out so i had to buy another block.. picked up the (new to me) 383 short block. put the heads on. got chromo push rods. put the rockers on. found out all the intake valves had been ground down to far so the self aligning tabs were resting on the spring retainers. so back to the stock rockers for now... but did get my oil pan and center bolt adapters for perimeter bolt covers in. also ordered my dress up kit. will post those pics soon.
Old 12-14-2011, 10:36 PM   #30
ProjectGMC84
7 Qt. baffled with 1 door. valve cover adapters.
Old 12-19-2011, 12:25 PM   #31
made2drag
made2drag's Avatar
great job so far....and i love your tarp holders
made2drag is offline   Reply With Quote
Old 12-22-2011, 12:02 AM   #32
ProjectGMC84
haha thanks.. got quite a bit done on motor. more parts came in today - including a holley 750 cfm double pumper, harmonic balancer, 110 gph mech fuel pump etc.. but I'm at work of course, so i won't be able to get them on for a couple days. will up date asap. o also ordered a polished aluminum water pump with aluminum impeller.
Last edited by ProjectGMC84; 12-22-2011 at 12:07 AM. Reason: forgot to add h20 pump
Old 12-22-2011, 03:14 AM   #33
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Motor looks great!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-26-2011, 11:00 PM   #34
ProjectGMC84
Merry Belated Christmas y'all. Slapped some paint on the motor. my dog was checkin out the water pump lol. test fitting the air cleaner. gotta get a carb spacer bc the throttle linkage is not gonna clear.
Old 12-26-2011, 11:15 PM   #35
ProjectGMC84
o btw the carb i bought is a dual feed 750 cfm holley. single pump not double. got the water pump and balancer on.( forgot a timing tab. oops..) and my super wonderful gf bought me a blast cabinet for Christmas. it is gonna speed up the process a lot. She is awesome!!! will update again soon.
Old 01-09-2012, 12:41 PM   #36
ProjectGMC84
got the motor completed and running.. but i have a leak between block and head on passenger side. did get the cam broke in tho. oil is not milky... think the head is bad.. gonna order some aluminum ones soon i believe. ps the cats are on the empty side...
Old 01-10-2012, 02:13 AM   #37
Gordonr1973
Home Built '87
I love that engine test set-up you have going there!
That is something I could have really used a while back!
Motor looks amazing too btw.
Gordon
Old 01-10-2012, 11:03 AM   #38
ProjectGMC84
thank ya. ya the motor stand was a rust bucket i got from a guy who frequents the parts store i work at part time. 30 minutes had it wire wheeled, primed, painted and new gauges in it. makes things a lot easier.
Old 01-10-2012, 11:05 PM   #39
Boom
very cool project, I am not going to tear mine down very far just want to change a few things. but your truck gives me some motivation.
Boom is offline   Reply With Quote
Old 01-11-2012, 12:39 AM   #40
ProjectGMC84
thanks boom . if you have any questions message me.
Old 01-31-2012, 01:18 PM   #41
ProjectGMC84
well.. good news and bad. came across this truck for a number i couldn't refuse. 86 lwb. all new interior. wats not been installed aka door panels, vent window seals, etc i have in boxes. all billet trim. all new carpet, headliner, bench seat foam and upholstery. 4 in rear drop, 2.5 drop spindles ( no motor in now - makes truck sit a lil higher) 4.30 gears, detroit locker, b&m aluminum trans oil pan (for my 700r4), lokar shifter, new in box 3k stall converter, and more --- all for $1k. now the bad news, the 383 i built had a leak and turned out to be a bad head.... gonna save up and order aluminum heads....
Old 01-31-2012, 02:55 PM   #42
trout
killer deal on the truck whats the plans??? sucks bout the motor
Edited by staff
trout is offline   Reply With Quote
Old 01-31-2012, 03:55 PM   #43
ProjectGMC84
plans r gonna cut the frame. install fuel cell. put the shortbed from the 84 on the 86. for now, may decide to bag it but not sure about that yet, would like to get it driving first ... i agree bout the motor, but i guess thats part of this hobby..
Old 01-31-2012, 04:10 PM   #44
trout
that suck another long bed getting shortend
Edited by staff
Old 02-02-2012, 02:45 PM   #45
ProjectGMC84
well. nothing is set in stone... i may leave it as is and have a swb and lwb lol
Old 02-02-2012, 03:11 PM   #46
trout
i like the sound of that
Edited by staff
Old 02-02-2012, 03:26 PM   #47
ProjectGMC84
ya. it would be nice to be able to drive something instead of just staring at it on jack stands haha
Old 02-02-2012, 04:12 PM   #48
trout
yea lol
Edited by staff
Old 02-08-2012, 11:14 PM   #49
ProjectGMC84
Ok. Heads came in. Aluminum 2.02 1.60's. 3/8 screw in stud. raised guide plates. cnc'd combustion chambers. War hammer 1.5 roller rockers. fired it up and it sounds like a BEAST. also got a holley fuel regulator and picked up a set of cherry bomb extremes for $40. blasted and painted them - they look brand new. going to make another video fri and will upload. also removed dual tanks on the 86 and installed the fuel cell. hope to put motor in truck fri as well. fingers crossed!
Old 08-18-2014, 10:17 PM   #50
ProjectGMC84
UPDATE UPDATE UPDATE
hey everyone, im not dead. lol ive accumulated multiple things that had put this project on hold.. another c10, k10, k5 blazer. as well my wife... then our sweet baby girl. so coming soon -- ill be back into the game at a new house with some room for me to work.
stay tuned!!!!!!!!! haha
