10-14-2011, 01:44 AM | #26 |
Re: Jethro's fan belts
PanelDeland: You are the man! Thanks, brother.
10-14-2011, 01:58 PM | #27 |
I found something in the junkyard that'll do the trick. '79 Firebird. And that paint is actually black. Funny how the camera sees things sometimes.
10-14-2011, 05:38 PM | #28 |
RAT1968 '68 Cab/'71 Parts
Looks like it hung itself with Jethro's belt.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-14-2011, 09:50 PM | #29 |
I am a Referee of life.
Glad the little bit of info I had could help.Took me a while to figure it out for mine,so I figured I would give a heads up and maybe shorten you search.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-15-2011, 12:20 AM | #30 |
I got all the pulleys on and lined up today. Looks like it oughta work, but... man, does it ever look funky. I'll get a picture tomorrow once I get the 600 foot v-belts installed.
10-15-2011, 02:57 AM | #31 |
Back to your origonal question, the compressor fittings can be rotated to any position. As has been said, adjustable water neck will cure that problem.
My junk has a short water pump, Alan Grove brackets (slightly modified!) and single groove PS pulley (not pressed on yet). I went with a single and double on the crank. The guys at Grove's are really knowledgeable. Pic's to confuse.
1972 K2500 Long Box 400/350 |
10-15-2011, 10:14 AM | #32 |
Outstanding. Thank you, Mr. Hilly.
10-15-2011, 11:47 AM | #33 |
Okay. Now all I have to do is convince the parts guy to let me borrow 5 or 6 v-belts and tweak around until I get the best fit. Uncle Jed says I should just leave it run on the rope.
10-15-2011, 04:32 PM | #34 |
Take the rope and put it around the pulleys.Stretch it to the size you need.(Just big enough to go on at shortest adjustment.Then mark the rope.Go to parts store and get that length of belt.Instal.Bleed air from PS.enjoy.
10-16-2011, 08:28 PM | #35 |
Getting closer. Still have some wiring left to do, and the top radiator hose.
