01-28-2012, 09:00 PM | #26 |
Newbee
Re: IR 5HP air compressor pump knocking.
The knock may have been the crud piled on top. If there is no slop in the rod or wrist pin, hone it, new rings, lap the head, new valves, and run it.
01-29-2012, 10:42 PM | #27 |
1. If the wrist pin is good on that LP piston RUN it.
2. I have never heard sheaves knock in any way. 3. If I had to guess that machine has been running car motor oil. Just a guess though. That crud looks to be carbon from mineral oil to me. Last edited by RanchFlyer; 01-29-2012 at 10:47 PM. Reason: addition |
01-30-2012, 02:39 AM | #28 | |
Tripple Five Fanatic
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
02-08-2012, 11:20 AM | #29 |
Any updates? I have been watching this cause I just picked up single stage 80 gallon with no motor. I guess the emersons were junk motors. Not to hijack, but could you post a picture of the spec plate on the motor? Or just let me know the model number, rpm, amps, base type ect... Thanks Alot
02-08-2012, 01:07 PM | #30 |
L&l what brand is the tank? Do you have a picture of it maybe we can help ya
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-08-2012, 05:16 PM | #31 | |
Tri5
02-08-2012, 05:50 PM | #32 |
Yes its a ingersoll rand 80 gallon single stage 135 psi. Model number SS5N5. My pump only operates at 1000 rpm where Tri5's dual stage operates at 1600 rpm. That should only be a difference in pullys, most likely the same motor. Just looking to varify as motors for that hp seem to be expensive. I only have $200 invested in the pump and tank so I still will come out on top after the motor purchase. Thanks guys
Matt |
02-08-2012, 06:19 PM | #33 |
Matt start another thread and I can help with some more motor info. Just to fair to Tri 5
03-03-2012, 09:46 PM | #34 |
it's rebuilt.
Well today I was finally able to get to my friend and get the pump put back together. He pull the old bearings off and replaced with the new ones and polished the crank. Looking at the rebuild kit I noticed that the valve kit was a little different but I followed the instructions they provided. It took about 2 hours to put it back, I didn't need to use a ring compressor tool because it cyclinders has a bevel at the bottom to have the piston slide in.
It looks like the original issue was with the reed valves pins came loose due to the head loosening and scaring the pistons a little but not doing any real damage to the piston, so now i need to get some syntechic oil and put it back on the tank. I have almost all the parts available to reuse if needed, hopefully I will never need to do it again. I have the instructions and can share them if needed, I just have to scan and save them. Tri5
03-04-2012, 09:17 PM | #35 |
Got it running now, but mow the pressure switch is leaking air so I'll take that off and try to fix or buy a new one.
Tri5
03-06-2012, 12:14 AM | #36 |
Tri Five glad to see it going again. Congrats on doing it yourself. As far as a leak at the P Switch. Be sure to check the check valve where the discharge line goes into the tank. The P Switch is supposed to bleed off the air in the compressor pump after the machine shuts off. When the check valve fails, the P switch will bleed air constantly. I have sold many switches to only have people come back complaining that the new one "leaks too".
03-06-2012, 02:29 AM | #37 | |
