10-14-2011, 11:33 PM | #26 |
Re: Is it bad form to use rhinoliner/hurculiner?
subscribed.
10-14-2011, 11:43 PM | #27 |
VA72C10
I'm going to be using herculiner on mine because it's a longbed and not a show truck. I plan to fix the little bit of rust and few floor dents then scuff and put on the liner. I'll take pictures before putting it on to prove it's not covering any rust. Got it for $49 after Rebate at O'reilly's for a kit. Will need one more quart because it's a long bed if I want to go all the way up the sides (might just do the floor)
Looking for a 67-72 swb or blazer project in or around VA. |
10-14-2011, 11:54 PM | #28 |
Petroleum User
I think it looks great. I bought a bed with the liner already done and considered it to be worth over 200 bucks in material and labor that I didnt have to do myself. I dont know about resale value, though, but Im gonna hang on to this truck anyway. I think I'll line the cab floor with it, too.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
10-15-2011, 12:09 AM | #29 | |
10-15-2011, 12:23 AM | #30 |
~Rest In Peace~
kevlar
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
10-15-2011, 12:38 AM | #31 |
Catchy title goes here..
Just keep it off your hootus, and you will do just fine.
10-15-2011, 12:41 AM | #32 |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-15-2011, 12:48 AM | #33 |
Petroleum User
10-15-2011, 12:56 AM | #34 |
10-15-2011, 10:43 AM | #35 |
Newbee
ROFLMAO!! OUCH! Yes I googled it...
BTW, I forgot to mention earlier. The Al's gun ( hootus made me remember) uses ALOT of air. So if you dont have a big compressor, round some up from friends, and hook the hoses together. AND FOR THE LOVE OF GOD, WEAR GLOVES |
10-15-2011, 11:19 AM | #36 |
I personally havent found a home use spray on that turns out as nice as the professional products, I have helped 12 college buddies to date do their trucks to save a buck and no matter how good the product was you could always tell that it was a diy kit... now as far as the professional products go I have used both lineX and Rhinoliner on the farm and would have to say that I much prefer the looks and useability of lineX. After a number of years of abuse lineX still looks pretty much new after you spray it down with a pressure washer and spray tire gloss on it, while rhinoliner put through the same test looks like it was used and for some reason I noticed on a few trucks was that rhinoliner will sometimes chip.Just my .02 take it for what its worth
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-15-2011, 11:22 AM | #37 |
People know me
I love the Als liner, I have sprayed over 20 gallons of it and it is holding up great.
Harbor frieght sells the exact same gun as als liner and you can usually get it for cheap, I was in there a month ago and picked one up for $8 bucks, gonna use as a spare.http://www.harborfreight.com/texture...gun-66103.html As far as resale, you can look at the job done and the underside and get a good feel of what kind of shape the truck is in. I have sprayed my 67', Blazer and Jimmy the GMC. I sprayed both sides of the firewall, the interiors and beds. I tinted all of them to color match and have had alot of compliments on them. It is nice having bedliner in the convertibles, especially if it is raining, dont have to worry about wet carpet starting rust.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
10-15-2011, 11:24 AM | #38 |
I have a spray in liner in my newer truck and a couple months ago i spilled brake fluid in the bed and it took the liner off clean to the paint and left the paint like new. Idk if it would be a good thing to try or not, id be worried about my paint but it could be away to remove a liner like that.
1969 shortbed c/10 1998 GMC sierra |
10-15-2011, 11:52 AM | #39 |
If you go with it and it gets scratched (broke through to the metal) Either repair it or cut the non-adhered part off. The PO of my truck had scratch bedliner in a few places. Underneath was solid rust.
10-15-2011, 12:07 PM | #40 | |
Active Member
We have all seen what rust can do under the drip rails seam when unseen and undetected. By the time you notice it, it has done it's damage on the cab top and elsewhere in the cab. All I can say, if it has liner all over, beware... |
10-15-2011, 02:03 PM | #41 |
This has got me motivated,....good info! I gotta yank the plastic bedliner first. Why does anyone think these are a good idea?
10-15-2011, 03:28 PM | #42 | |
Mine was a new floor (from LMC sadly). |
10-15-2011, 04:04 PM | #43 |
This thread ended up having a wealth of info, thank you everyone! I think I am going to go with either al's liner or hurculiner. I just picked up the truck today from the guy and I'm making a list of things I want to do to it, so this has gotta go to the back burner until I get that stuff done! I'll let you know how it turns out though.
10-15-2011, 04:18 PM | #44 |
I am a Referee of life.
Liner a user
Wood a Shower The "hootus" remark is due to a story about a guy who posted his experience Let's just say "Go Pee before you start and hold it until you're finished".
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-15-2011, 04:27 PM | #45 |
BlahBlahBlah
Ive had both, plastic liner and Rhino. Both have good and bad qualities. The thing about the plastic one is its sure easy to slide stuff in and out. The thing about Rhino is its sure nice stuff doesn't slide all around.
So guess it depends on your likes. My plastic one was an under the rail. I gave my box a really good brush coating of Hammerite before I installed the plastic liner. Took it out years later with no rust problems underneath. My son used to spray Rhino for a Dodge dealership on their new trucks. I would stop by and visit him at work and damn that stuff gets everywhere, and like someone said, forget ever using those clothes and shoes again. You should have seen his little shop radio, it had a thick coating of liner and still worked =)
10-15-2011, 06:54 PM | #46 |
Or, you could go with line-x, it's not as thick as rhino and it can be color matched. It usually runs about 450 for a short bed plus 200 to color match. They actually spray the color on after the line-x. Here's some photos I got from their website: No, i'm not a salesman I just think it looks really cool
Cheers, Last edited by 72peace; 10-15-2011 at 07:01 PM. |
10-15-2011, 07:21 PM | #47 |
The color matched stuff looks great.
"You can take the man out of PA, but you can't take PA out of the man" |
10-15-2011, 07:24 PM | #48 |
wow i really like the heartbeat of america put on the front of that box, can they color match any truck or is it just a couple of colors to choose from?
10-16-2011, 01:56 AM | #49 |
The line-x stuff isn't cheap but it looks really good and they say those that don't have the time to do it themselves save up for it and have it done or sell it and get a cheaper hobby. I'm having a guy rebuild my trans for 250, another guy is going to take the bed clean up the dents and primer it for 500 because i usually work 50 hours a week and like most of us usually have to finish the honeydew list before we can work on the truck. But the 50 hours a week help pay for what needs done, so it's a give and take situation. Sorry, what were we talking about, oh yea, the line-x is my plan after the dents are removed, once I save up for it.
And I believe, like most body shops can order and match any color. |
10-16-2011, 10:31 AM | #50 |
so easy a caveman can do it...
I don't think it's such a bad thing if you're going to keep using it as a truck. I plan on having the metal strips sprayed for my wood bed and the floor of the cab.
