Old 10-25-2011, 01:40 PM   #1
68Stepbed
68Stepbed's Avatar
New look in engine bay
A couple months ago, my thermostat stuck and I overheated my engine, which caused the oil to get real thin, which caused 3 wiped cam lobes and several weak springs. In the process of swapping cams, I had to lift the engine to get the pan off, so I just unbolted everything and pulled it out. While out, I repainted the engine, valve covers, pulleys, t-stat housing, etc., etc. I reversed my color theme a little bit. I also put on my custom made wire looms.
Here's the end result. Let me know what you think.
Here's what it looked like before.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
