Old 10-31-2011, 08:25 PM   #26
YBNORML
YBNORML's Avatar
Re: copper lines with accuair setup ??
I'm watching this one, should be starting on my accuair system soon!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-31-2011, 11:03 PM   #27
67cheby
67cheby
67cheby's Avatar
that is what this whole thread is about....you dont need to use anything the aluminum slides in just like the plastic lines !!
67cheby is offline   Reply With Quote
Old 10-31-2011, 11:27 PM   #28
FnLow69
FnLow69's Avatar
you can also use compression fitting with the aluminum line if you wanted to
FnLow69 is offline   Reply With Quote
Old 10-31-2011, 11:59 PM   #29
VA72C10
VA72C10
VA72C10's Avatar
Great thread cheby! I am going to do this....when I build a bagged truck I'd definitely polish it too!!!!!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-01-2011, 10:29 AM   #30
Tony@AirRideTech
Junior Member
Originally Posted by chapster View Post
Where was this thread a few months ago...lol
I am into my S.S lines and Swagelok fittings for $450 and I still need a couple of flex braided lines.
Stainless much better set up... thats what I would have run myself
Tony@AirRideTech is offline   Reply With Quote
Old 11-01-2011, 11:21 AM   #31
67cheby
67cheby
67cheby's Avatar
because of ?? i would love to run stainless but trying to find a more economical route ? is there a reason not to run the aluminum ?
Old 11-01-2011, 11:49 AM   #32
Tony@AirRideTech
Junior Member
Stainless is just a better route to go. It doesnt work harden especially like copper does... and aluminum wont rust and is a much better choice that standard steel line but it does work harden quicker and it can corrode over time unless you are using more expensive coated tubing. Plus you can polish the stainless and it is sweet~!
Old 11-01-2011, 12:09 PM   #33
67cheby
67cheby
67cheby's Avatar
thanks for the info...i agree nothing looks as good as the stainless ! but for a guy on a budget the aluminum might be the way to go !
Old 11-01-2011, 12:22 PM   #34
belowme51
belowme51's Avatar
yeah im in the same boat cheby...aluminum or copper....copper fits the final product im aiming for but $$ wise polished aumuinum was on the list too....being that the entire of the rear of my truck will be exposed when i open it up i want the "holly sh**" reaction..lol...
belowme51 is offline   Reply With Quote
Old 11-01-2011, 12:24 PM   #35
belowme51
belowme51's Avatar
ill talk to the accuair guys today or friday at sema being that ill be there and see what there thoughts are also.
Old 11-01-2011, 12:29 PM   #36
67cheby
67cheby
67cheby's Avatar
oh....thanks for rubbing it in !! "oh i will just ask them since i will be at SEMA " ......SHOW OFF!!
Old 11-01-2011, 12:44 PM   #37
belowme51
belowme51's Avatar
lol ill tell them hi for ya
Old 11-01-2011, 12:47 PM   #38
belowme51
belowme51's Avatar
hey you get to rub it in all the time, you at least have sheetmetal on your ride...lol right now I just have a frame.....the rear wheels are taking for ever to get done so im holding off on those, just trying to keep up with you man.
Old 11-01-2011, 12:52 PM   #39
dznucks
dznucks's Avatar
when i was routing the aluminum lines for my accuair setup I found that I could straighten the coiled tubing with a wooden dowel. Once it was straight, i then bent it. Also, use a coat hanger or other wire to mock up the bends. Then transfer the coat hanger bends to the tubing.
The aluminum tubing is soft and you may want to use a cheap bender or you risk kinking or deforming the tubing while bending.
Another plus to running metal lines are their resitance to damage from road debris. At least thats what motivated me to use aluminum.
dznucks is offline   Reply With Quote
Old 11-01-2011, 01:03 PM   #40
67cheby
67cheby
67cheby's Avatar
do you mean sticking a wooden dowel through the middle of it and rolling it out flat ??
Old 11-01-2011, 01:04 PM   #41
67cheby
67cheby
67cheby's Avatar
oh WHAT____ EVER !!!
Old 11-01-2011, 01:16 PM   #42
Tony@AirRideTech
Junior Member
If I only had a copper budget, I would plumb it in D.O.T. Synflex tubing.
Old 11-01-2011, 01:17 PM   #43
67cheby
67cheby
67cheby's Avatar
?? what is that ? i am going to google that now.LOL
Old 11-01-2011, 01:35 PM   #44
Rochlow
I've used S.S. braid line and A.N. fittings before and will do them again on my current project.
Rochlow is offline   Reply With Quote
Old 11-01-2011, 01:37 PM   #45
gringoloco
A guy with a truck
gringoloco's Avatar
Hook one end to a stable object (vice, etc) loop the other around a tool. Yank HARD to shock it into shape. Voila- straight tubing.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-01-2011, 01:47 PM   #46
Tony@AirRideTech
Junior Member
" Shocker "
Old 11-01-2011, 02:28 PM   #47
67cheby
67cheby
67cheby's Avatar
Lol....
Old 11-01-2011, 02:36 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
Guess I coulda worded that differently...
-Chris
Old 11-01-2011, 04:46 PM   #49
Tony@AirRideTech
Junior Member
Leave it to me to drive this straight into the ditch.
Old 11-02-2011, 08:01 AM   #50
dznucks
dznucks's Avatar
Yes.....being very gentle. you dont want to break the dowel off inside. I imagine a piece of aluminum or copper rod would work too.
typically, you wont have more than a 6' to 8' long run of tubing. I would use a string to get the length mocked up along the path i was going to route the tube. then cut that much tubing off the coil to that length and use the dowel to straigthen it. You can straighen one half, then go in from the other side and straigthen the other half.
Then the use the coat hanger as a guide to bend the tubing.
