#26 |
Re: My truck vs the cooler outside temps
Well, that is the plan this morning. tranny vacuum will be easy.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
#27 | |
#28 |
got the tranny line fixed. bought a vacuum gauge to dial the ons. best I can get is 8 to 9". I had to adjust the one way out before I reached max vacuum. so, the next thing to tackle is the dizzy.
can I adjust timing based on vacuum since the balancer is not reading right?
#29 | |
with that tube melted the combination of low vacuum and a leak causes a real bad idle issue not to mention these cams perk up around 25-3thou rpm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#30 | |
The timing needs some help though (I think). The erradic idle made it difficult to properly check vacuum. Is the balancer removeable w/o removing anything else? Also, I was trying to setup the choke. I noticed that with full choke, the valve is basically closed, which has been causing the engine to snuff out. How do I get the connector rod for that valve off so I can bend it a bit? I think once that is fixed, the choke should work like it is supposed to.
#31 |
If the engine has a fairly radical camshaft it may require an excessive amount of throttle opening for idle and/or have low idle vacuum levels. Either condition can lead to poor levels of
adjustability and erratic idles. • A fix for the above condition is to run as much spark advance as possible at idle. If the distributor is fitted with a vacuum advance unit, connect it directly to manifold vacuum. If you are not able to employ vacuum advance for some reason, then the mechanical curve should have a low limit, which will allow you to use plenty of initial spark advance. • Measure the manifold vacuum at idle. If it is below 7" Hg, there is a good chance that the Metering Rods are in the up (rich) position. When combined with a high idle air rate this can cause the Nozzles to discharge fuel at idle. Use a weaker Step-Up Spring to keep the Rods down at idle. With some cams, a stiffer spring (pink or silver) is necessary. Experimentation is the best way to determine which is best for your application. Last edited by RUSHNBOBO; 10-28-2011 at 09:43 PM. |
#32 |
#33 |
Why is everyone set on his carb is to big. The stock Rochester Qjets were 750. Its not the carb size. Level headed and unbiased I would say start with watching the eldelbrock tuning videos if you haven't seen them yet. after that id make sure the chock is properly tuned. and Idle screws(again). If thats not your issue make sure your gasket isn't leaking.
#34 | |
I guess I wil need to buy the calibration kit to find a good working setup. Thanks for the tips.
#35 |
it would help alot if u had your 4th carb stud and nut thats missing in your sig pics
#36 | |
Engines and carburators don't work that way, any given engine can and will only draw so much air no matter how big of carb you put on it. And any given amount of air passing through a venturi can only pull so much air/fuel mixture period. A engine is just a air pump, you could put a properly jetted 850 cfm carb on it and it will still run smooth and pull in approx the same amount of air/fuel mixture. The difference being air/fuel mixture will be moving at much slower velocities when compared to a 600 cfm (this is where the differences become a liability) The engine may not be capable of drawing the full 850 cfm but will draw only as much as it needs. I just read an article where they took a 383 sbc and just for comparison purposes they ran a 390, 600, 750, 850, and a 950 cfm carbs. Every carb could be easily be jetted to 14.7: 1 and tuned to run smooth. The main problem when running oversized cfm carbs are not fuel consumption or mixtures but a poor venturi signal and velocity especially at low and mid rpms.....this is where over carburation will kill your torque and hp numbers. The venturies become so large that the undersized engine cannot pull the air/fuel fast enough through the smaller diameter venturi. Greater velocity=the speed of air/fuel charge. The highest velocity is what your after at your desired rpm range. Example if you were to never to exceed 4000 rpm, a 390cfm carb on a 350 ci. engine may show increased throttle response and hp and torque numbers over a 600cfm. Exceed into higher rpm ranges and the venturies now become a restriction, hp and torque will drop off, due to air/fuel requirements now being greater than the carb can deliver. If your engine is running like crap it ain't cause your a little over carburated especially not a 750 cfm. Read my last post about big overlap cams with the Edelbrock.....that cam is giving you a very weak manifold vacuum which makes the carb act like your accelerating hard even though your at idle (low vacuum) so your most likely loading up with excess fuel. This happens on Holley type carbs with big cams on the power valve circuit.....most stock Holleys have a 6.5 in hg power valve vacuum opening point. If you idle at 6-7 in hg you can quickly see the problem.....the power valve may be open or partially open at idle, flooding the engine with fuel. Swapping to a 3.5 or 4.5 will usually fix this. I have a friend with the same cam in a Camaro and he idles right at 7 in hg and would load up quickly right off idle, fixed the power valve circuit and it idles and accelerates fine. Read the articles on the Edelbrock website....they go into detail how to set up their carbs on radically cammed engines. |
#37 | |
A large cam like yours will be happy with as much as 15-18 degrees initial, if you can add vacuum on top of that without detonation do it. Get your mechanical right first, "rate" (how fast it rises) and amount, then add vacuum advance a little at a time (use an adjustable chamber) if you use full manifold vacuum dial your chamber to the lowest setting and see how it runs, if you hear no detonation begin to add vacuum adv a turn or two at a time. You may have issues with your starter at this high of initial advance....but there are ways to fix that. You can run a start retard box MSD (their cheap) you could step up to a mini gear reduction starter (not cheap) or you may have no issues....I run around 16 degrees of advance with a direct drive starter and it's a little sluggish when i'ts hot, some of that is heat soak though. Any port below the throttle plates is full manifold vacuum and will work even with a tee fitting. |
#38 |
Why d you need to remove the balancer? If you don't have a pointer go to the parts store and get one. Are you can do as the Rush said and bump the timing up a little at a time, it you here detination back it down a little. Are you running a HEI dist? If you are pull the cap and make sure the mechanical advance is working and not froze up. Turn the rotor and it should spring back when you let go.
#39 | |
#40 | |
I am running a stock HEI. I will have to try that tip to see if the advance is working.
#41 | |
My 2 options are: 1.) Drill out the mounting hole on the carb to allow use of bolt or; 2.) Install a heli-coil I think I will prolly do #1 until I replace the intake manifold altogether.
#42 |
Well, I think a dizzy is in order soon. When I pulled the cap and tried to turn the rotor, it was locked in place. I did check to make sure the rotor was secure, but it wiggles around a little bit. Like the shaft is loose. It wiggles enough to change the timing just a little. Not sure what would cause that.
Any ideas? Thanks!
#43 | |
#44 |
I do things within my knowledge and experience. It worked before, it'll work again.
#45 |
Id put the heli coil on it they work fine.
#46 | |
Also with that cam, a spark amplifier box is a good investment, they kick up the 12 volts to around 300-450 on the primary side. Most also feature multiple sparks at lower rpms to help light off the fuel with high combustion chamber pressures caused by high static compression and big overlap cams. I run a MSD 6a on every vehicle I own.....even my Yota pickup has one. Also good heli-wound wires and a good aftermarket coil (make sure it's compatible if you have a spark amplifier).....one more optional ignition component is a in cab "ignition dialback", this is a valuable device if you run your ignition on the edge of ping, no ping. It connects in the with the spark box and allows you to change your amount of overall timing on the fly....great when changing elevation or when running sub-par fuel. |
#47 |
I think next payday, I'm gonna buy a new stock dizzy until I can afford the MSD 6AL setup. Or get the MSD Streetfire dizzy which isn't much more than the stock Accel.
#48 |
Next question on the dist. Does it have any wires going to it besides waht plugs into the cap? I see in one of the pics that there is a four wire weather pack connector tied up on the firewall. I believe this year model may have come factory with esc, if so the dist. will not have mechanical advance.
If not then the mechanical advance is froze up if you cant turn it by hand. So what ever intial is set at that's all the timing you are getting. |
#49 | |
I noticed that Jegs has the MSD Streetfire dizzy on for $119.00. I will def. get that ASAP. Pulling the dizzy seems pretty straight forward. I won't need to remove the hood will I? Thanks!
#50 |
I just wanted to say that I appreciate everyone's efforts in helping to resolve my issues. I know it gets frustrating when you can't be here in person. I could really use someone in my area that has good knowledge of these things to help me out some. Having only a Haynes book and the internet to go by, really makes things harder than what it should be.
Thanks for all your help, I know we all can get my truck running like it is suppose to soon.
