02-07-2012, 10:49 AM | #26 | |
PITbut
Re: Carb issues, just chime in.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-07-2012, 02:03 PM | #27 |
Have you tried adjusting the accelerator pump linkage to give you a little more juice when you hit it? If it's like my old Carter AFB (they look the same), move the linkage one hole inward toward the pump. This will give it a little more gas through the boosters when you stomp it. If that fixes it your good. If it makes it worse, go one hole out from the original hole.
02-07-2012, 02:08 PM | #28 | |
PITbut
02-07-2012, 04:52 PM | #29 |
Did the Q-Jet ever have a throttle-shaft bushing kit put in it?
02-07-2012, 04:55 PM | #30 |
PITbut
The quadrajet had corroision in EVERY hidden crack. SOaked it, blew it out, and i was continually getting pieces of junk coming out. So i bought a new one.
I also kept the quadrajet and bought a book on how to rebuild it. Mine has all new stuff and is setup right, i just need to get the passages cleaned somehow. THe soaking didnt seem to do it.
02-07-2012, 05:45 PM | #31 |
Take a look at a couple of articles on this Corvette site (http://lbfun.com/Corvette/Tech/vettetech.html) scroll down the page to "timing and vacuum advance." The article "Vacuum Advance Principles and Application" by Duke Williams and one by John Hinckley, "Advanced Curves" will explain vacuum advance, timing, and ported vs manifold vacuum. Big Blocks with big cams typically have lower vacuum than stock and usually need to have a different vacuum advance can installed. These two articles helped solve my problems.
