Old 11-15-2011, 01:42 PM   #1
awbrown
Re: Bought my truck tonight!!!
comp cams zinc additive is number 159 for the 12 oz bottle.....
awbrown is offline   Reply With Quote
Old 11-15-2011, 10:24 PM   #2
SchnorrCS
Nice!
You guys are awesome!
I think I'm gonna use the comp cams break in additive all the time. I have the comp cams cam card, and they recommend it all the time. Figure it can't hurt.
I am going to try and get the shift linkage adjusted, but I don't think it's gonna help a whole lot.... You're gonna hate me for this..... I found out its an M22 (rock crusher). That would explain the gear whine and semi rough shifting........ Hahaha. This truck deal I made keeps getting better and better.
I'll post some more pics this weekend when I get the new tires on and clean her up a bit.
SchnorrCS is offline   Reply With Quote
Old 11-15-2011, 10:50 PM   #3
rideblue00
rideblue00's Avatar
I have a ? What is that wire/spring lookin thing goin up to the radiator?
rideblue00 is offline   Reply With Quote
Old 11-15-2011, 10:59 PM   #4
SchnorrCS
It's a temp prob for the electric fan controller.
Old 11-14-2011, 11:07 AM   #5
MikeN
MikeN's Avatar
Post photos of your shifter and seat if you can. I'd like to use a Muncie 4-speed in my truck, but haven't really come up with a good solution for a shifter that will work with the stock bench seat.
MikeN is offline   Reply With Quote
Old 11-14-2011, 12:21 PM   #6
TheManInBlack
Couldn't you use a stock shifter from an El Camino, my old man had one with factory bench, it has a big bend in it to work around the seat.
BTW truck project looks cool!!
TheManInBlack is offline   Reply With Quote
Old 11-15-2011, 12:55 AM   #7
js91z
Very good looking truck! The only thing that I would change would be the air cleaner. I had one of those and it caught fire after a back fire through the carb. Otherwise its a great looking ride! Have fun with it
js91z is offline   Reply With Quote
Old 11-14-2011, 12:37 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
You might check out the newly released Hurst bolt on 55 Chevy shifter handle. It should stick up about 2-3" higher than the welded type and should work great with a bench seat. I believe it is part number 5388620:
Old 11-14-2011, 01:38 PM   #9
doobiebro
doobiebro's Avatar
Markeb01 I used the exact shifter for my 1962 C-10 I used to have years ago. I believe it was 55-57 and also bought the installation kit which made the shift smooth and tight. I bolted it up to a 4 spd Saginaw but the only thing I had to do was heat and bend forward (a little bit)the lower part of the shifter cause 4th gear was hitting the bench seat. But it came out nice and fun to drive.
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
