Old 11-15-2011, 11:13 PM   #26
J.Cagle
J.Cagle's Avatar
Re: Getting a non running truck started??
yes, they move and look new. I don't know what else to check. Had a friend come over with his volt meter and I am getting good power to the coil and everything.
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 11-15-2011, 11:25 PM   #27
J.Cagle
J.Cagle's Avatar
A guy I know suggested switching my wires around that connect to the coil. That sound like a possibility?
Old 11-15-2011, 11:29 PM   #28
awbrown
negative to points positive to switch and resistor bypass wire ...did you try to short the points with a screwdriver???you could also hot wire direct to the battery....
awbrown is offline   Reply With Quote
Old 11-15-2011, 11:32 PM   #29
J.Cagle
J.Cagle's Avatar
Yeah, Ive got my negative side hooked to distributor and the positive side hooked to the power wire that comes out of the wireing harness on the firewall. When I touch my test light to the negative terminal on the coil it lights it up when the key is on. Thats normal right?
Old 11-15-2011, 11:49 PM   #30
awbrown
drive your testlight between the contacts of the points and see if you get any spark from the coil wire.with the key on of course...
Old 11-15-2011, 11:50 PM   #31
awbrown
last but not least run a ground wire to the distributor in case it has coroded between the clamp and block...Dont force me to come down there and start that thing for you !!!lol... one more thing you can check it by grounding your test light and checking the distibutor housing and see if it is grounded fifteen years can cause a lot of corrosion and a lack of a ground ...if when you go from ground to the distributor housing if you get a light it is not grounded properly..........
Old 11-16-2011, 01:57 AM   #32
Captainfab
60-66 Nut
Sounds like you are having the same issue I had last week. I posted the solution in my previous post.
Old 11-20-2011, 11:06 AM   #33
J.Cagle
J.Cagle's Avatar
Got it to run!!!!!!!!!!!!! Put a set of new points in it and it fired up. Actually ran pretty good. Didnt smoke or knock. Wouldnt stay running with out either b/c the old gas is so bad. Draining the old gas now and Im gonna tune it all up and see how she'll run! Pretty excited!
Old 11-20-2011, 02:13 PM   #34
csa daddy
csa daddy's Avatar
congrats on getting her runnin
csa daddy is offline   Reply With Quote
Old 11-26-2011, 12:04 PM   #35
b2948kevin
b2948kevin's Avatar
Nice! Beware that the screens in the tank (at the end of the pick up tube that also holds the fuel sender) can rust and clog. I sprayed mine with carb cleaner and scraped it off and it worked again. It was really nasty in the beginning.
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
