Old 11-15-2011, 10:31 PM   #26
71swb4x4
71swb4x4's Avatar
Re: Engine Blew?
Vacuum lines will certainly affect the way it runs.
As far as oil leaking when you were running without a PVC valve you may have boogered up the rear intake gasket. Can you tell if there is oil leaking from the rear of the intake?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-15-2011, 10:49 PM   #27
85Bowtie
85Bowtie's Avatar
Re: Engine Blew?
Do you not have an oil pressure gauge? If you blew your intake gasket, then you should see your oil pressure drop under acceleration since the oil is getting sucked out of the engine.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 11-17-2011, 10:06 AM   #28
HTX86chevy
HTX86chevy's Avatar
Re: Engine Blew?
Ok guys this is just a quick update: Found the oil leak. Turns out that oil is leaking from the Oil dipstick tube where is inserts into the block. Can this be fixed easily? Is there just a simple o' ring or gasket or do I need a new dip stick tube? there is alot of play in mine. I can twist and turn it and pull up and down on the tube. How do I remove it? Just yank it out?
HTX86chevy is offline   Reply With Quote
