Old 11-30-2011, 11:05 AM   #26
1963c-10
1963c-10's Avatar
Re: BBC Swap
Nice job, cant wait to get around to installing my big block. I went with tubular motor mounts from CPP for header clearance. Can't wait to see what we'll have to modify. Although mostly looks like some frame trimming from what ive seen.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-30-2011, 01:14 PM   #27
argonaut
argonaut's Avatar
Re: BBC Swap
Frame trimming is all you'll have to do if you don't shift the motor/trans forward. Plus exhaust and accessories, etc. I don't think that hood clearance is really an issue on these trucks, at least not that I've experienced, unless you plan on a blower or a high rise intake....
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-30-2011, 01:34 PM   #28
C/10 King
C/10 King's Avatar
Re: BBC Swap
Jason, boy I'm very impressed, I hear M.I.T. is looking for guys like you. Hope to see you soon.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 11-30-2011, 01:43 PM   #29
argonaut
argonaut's Avatar
Re: BBC Swap
Hey, they don't call me "The Doctor" for nothing...
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-30-2011, 02:15 PM   #30
1963c-10
1963c-10's Avatar
Re: BBC Swap
No, no blower or hi-rise. Im also converting to hydraulic clutch to get rid of all the frame linkage. Got a nice mounting plate from Captain Fab for that. Just about have everything pulled together to do the swap. Tryna make sure I have all parts on hand (at least planned parts).
Old 11-30-2011, 02:31 PM   #31
argonaut
argonaut's Avatar
Re: BBC Swap
I agree on the hydraulic clutch. Much cleaner installation and nicer actuation than mechanical linkage or cable types. Show us pictures when you do the installation!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-30-2011, 07:00 PM   #32
C/10 King
C/10 King's Avatar
Re: BBC Swap
Doctor Tripas, that has a nice ring to it.
C/10 Rene
1971 Short Fleet
Old 11-30-2011, 08:33 PM   #33
protrash64
Resistance is Futile
protrash64's Avatar
Re: BBC Swap
I'm running a 6'' K&N on mine with no problems clearance wise.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-03-2011, 10:08 PM   #34
argonaut
argonaut's Avatar
Re: BBC Swap
Got a few more things done yesterday.
Installed a new pinion seal. The last one was letting oil drip through and then spray all over the underside of the chassis with the spin of the driveshaft... lovely. I didn't find any noticeable cut or ripped or worn spots on the old seal so who knows.
Measured the angle on the trans output shaft (7.5 degrees) and on the pinion (4.5 degrees) so it looks like I need to rotate the pinion up by 3 degrees. This wont be a problem since I currently have some spacers installed to tilt it down for the old engine-trans angle. now I can take them out, which makes me happy.
Got all my vacuum hardlines made up and got my power steering brackets and lines squared away. Alan Grove's brackets are serving me well, although they came with 7/16" bolts to mount to the block while my holes are all tapped for 3/8" so I had to replace them and the brackets fit a little "sloppy" until tightened up because of the bigger through holes. I also had to re-route the pressure and return lines to go under the frame rail but they fit nicely now, even better than with the small block in there.
I still need to get my electric fan hooked up, although I did get it already. I also need to get the new exhaust welded up. Lastly I ned to sort out the carburetor. The motor runs well but won't idel below 1200 rpm with the idle speed screw all the way out... yikes. I want to rebuild the stock quadrajet anyway, so everything will get sorted out.
Took it for a test drive around the block. It drove smooth and strong but with straight pipes its just way to loud, so I didn't really put my foot into it.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 12-03-2011, 11:39 PM   #35
protrash64
protrash64's Avatar
Re: BBC Swap
on the test drive.
Old 12-04-2011, 10:55 AM   #36
Rich 5150 69
Rich 5150 69's Avatar
Re: BBC Swap
Cut a short piece of copper or brass tubing to fit the thickness of the brackets that is the same diameter of the 3/8 bolts, make a cut length wise thru the tubbing to act as a sleave to make up the differance. If this makes sense.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-04-2011, 07:16 PM   #37
argonaut
argonaut's Avatar
Re: BBC Swap
Rich,
That sleeve idea is a good one. I think it will work the way I have it now but I'll make up sleeves and see how it works out. The other thing I could do is just drill and tap the holes for the 7/16 bolts. I believe that holes on the right front of the block for the a/c brackets are 7/16 already.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 12-04-2011, 07:19 PM   #38
argonaut
argonaut's Avatar
Re: BBC Swap
Also, if a moderator sees this thread, maybe they can move it to the "projects" section.... I was thinking it might be more appropriate there. Then I'll add some more photos and info about other things I've been doing to the pickup.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 12-05-2011, 10:17 AM   #39
1963c-10
1963c-10's Avatar
Re: BBC Swap
Im glad to hear that, because thats what I bought prior to install in hopes that it'd fit
Old 12-05-2011, 09:30 PM   #40
Rich 5150 69
Re: BBC Swap
14 x 4 inch air filter with plenty of room to spare..
Old 12-06-2011, 02:57 PM   #41
argonaut
argonaut's Avatar
Re: BBC Swap
Rich,
I like your radiator... I think I have the same one.
Well old Gerty is under the knife today getting a full 2.5" dual exhaust system with H-pipe and 50-series flowmasters. We'll see what it sounds like tonight when I pick it up.
I'll wire the fan up later this week, but I'm still waiting on a thermo-switch. I was thinking about on at 190 off at 180, or somethign around there. I have a 180 thermostat in the engine. Any suggestions or advice on on/off temps for the thermoswitch?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
