11-29-2011, 05:46 PM | #26 |
Re: running a 31x18x15 on a 64 fleet
Or.......... as suggested, look for a narrower housing from a different vehicle. Sometimes they can be obtained easier.
11-29-2011, 07:13 PM | #27 |
Only thing I can find is a 9"at 58" from a first gen bronco my uncle said a 9 from
A mid 50s model ford car would work said it should be around 53 " side to side. But I don't know where I would find one of those Posted via Mobile Device |
11-30-2011, 11:51 AM | #28 |
It's Better With Nitro
That is the tough part of the equation if you plan on running that wide of a tire/wheel combination...you'll almost have to narrow a housing, or run a wheel with an unconventional backspace dimension.
11-30-2011, 12:20 PM | #29 |
I talked to a buddy who told me of a guy not far from my house that will narrow a rear for 80 bucks an he knows another guy to respline the shafts so I'm just going to narrow up a 12 bolt an keep it gm just use a newer rear with 5 lug pattern an do it 51 inches like you done yours an I should be able to run a standard 15x14 wheel with 4.5" back space I think an still lay it out like I want
11-30-2011, 01:09 PM | #30 | |
11-30-2011, 01:29 PM | #31 | |
11-30-2011, 01:42 PM | #32 |
Nothing else I guess I can order new if I have to. But thanks for the tip I will have to check into that
11-30-2011, 02:36 PM | #33 | |
Sorry about my blue bed dolly (I use it to lift the bed off and on, and to lean on on while doing some of the work on the chassis). Here's an older photo without the bed...
11-30-2011, 03:40 PM | #34 |
Im just going to run factory 5 lug drums for the rear an how much offset do your wheels have an will the outside of tire clear the inside of the truck box sides. You know the part where the top an bottom come together on the inside of the box where it has the 3/4 lip that goes back to the top half of bedside. If I narrow the housing to 50" flange to flange then it should be 54" from mounting surface to mounting surface on the rear. Cause brakes are about 2" thick roughly. ok if I make there rear a total of 52" wide from mounting surface to mounting surface I will have 10" on both sides of the rear at that point theoretically I should clear every thing with no problems an still have a couple inches to spare on the back side
