Old 11-21-2011, 03:19 PM   #26
Reziel_1983
Reziel_1983's Avatar
Re: Installed new engine today, think that I might have an Exhaust Leak.
Originally Posted by INSIDIOUS '86 View Post
sounds like something isnt right in the valvetrain, did you use break in oil for the engine?
We used Delo 15w-40 for it. That is what our machinist told us to use.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 11-21-2011, 03:21 PM   #27
Reziel_1983
A mechanic came over today and told us that the deep sound was a main and the higher pitch was.something outside the engine scraping. Pulling the motor out again now.
Old 11-21-2011, 03:26 PM   #28
Reziel_1983
Another thing to add is that these noises have been heard since the moment the engine fired up the first time.
Old 11-21-2011, 03:35 PM   #29
INSIDIOUS '86
INSIDIOUS '86's Avatar
wel delo even has lower zinc levels now so thats why break in oil or zinc additive should be used exclusivley for the engines to survive the first ten mins of break in
if the main bearings are wiped out have a machinist check the clearances cause if its using spacer bearings or a large journal crank its likely not clearanced right, alot of these stroker cranks are made in china (eagle) and a crosseyed machinist could have made better cuts
if so your engine builder should fix it free, his fault for not checking clearances
and plastigauge is not a viable way for this
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-21-2011, 04:06 PM   #30
stroker87
once "most" of these engine builders get your money your warranty is over as soon as the engine leaves his hands, the 1st engine builder I used said my engine was "all checked" and ready to go! had it in stalled found out the oil pan was hitting a rod bolt after i got that worked out the engine never made the HP it should of tuning was a nightmare 3000 miles later I found out why after the engine died the distributor gear was chewed up since he never set the height, was suppose to be 10:1 and was 8.9:1 and the comp cams hydraulic roller lifters I paid for was a cheep $50 set and this was done be a big machine shop not a mom and pop place (witch i maybe should of used)
sorry for the rant just get up set when stuff like this happens!
stroker87 is offline   Reply With Quote
Old 11-21-2011, 04:49 PM   #31
Reziel_1983
The higher pitch noise seems to happen more often when the engine is warmed up, if that helps at all.
Old 11-21-2011, 07:39 PM   #32
3r!c84
Badass
3r!c84's Avatar
Sorry to hear about all this bro..
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-21-2011, 07:55 PM   #33
Reziel_1983
It'll all work out somehow. :P
Took out the engine today and miced(idk if that's how you would spell it) the crank and it is not a 10-10 crank as advertised... so it has been moving between the mains I guess causing the deep knock. The higher knock we think is the flywheel hitting the starter(I think that is what my dad told me, he's gonna put a new starter shim in it.) The red tube we're still not sure about, gonna put some fluid on the intake and see if it revs when we get the motor back in the truck.
Old 11-21-2011, 08:56 PM   #34
RFOX
RFOX's Avatar
sorry to hear of your bad luck I hope everything works better for you when you put it back in!
1997 CHEVY K3500 DUALLY 454 (SOLD)
1982 GMC JIMMY 2WD 350 (SOLD)
1994 TOYOTA 4X4 4 BANGER (SOLD)
1985 SILVERADO 2WD 400sb(SOLD)
1993 CREW DUALLY 500 CADILLAC (SOLD)
1989 C1500 GMC SEIRRA 350
RFOX is offline   Reply With Quote
Old 11-21-2011, 10:19 PM   #35
Reziel_1983
Thanks, me too. I guess stuff happens though, especially on your first time to do something. :P. Gotta learn somehow I guess.
Old 11-22-2011, 11:36 AM   #36
406 Q-ship
406 Q-ship's Avatar
Wait.......your saying the crank was turned more than .010 on the mains, do the spacer bearings match to the size of the crank journel (if the main is turned .020 under the crank the bearings should have .020 stamped in them). If the crank is moving foward eoungh to hit the starter nose you got much bigger problems, the thrust surfaces are beyond junk (this is the knocking). Sounds like to me that the engine builder may have thrown together junk and sold you a POS. I think your going to have to go through the engine and measure everything again!
BTW- there is no way a destroked 400 using a 350 crank, will have the rods hitting the oil pan. I use the oil pan off a 302 (1969) for my stock stroke 406 to have the windage tray and it does not hit.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-22-2011, 11:43 AM   #37
Reziel_1983
The crank was turned more than .010 on the mains, yes. But it was SUPPOSED to be turned .010, from what the person who sold the crank to me said. I think it was accidentally turned .020 instead, but we'll just have to check whenever we get it miced(I thought we miced it but we didn't.) The bearings are stamped .010. The bearings have a few scratches but we didn't run it long so the crank is still in good shape.
Old 11-22-2011, 11:44 AM   #38
Reziel_1983
And actually, we built the engine so it is our fault for not checking all the measurements... we just went by what the guy said that the crank was 10-10. It's not his fault really, it's the place he ordered it from's fault.
Old 11-22-2011, 05:36 PM   #39
Reziel_1983
The crank is a 10-20 crank... not 10-10. Going to order new main bearings today.
Old 11-23-2011, 08:01 PM   #40
Reziel_1983
Engine back in, noises are all gone, but that header tube is still glowing... sprayed fluid on the intake. Nothing...
Old 11-23-2011, 10:10 PM   #41
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Not normal....has to be something. You sure the valves are opening and closing fully... on both the intake and the exhaust valves... for that cylinder?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-23-2011, 11:08 PM   #42
Reziel_1983
Don't know how to tell if they are opening and closing all the way but I checked the rocker arms/pushrods and they all seem to work correctly. I even readjusted the valves... I guess it could be too.retarded timing but wouldn't that effect all cylinders rather than just one? Could the coating on the header just be thin?
Old 11-23-2011, 11:27 PM   #43
Reziel_1983
I wish I knew if it was doing this on the old engine... could tell if it's just a thin header tube then... it's a REALLY old header and isn't really a very quality one.
Old 11-23-2011, 11:39 PM   #44
stroker87
check a different pair of rockers or springs (intake/exhaust) rotate the engine and measure the highest height of each then check the pair that had the glowing header tube, I'm no pro but that should give you an idea if they are closing all the way
Old 11-23-2011, 11:41 PM   #45
Reziel_1983
Also... it does NOT glow while idling if that is helpful information... only when doing the cam break in. Could it just be because the headers are getting very hot and that particular tube is very thin?
Old 11-24-2011, 01:04 AM   #46
92GMCDriver
92GMCDriver's Avatar
i cant say this from any personal experiences but i have heard of headers glowing during cam break in. not just one tube i usually heard of the whole thing glowing rather than one tube because of timing issues or carb issues etc..
Cole.
1967 GMC c15
1991 k2500
2005 2500hd Duramax
92GMCDriver is offline   Reply With Quote
Old 11-24-2011, 01:36 AM   #47
INSIDIOUS '86
BTW- there is no way a destroked 400 using a 350 crank, will have the rods hitting the oil pan. I use the oil pan off a 302 (1969) for my stock stroke 406 to have the windage tray and it does not hit.[/QUOTE]
if i had mine i would show you lol
but it was a cheapo chrome pan, all i know is that stock origanals dont hit
maybe a valve is not sitting right on the seat, if the header is glowing its possible it may be a bent oor warped valve
Old 11-24-2011, 01:38 AM   #48
Reziel_1983
We had the oil pan off, nothing was hitting on anything, so I guess I got lucky . No more noises, it was all just that stupid crank not turned what it was supposed to be.
Old 11-24-2011, 02:07 AM   #49
68GMCCustom
pull the valve cover, start the motor and verify full up and down open/close of both valves (watching @ valve tips) for that cylinder.... vs the other 3 on that side... with it running. Your not going to make a big oil mess unless you rev it up. Some people prefer to adjust their valves this way (engine running) vs the standard method.
Kurt -
Old 11-24-2011, 02:07 AM   #50
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
This goes to show that spending an extra hour double and triple checking bearing clearances can save hours and hours of labor and heartache later. sorry you had to go through that, but at least you got it all worked out in the end! The header glow is another story. On your motor, it would have to be valvetrain related of something is wrong.
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
