#26 |
Re: Once was long, but now is short!
Trav looks good, can't wait to see more. Looks like a solid truck too. Keep us posted on the progress and updates. I cut mine down 2 years ago, did a straight cut with a diamond gusset on the back side, and I use it like a truck. Great work! I want one!
#27 |
Love bro, great job... Don't let them get ya up set...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#28 | |
#29 |
This is what 295,000 miles looks like in the ole 350.
#30 |
this type of thread is what makes this forum so great
#31 |
thats a long time on that v8, 150,000 is the usual cuttoff for a v8
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#32 | |
#33 |
misshape grape
This is the internet, an extension of the real world. Everyone is going to criticize. I for one like it, as it tends to lead to great discussions some may learn from, others may not.
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
#34 |
![]() Join Date: Apr 2009
I'm sorry if anyone posting on this thread has misunderstood MY intentions.
I personally did not post criticism , but a suggestion on how I might have done the modification differently. We are all here to learn from each other. So don't be so touchy about people making suggestions on your thread. One point to remember is that some people read these threads and do their own projects without ever commenting or posting their own information.. No one knows how good a welder you are or what projects you've done in the past, be open to learning something you don't know. I have learned a ton of info from this forum , as have you. If I feel like someone is posting info which is questionable , I will post my concerns. If this has offended you , I'm truly sorry. My concern is that everyone who dives into MAJOR frame modifications knows all the dangers. no reply needed Desert |
#35 |
misshape grape
Didn't offend me! I just saw somebody throw the crticize word out there haha
#36 | |
GoatLube Experss
![]() Join Date: Oct 2009
I'm just wait'n to see how you work out the brake line's and driveshaft, my Girlfriend bought me a short bed yesterday so I will defanently be do'n this to mine when I get home . aslo what are your plans for the fuel tanks ? look's good so far , keep the picture's come'n.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#37 |
Sorry Jit, my truck is in the body shop. when i get it back i will get some pics of the brake lines. The driveshaft was cut at the front of the second drive shaft next to the yoke that slips onto the front drive shaft. As far as the rear brake line goes, there is a coupling that joins two pieces of tubing right behind the cab. I removed the line between this coupling and the rear rubber hose, and installed a shorter line.
Posted via Mobile Device |
#38 |
I cheated on mine. I bought a burnt SWB truck, sold off more than enough pieces to get my money back and used the bed, brake line, driveshaft, and even the exhaust. Made it very simple, and the parts trucks are out there.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
#39 |
watchin....
1981 Chevy C30 440 Holmes 42K one owner miles |
#40 |
#41 |
I have one bent rail on my old blazer frame and am going to replace it with a section from the junk yard. I am going to do it just as you did. Cut a piece out of the old frame and shorten it's width and use it to box the section where I cut it. Grade eight bolts in all the spots where there were rivets. Diamond plate the outside ( maybe ) And double bevel the straight cut section. It is the steering box side so I am also going to cut out the steering box bolt in section and weld it to the new frame to strengthen that spot as well.. I used to work at a Diesel repair facility that did nothing but frame and axle and alignments on big trucks and that is how they did it. Sometimes they did not weld the frames when they were aluminum. In fact we had a really cool drill that clamped to the frame and would drill the holes by itself...Kinda like a core drill for cement.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#42 |
At the body shop.
![]() Works on these oughta be fine on a pickup truck.. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#43 |
I don't care how its welded I just wanna see the end product!
#44 |
Square
I gotta say. Just because its been done before doesn't mean its safe. Butt welding a structural piece like the frame of a truck like that is not normal practice. If a truck shop is doing this than they are not doing it properly. Anyone who does frame repair on a normal basis will tell you to z cut or something similar to give the most surface possible to weld and spread the pressure and heat. Even if it's a professional welder. Yes, the welds may be the new strongest part of the frame. but the heat generated by welding on the metal on the edge of the welds has been drastically compromised. If you have ever seen a weld break, you will notice it's not the weld itself It's the edge of the weld where the metal got extremely hot. Now add to that the weld is vertical in a high stress part of the frame and you are just asking for disaster. You don't need to haul anything to cause damage, a ruff bump in the road is gonna tear that frame in half. Blow me off and what i'm saying off if you want. But I would just cut your losses now and redo the job correctly.
Squarebody Syndicate |
#45 |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
I have welded (3rd generation welder, w/4+ decades under the welding hood) longitudinal steel a multiple of ways; butt seam, 45 deg angle, & staggered. If time is the driving force the butt weld is the preferred method, for strength it is hard to overtake the staggered weld for strength
While the butt weld will hold, the staggered method is preferred when joining parallel channels. The reason being is because of the chill lines on the welds, the point at which the “heat dissipation” from the weld ceases to migrate. |
#46 | |
Whenever I was involved with a large truck frame splice we always “gloved” the frame. Which is to say yes to a butt splice/weld, followed up by no less than at least a 36” piece (18” extending past on both sides of centerline = weld) of channel slightly larger than the original frame, then usually “Huck Riveted” to frame not welded. I would be interested in seeing the finished product |
#47 |
"usually “Huck Riveted” to frame not welded."
I also have experience with "Huck Rivets" I'm not sure 99% of the people here know what that is, I will tell you that once two pieces of metal are Huck riveted together , they are NEVER coming apart...LOL Desert |
#48 |
I used them to constuct the underframes for heavy rail cars (boxcars)
Never lossed a thumb, but I did lose more than one tip off my gloves... ![]() |
#49 | |
At the body shop.
275" i cant find any pics of the weld and glove though. ![]() Neat ride from another forum i frequent. Posted via Mobile Device
#50 |
Sweet looking Rig
Got to Love the BIG BOYS ![]() |
