Old 11-25-2011, 11:48 PM   #26
Doug_J
Doug_J's Avatar
Re: Riddle me this Mechanic Man?
I would think rings maybe time for a rebuild but I would try some lucas heavy duty oil stabilizer first.
Doug_J is offline   Reply With Quote
Old 11-26-2011, 05:32 AM   #27
INSIDIOUS '86
INSIDIOUS '86's Avatar
Originally Posted by savatreatabvr View Post
How can a ruptured fuel pump diaphragm also cause my problem?
it aligns the sun and planets such that the gravity pulls the oil out of the pan and into the cylinder, it also is known to make your engine not run and also induce the F*^k me!! frustration syndrome
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-26-2011, 11:39 AM   #28
savatreatabvr
savatreatabvr's Avatar
Yeah, I'm getting close to my boiling point, the levels of frustration I'm dealing with are epic! To top it off my exwife decided to move herself and her dog right on in with me and my daughter, thank God it's only temporary! I think I'm going to just pick up another Quadrajet, Holley or Edelbrock on Craigslist and hope for the best because I'm done! Here's a pic of my exwife though when she was modeling for ya'll to salivate over!
savatreatabvr is offline   Reply With Quote
Old 11-30-2011, 09:04 AM   #29
BigBlocksRule
I re-read the thread and I think RS72Z might be absolutely correct - if you have a loose rocker stud, it'll allow it to suck oil into the intake, and will be worse for a bit immediately after you add oil which you said had happened...
BigBlocksRule is offline   Reply With Quote
Old 11-30-2011, 09:57 AM   #30
savatreatabvr
You may be right but isn't a valve seal or guide more likely to go out than having a loose rocker arm stud? I'm off today so I'll pull the valve cover and check the studs and oil passages for blockage. Now shouldn't every rocker arm stud have around the same number of threads showing above the nut?
Old 11-30-2011, 10:15 AM   #31
Desert1957
Desert1957's Avatar
rocker stud holes on big blocks are dead end holes, meaning there is no vacuum at the bottom of the hole.
If you want an easy test try this , warm the engine to operating temp or a fair road test , pull the PCV valve out and away from the valve cover, hold the engine rpm at about 2000, watch and feel whats coming out of the valve cover grommet , if you can see oil vapors. Its motor time , if you can feel a steady flow of air pushing out of the hole its motor time.
Desert
Desert1957 is offline   Reply With Quote
Old 11-30-2011, 10:48 AM   #32
savatreatabvr
So there's no possible way a loose rocker arm stud could cause oil to leak into the cylinder, right and when you say "motor time", are you meaning time to rebuild or replace the motor?
Desert
Old 11-30-2011, 10:57 AM   #33
notyo_cheez
Cool Re: Riddle me this Mechanic Man?
Suction on the PCV is a good sign, as for the fouling plug(s) I would borrow a compression gauge and check the cylinders. That's just me.
I owned a '76 Monte Carlo a long time ago that would smoke a little after start-up, told it was the valve guides heading south. Never did anything about it, only drove it for about 3 years and ran okay and the plugs weren't abnormally fouled. Had an Olds 455 where the previous owner put Splitfire plugs in and a couple of them had anti-fouling caps on them, changed them all for platinums and ran much better. Didn't burn or leak oil at all, not sure why the no-fouls were there.
Try cheap and simple stuff first. Change your oil and substitue one quart of Marvel Mystery Oil for the crankcase oil, drive it normally and watch your levels. After a month do it again. It worked for my grandpa.
notyo_cheez is offline   Reply With Quote
Old 11-30-2011, 11:46 AM   #34
Desert1957
Desert1957's Avatar
Yes, without getting to technical, I will try to explain why 454's like to wear them selves out faster then any other V8 Chevy made.
It has to to with their stroke, 454's have a long crank stroke with makes great engine torque and power, but the dark side is the connecting rod through its cycle has a very bad angle at the piston pin causing severe side loading on the cylinder wall.
this side loading forces the piston up and out which makes for an extreme load on the outside of the cylinder wall. This is the reason they don't like to be revved up like a small block.
IMO a 454 can't go 200 or 300,000 miles like a 350 due to this design, without premature cylinder and piston ring problems.
If you are not sure on the history of your engine I would recommend a cylinder leak down test, this will tell you what percentage of leakage is going by the piston rings or worn cylinders, anything over 30% will causing oil consumption. Extreme oil usage and smoking.
Normal engine is 5-10% leakage.
If the leakage is low, look for things such as Valve Guide wear, leaking intake gaskets, fuel pump diaphragm etc.
I hope this was written so you can understand what you may be facing.
Hopefully its not bad news, If the engine is quiet,(no Knocking) there are a few things you can do.
1. use a heavier weight oil(not synthetic) Castrol high mileage
2. add a an of engine restore or what ever oil supplement you prefer
3. drive conservatively NO full throttle blast
4. run a hotter spark plug
one other problem that engine have burning oil causes detonation ( or pinging) under acceleration, this is also hard on the pistons.
Hope this helps.....
Desert
Old 11-30-2011, 03:11 PM   #35
ramz
ramz's Avatar
I had the same issue, I changed out the spark plugs and about 1month later it looked like your picture. It would run good until the spark plug clogged up again. One mechanic told me valve seal but I took to another mechanic and it replaced the EGR valve.
ramz is offline   Reply With Quote
Old 11-30-2011, 07:29 PM   #36
savatreatabvr
I always heard a 454 can't handle being redlined to many times, now it makes since! Yeah, I'm sure my 454 has high miles but it doesn't knock or ping and still seems pretty tight so I'll try thicker oil, maybe some Marv Myst oil and hotter plugs, I really appreciate your post, I learned alot and it was written well, thanks again!
Desert
Old 11-30-2011, 07:32 PM   #37
savatreatabvr
Excellent advice, thank you!
Old 11-30-2011, 07:34 PM   #38
savatreatabvr
Unfortunately I don't have a EGR valve, it's a 1973!
Old 11-30-2011, 07:40 PM   #39
savatreatabvr
I also noticed when I pulled the fouled plug there was oil on the outside of the plug hole. Could the piston be blowing oil past the threads of the spark plug or the head be cracked right at the spark plug threads, I know it's far fetched but I thought I'd ask?
Old 11-30-2011, 07:42 PM   #40
tucsonjwt
In my experience, wet oil on plugs means bad rings. Any blue smoke out the tailpipe? There should be some?
tucsonjwt is offline   Reply With Quote
Old 12-01-2011, 09:42 AM   #41
savatreatabvr
I must not have been clear, the oil is on the "spark plug threads" and the "outside" of the engine. I guess I kinda answered my own question, common since says any liquid will take the path of least resistance especially under pressure.
Old 12-01-2011, 10:33 AM   #42
raws67
raws67's Avatar
Have you tried hooking up a vacum gauge to see what kind of readings you are getting?
raws67 is offline   Reply With Quote
Old 12-01-2011, 06:26 PM   #43
savatreatabvr
No I haven't, that's next on my agenda! Do I cap off the vacuum advance while hooking up the vacuum gauge?
Old 12-01-2011, 07:59 PM   #44
raws67
raws67's Avatar
I dont really think it will matter if you do or not just as long as you are getting vacum from the manifold. Unported vacum at least below the throttle blades. Check this site out I think it might help with your checks. http://www.secondchancegarage.com/public/186.cfm
Old 12-01-2011, 08:05 PM   #45
savatreatabvr
Thanks raws67, the link you posted is quite informative, it's raining here in Phx right now so I'll jump on it tomorrow morning!
Old 12-01-2011, 08:25 PM   #46
BMERDOC
BMERDOC's Avatar
It is oil consumption. Your next step is a compression and a leak down test. If the valve seals are rotten that would be your cheapest resolution. If the valve seal fix it and your problem returns soon (depends on how much its driven) you have bad valve guides. Other than that you have bad rings. The tests can confirm where the problem lies.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-01-2011, 08:27 PM   #47
csb#356
Why not just do a compression test on this engine. I see you're going as far as pulling valve covers and adjusting valves and are even considering replacing stems seals. That seems crazy without first doing the easiest test there is. If you find its low then find out where its leaking and know for sure. If its not low on compression and you're burning oil theres only one really logical place. down the valve guides. And I don't believe big blocks have replaceable valve guides. They're cast into the block and have to be bored oversize. Also the lifters on your engine are probably hydraulic meaning you don't have to adjust them
csb#356 is offline   Reply With Quote
Old 12-01-2011, 08:28 PM   #48
raws67
raws67's Avatar
No Problem!
Ive used this methood before and it was right on the money with a valve problem I had. One other thing that makes me interested is how tight that valve was that you were talking about. That almost sounds like the valve sunk in to the head or a po who didnt know what they were doing over adjusted. Either way you did say that that cylinder seems to run fine. Let us know what you come up with.
Old 12-02-2011, 12:39 AM   #49
savatreatabvr
I did a compression test a while back and 2 cylinders were at about 90lbs, the rest about 110-120lbs.
Old 12-02-2011, 12:41 AM   #50
savatreatabvr
Don't have to adjust hydraulic lifters?
