Old 11-28-2011, 11:42 PM   #26
farmtrucks
farmtrucks's Avatar
Re: convertor help
It is splined to the end
farmtrucks is offline   Reply With Quote
Old 11-29-2011, 01:59 AM   #27
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Re: convertor help
NOW.......... we have a problem Houston......
Because you are dealing with a late, late model 4L60E, you will need a custom converter, different flexplate, or have someone install an earlier input shaft in the trans, I think....... If you were dealing with an earlier model 4L60E, you would of had no problems. I am going to dig through some stock converter books and see if I can come up with one that will fit your bill, I am thinking of one in particular but I have to check the specifics of it.
I will keep ya posted!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 11-29-2011, 07:45 AM   #28
farmtrucks
farmtrucks's Avatar
Re: convertor help
My bargain isn't turning out to be a bargain
Old 11-29-2011, 10:30 AM   #29
schwoch1
schwoch1's Avatar
Re: convertor help
Been there, done that. Most cost effective (cheapest) way for you to get out of this is get another transmission or a swap converter. I am still digging to see if there is an oem converter that will work.
Mike
Old 11-29-2011, 01:18 PM   #30
farmtrucks
farmtrucks's Avatar
Re: convertor help
Just curious -- what would be the difference (distance) between my longer crank flange + flexplate compared to the regular 6.0 crank + factory spacer + flexplate.
*** also found 2 - 4l80e
1 - 00' OBCP w/original converter
1 - 06' MPJ w/original converter
will both these
what is wiring plug difference
what is converter difference
Old 11-29-2011, 01:54 PM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: convertor help
ooooh ooooooh now I like were this is going... railroading someone in to a 4l80e YES.
The first one is a 4x2 trans out of a 3500 truck, this is basically what I'm using. The wiring on these SHOULD both be the same (I had my harness made for a 4l80e without telling him what year), but will require an extra VSS (has a different name but its a vss type sensor) than the 4l60e wiring.
The 4l80e is a nice place to go, stock it holds these motors no problem.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-01-2011, 07:34 AM   #32
farmtrucks
farmtrucks's Avatar
Re: convertor help
Any more suggestions?
Old 12-01-2011, 02:59 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: convertor help
just sell the 4l60e you have and grab one of those 4l80e. Even in stock form it should hold without much of an issue.
I see it this way'
4l60e (free) + trans upgrades shift kit, servo etc (250-400$), + custom converter ($900) = $12-1400
OR
Driving condition 4l80e (~$500) + extra vss plug ($15) = $515 Leaving you with 5-700 in cash left over, which you can use to get an upgraded stall converter if you want, or use a stock verter and save the extra cash.
Old 12-01-2011, 09:52 PM   #34
clinebarger
Re: convertor help
You can swap the Input drum & Stator support shaft for "298mm" versions & run a 98 & up 4.3L converter, Redrill the flexplate......Problem solved.
clinebarger is offline   Reply With Quote
Old 12-02-2011, 07:43 AM   #35
farmtrucks
farmtrucks's Avatar
Re: convertor help
Thanks guys for all the help and education.
I got a 5.3 laying in the floor -- I'm just gonna use it in front of the 4l60
I'll get a 4l80 to go with the 6.0 for a later build
Old 12-02-2011, 10:23 AM   #36
schwoch1
schwoch1's Avatar
Re: convertor help
THat would be the easiest for you at the moment!
Sorry I could not get you out of this one!!!
Mike
