12-03-2011, 12:19 AM | #26 |
Re: Got Me some Camel Humps!!
Get em done right they are a good set of heads.....port match, unshroud the exhaust valve wall and match all valve heights......( change out seats and valves that are sunk in heads). Mine are on a 406 smblk.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
12-03-2011, 05:53 PM | #27 |
I think I will go with the 268H cam from comp. will it work fine with stock springs on my camel humps?? Assuming they are stock springs.
Posted via Mobile Device |
12-04-2011, 01:18 AM | #28 |
60-66 Nut
They should work, but it is always recommended to check for coil bind and retainer to valve stem/seal clearence, when upgrading a cam.
12-04-2011, 06:50 AM | #29 |
I agree with Captain... always double check. As for cam another thought would be the 279 thumper series from comp cams. It is designed to give ya a racier idle and a decent performance boost with out all the hassle of a large cam. Not downing the 268H cam, as it is a fine little cam, but it is 30 year old tech. The newer designed cam profiles can accomplish a lot more with alot less motor. Just a thought.
01-12-2016, 09:58 PM | #30 | |
But Found Her 25yrs Later!
What kind of heads are these on my 283?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-13-2016, 02:07 AM | #31 |
60-66 Nut
The best thing to do is remove a valve cover and get the casting number. All I can tell you from the pics is that they are a '68 and newer head.
01-13-2016, 09:49 AM | #32 |
If it were me when ever doing a cam swap . I would always buy the cams valve Springs to match said cam as well. It is a peace of mind that is money well invested in your build ... so if you can buy a full cam and lifter set with matching valve Springs. . Also something I have not seen anyone ask you or mention to you is . Do you have power brakes ? Because if you do and you get a cam with a big lope sound that means way less vacuum which means poor brakes if they are power assist. For that you will also want to buy a vacuum can from summit so remember more lope / thump means less ability to stop at lights . Without running a vacuum can .. Happy Truckin
01-13-2016, 11:01 AM | #33 |
Those look like #416 305 heads.Best to check casting # to be sure tho.If so,they are the 2nd best 305 head available after the L30/305 Vortec head.Casting #059.
Actually,it appears after looking at both pictures that you have 2 different heads. Last edited by jokerz71; 01-13-2016 at 11:09 AM. |
01-13-2016, 11:08 AM | #34 |
FWIW,the humps were great heads back in the day & if you're trying be period correct,that's 1 thing,but,if you are looking for performance & efficiency,that's a whole different thing.
A set of L31 Vortec heads,or,any of the similar fastburn heads will be an instant 30 HP over any of the humps.You can make more power with less cam & have much better resistance against detonation. Unless they have had hardened seats installed,a performance type cam & springs can beat the soft seats out of the head in no time flat. By the time you have seats installed,install screw in studs & a valve job,you will have a lot of money tied up in a set 50 something year old heads that will be less powerful & efficient. |
01-13-2016, 12:39 PM | #35 |
I'm trying to find the other post - I think by you - where you say something about a good newer head that works good on a 283.
01-13-2016, 05:12 PM | #36 | |
Found your other post.
01-14-2016, 02:37 PM | #37 |
Did anyone catch the age of the thread?
Anthony |
01-14-2016, 08:33 PM | #38 |
the age dont matter to me of this post . because since im still fairly new to the site this post has some good info in it that i my self did not know and now are better equipped when i do my build .. like a for instance the alternator bracket system that does not bolt on the heads . i did not know existed . so im glad that who ever made a comment on this post the site made it look as a new one . or ide never have bumped into this . and got good info
01-14-2016, 09:04 PM | #39 |
I have a lot of old books that still have good information.
An old thread on camel humps or a new thread on camel humps. Same information.
