#26 |
Re: My Swap Plan (comments welcome)
I want to do a 243/Cathedral port vs a LS3/retangular port comparison but the problem is the LS3 style really needs a different cam too so then you run into lots of variables trying to compare the 2 on the dyno and track/MPH.
As I have mentioned before, 2 GTOs with nearly the same mods making nearly the same power at the wheels. 243 headed GTO was showing 2+MPH in the 1/4 on same day same track. One thing that lots of people do not factor in with the LS3/L92 heads which Clown mentions is the intake design is different plus factor in the rocker arms that are needed, it adds into the cost if you already have cathedral heads. Just plan it all out before you move forward but the motors can make power and useable power in all the RPM ranges.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
#27 |
Collector of Projects
Also keep in mind your control system. Im looking at a 6.0L but no harness... I priced out Painless at about $1400 and Howell at about $1100. This is all new pieces, wire and delphi connectors, new TAC moduel and pedal.
If you can get the original and UNCUT harness you will be $$ ahead. You can either modify it yourself or have it done. You should also get the ECM, Pedal and TAC module from the same vehicle if possible.... |
#28 |
So if I've got this right, a 6.0L LQ4/9 complete w/ harness, ECU, pedal, and TAC module is where I should start. Adding the L92 heads & LS3 intake, 92mm TB, and a mild cam should take care of the top end. Make a determination on accessories (Vette or Truck.) All of this should button up to a stock 4L80e, and get me to around 450+/- rwhp? Sold!
#29 |
I just got off the phone with my DMV. They require emissions equipment from the same year as the motor, not the vehicle. So I need CATs and the EVAP system to be functional...
#30 |
meowMEOWmeowMEOW
do they do visual inspections?
WI has similar requirements but no visual inspection, as long as you don't throw codes, they don't care.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#31 | |
http://www.psiconversion.com/
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
#32 |
Guys & Gals,
You'll be able to follow this build in the projects/builds section soon... likely in the LSx swappers sub-forum. Thanks for all the input, but I've pretty much got my plan thus far. -shannon |
#33 | |
The 4l80e is a great choice let me know how she fit's. I'm in the middle of tracking down a trans with out breaking the bank. I really have a feeling Im just going to go to the yard and find a 4l65e out of a trailblazer. From what knowledge I have of using the truck drive system is the car intake inlet will hit the alternator. It can be moved but that's another can of worms The Vette would be a great choice but it is around $700 from GM. It boils down to what intake you choose. Great stuff so far
Chuck D 66 C10 LS6/4L65e |
