12-12-2011, 05:16 PM | #26 | |
Still Learning
Re: Bed too high? What did I do wrong?
12-12-2011, 05:58 PM | #27 |
here is a good reference for the cab mounts and measurements. It was posted by Bruce in his build. http://67-72chevytrucks.com/vboard/s...318544&page=18
Hope he doesn't mind but here is the picture, it really helped me out. |
12-12-2011, 08:50 PM | #28 |
454 MAKES IT ROAR
A pic of my rear mounts after renewal. Your upper bushing looks squished.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
12-12-2011, 08:55 PM | #29 | |
Junior Member
I just snugged mine down without squishing them. I got them from Classic Parts and they look like yours.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
12-12-2011, 09:20 PM | #30 |
laying low
You don't suppose he has the front and rear cushions swapped do you? Would make sense since they are different thickness. The rear one is thicker.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-12-2011, 09:29 PM | #31 |
My front and rear mounts:
12-12-2011, 09:30 PM | #32 |
Hey - maybe you're supposed to inflate it?
12-13-2011, 12:07 AM | #33 |
Junior Member
Thanks for all your input guys! I REALLY appreciate it. Started to quote individuals but most suggest cab bushings. So...
This is the cab bushing set I installed: http://www.summitracing.com/parts/ENS-3-4108G/ Instructions list a 0.1" taller sleeve in the rear cab position. Poly bushing thicknesses as installed using dial calipers. Core Support - 0.750 Front cab - 1.01 Rear cab - 0.875 I have the taller (by 1/8") bushing in the front cab position. Winner? More pix with measuring tape:
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle Last edited by stomper; 12-13-2011 at 04:48 PM. |
12-13-2011, 09:29 AM | #34 | |
454 MAKES IT ROAR
And with air bags that would be the complete air system.
12-18-2011, 10:26 AM | #35 |
Hey eightbanger,i am is the assembly stage (mock up) of my 69/72super/ls1,researching
bed assembly,came across your dilema.on your first post you show 5 pics of your bed.on the fourth pic of your post is the front bed perch,i am pretty sure your perch is on the frame backwards.the angle is down towards the cab.It should be level with your rear perch if you straight edge it the length of the frame rail.By reversing it you should gain some or all of the lowering distance you nedd to align the bed to the cab. |
12-18-2011, 10:34 AM | #36 | |
454 MAKES IT ROAR
12-18-2011, 11:23 AM | #37 | |
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
12-18-2011, 11:37 AM | #38 |
laying low
Yeah, camera angle on that.
12-18-2011, 06:57 PM | #39 |
Hey stomper,i sent this earlier to the wrong person.from what i can see in your pics your front bed rail support perches seem to be installed backwards.i was just checking mine before i bolted them in, i positioned them reversed and it appears that it would lift the front of the bed up about the distance your having a problem with.unless it's one of those "obstical illusions"
badwrench |
12-18-2011, 08:05 PM | #40 |
Hey Stomper, I'm jsut catching back up - wondering if you got this fixed. I see you've posted a few more pics since last time I checked - and it appears to me that the passenger side gap between the bed and cab is extremely small... With all the other stuff going on, I'm curious how the truck was before you disassembled? Did everything appear level then? Asking because that would dispel the bent frame idea - which seems like a possibility if nothing else is making sense. Regardless, I think that if you've eliminated any mis-steps in the re-assembly process, shimming the cab may be the best route. Have you compared all the cab mounts and rubber to confirm they are same size - and looked at the bed mounts to do the same. Personally, I would install small rubber shim on bed, then adjust cab with shims to square it up. Not sure what else to do.
12-18-2011, 08:06 PM | #41 | |
12-18-2011, 08:10 PM | #42 |
Factory rivots--bracket is right............jim
12-18-2011, 08:14 PM | #43 |
my 72k10 the po put new cab mounts on had to do some shiming i have seen them come from the factory with them in there too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-18-2011, 08:14 PM | #44 |
Still Learning
So have we found the solution to this problem yet? any updates?
12-19-2011, 03:37 PM | #45 |
Junior Member
I have been working on it some. Sorry no pix right now. (Getting ready for Christmas) It's going to end up being a number of little things. So far I have:
Swapped the bushings front-to-back into correct locations. This raised the back of the cab about 1/8"+. I put an 1/8" shim in the rear bushing location. This gave me another 1/8" I probably got ahead of myself because the bed didn't have the wood in the back corners. Putting that in tilted the bed sides forward a little. This didn't lower the front of the bed but it closes the gap between the cab and the top of the bed front panel. I loosened all the bolts in the bed floor and pushed/pulled/bumped the pieces to get the bed closer to the cab. A new problem I have now: The panel gap between the back of the front fender and the front of the door is wide at the bottom. I'm hoping shims in the forward cab mount stack will take care of this. Mak191: Thanks ALOT for the illustration and measurements. Looks like the rubber bushings are 1/4" (AFT) and 3/8" (FWD) taller than the poly bushings. So... shimming the cab higher is likely the real solution for my problem. I really don't like it that I'm having to make up the difference with shims. Seems like they should make the poly bushings taller.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
