Old 12-22-2011, 02:21 PM   #26
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: single vs double wall top
Originally Posted by Firebirdjones View Post
That's why mine stays on. When I want wind on my head I jump in the camaro and just push a button
WHen I want wind in my face I let the dog drive
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-22-2011, 02:23 PM   #27
richard2717
I would imagine the only time my top will come off is when I pull it later this year to assess any damage that may be under it. THere does not appear to be but I want to check and be sure.
Hope everyone has a wonderful Christmas holiday
Members I have met.
Old 12-24-2011, 03:09 PM   #28
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I'm I the only one that can remove their top buy themselves?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 12-24-2011, 04:02 PM   #29
Firebirdjones
Probably
I have an overhead crane as well as a 2 post car lift. Both could be used to remove my top, (probably by myself) I just don't care to do it
Firebirdjones is offline   Reply With Quote
Old 09-10-2012, 12:57 PM   #30
GuyO
GuyO's Avatar
Red72, how do you do it by yourself? My double wall is very heavy and I am trying to figure out a way to rig up a top puller?
GuyO is offline   Reply With Quote
Old 09-10-2012, 02:00 PM   #31
truckster
truckster's Avatar
I have a low shed with a flat roof about 12" higher than the base of my top. I just back up to the shed, unbolt the top, get in the middle inside, and lift up. Then I slide it on some 2X4s laid crossways on the shed roof. It's not too bad if you use your legs to lift.
truckster is offline   Reply With Quote
Old 09-10-2012, 02:19 PM   #32
tubbedII
needs more $$$
tubbedII's Avatar
I'm planning on getting a couple of 2x4's to run across the width of the top with enough room on the outside to put in circle eye bolts into it facing the ceiling. Then using 4 ratchet straps (one on each corner) to lift it off and tuck it up into the roof of my garage. I've seen this done a few times, but I have a question for anyone out there that might know.
The roof of my garage is covered by sheet rock...would some lag circle eye bolts be sufficient to hold the weight of the top if put in straight up?
I'm sure a better way would be to cut a hole in the sheet rock for the straps to go through and put the bolts in through the side of the beams, but I rent and would rather not do that unless is absolutely necessary. I'm not in construction so I don't know what type of capacity these things can handle...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-11-2012, 06:45 AM   #33
panhead59
just screw the eye bolts into a stud. That'll hold a top for sure.
panhead59 is offline   Reply With Quote
Old 09-11-2012, 08:13 AM   #34
Bentblazer
Bentblazer's Avatar
In the back ground is what I used to store my double wall, poles were wide enough to back into with the front 4x4 removed, then I would get into the bed and use my back against the top and lift enough to walk back and set rear end of top onto back 4x4 then set front 4x4 on bed rails and slide onto bolts in poles, kinda looked like a monkey screwing a elephant but it worked http://67-72chevytrucks.com/vboard/a...0&d=1312287356
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 09-11-2012, 12:33 PM   #35
tubbedII
needs more $$$
tubbedII's Avatar
Thanks for the confirmation!
Hilarious!
1970 2wd Blazer
Old 09-11-2012, 10:23 PM   #36
Thelast 72k5
So that is what all those extra holes are for in mine...... now i know.
Thelast 72k5 is offline   Reply With Quote
Old 05-25-2013, 02:28 PM   #37
RED72blazer
urban fourwheelin
unbolt it. remove rear seat and tail gate. brace back against underside of top. lift with legs. get to end of bed. slip down to ground. military press top and walk to waiting tall saw horses.
Old 12-05-2013, 07:32 PM   #38
cst 72 blazer
cst 72 blazer's Avatar
im going against the grain on the weight theory .i traded a man in NC today my double wall for his single wall top.and we had both agreed right away that the single wall was quite a bit more heavy.we couldnt beleave the difference.we had the hatch removed on both for the move as well.as i compared it with my other double wall when i got home it seems the fiberglass is much more thick where the hatch arms and hatch lock bolts are.has anybody else noticed this? or do i need get some rest after that long drive.
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 12-06-2013, 05:29 PM   #39
mtully79
mtully79's Avatar
After you military press the top over to the tall saw horses be sure to go back and pick up your nuts....
mtully79 is offline   Reply With Quote
Old 12-07-2013, 01:46 AM   #40
Chulisohombre
Chulisohombre's Avatar
If you four by your blazer or Plan to I've seen single wall tops break when the truck Is Flexed Out. My double ive had no problems Except the cage bolts have broken off inside the top a couple on each side that I Need to fix at some Point. I also had my top off using the eye bolts And four ratchet straps to lift it. 2x4 slides Under top and lift slowly moving from one corner to the next to lift it Slowly a couple inches Off the body. Make sure the upper eyelet bolts are into
A stud up top and you will Be fine. The top weights around 350 pounds or So but I've gotten it Off with three strong guys working together. Not Ideal but it worked.
Chulisohombre is offline   Reply With Quote
Old 12-09-2013, 03:48 PM   #41
rayray767
Weight on the single wall vs double wall .. Their both heavy and hard to deal with yes the single is easy to bolt down with out the stripping that can happen to the double wall . Still take some effect to put them on and off.
rayray767 is offline   Reply With Quote
