Old 07-15-2012, 11:29 PM   #26
hahjoel
Re: 1969 GMC Long Bed
I got my new frame; everything stripped and finished mocking up all the suspension. I am very happy with the new frame, especially since the last one was junk. Just wish I would have bought a better condition truck to begin with. Oh well.
I was originally going to go with a PB rear kit, but I think I want the box intact, so I will use this and if I get tired of it, I will order the PB mild kit for the rear. I must say, though after dealing with Porterbuilt, the CPP Notches are complete **** in comparison, no quality what so ever, the holes don’t line up, the bends don’t line up. Good thing I have a torch to persuade it. Here are some pics.
69 GMC Long Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=500284
hahjoel is offline   Reply With Quote
Old 04-01-2013, 10:37 PM   #27
hahjoel
It been a while since I post anything, so here are some updates. I have most of my floor repairs done. Just need to finish off my cab corners and time for paint. I have quite decided If I want to fully paint it or make it have a patina look.
69 GMC Long Bed
Old 04-01-2013, 10:40 PM   #28
hahjoel
I installed my PB hinges and recently started welding in patches to smooth the firewall.
69 GMC Long Bed
Old 04-01-2013, 10:43 PM   #29
hahjoel
I am wondering what tire and rim size I can run with my PB drop member. does anyone know what the max rim or tire size is? I think the stockers that I have on there are 15" 225 70r. I think the tire height was about 28" and I only have about 1/2" of clearance at full drop.
69 GMC Long Bed
Old 04-02-2013, 09:09 PM   #30
thelonerife
thelonerife's Avatar
Nice job! I have a long bed too and am interested in the stance yours will have when the bodies all together. I'll keep watching.
thelonerife is offline   Reply With Quote
Old 04-02-2013, 10:39 PM   #31
hahjoel
Thanks, it sits on the ground in the front. A little higher in the back than I like. But I want to have a full box to use. And the air ride will make it ride nice.
69 GMC Long Bed
Old 05-20-2013, 07:29 PM   #32
hahjoel
Finally got my firewall done, I don't have the final pictures up on here yet. but here are few. sucks because I didn't have large enough pieces of sheet metal to work with. A little grinding and bondo should take care of the most of it. A lot of it will be hidden by the master cylinder and the column poking out of it.
Another pic of my brakes
69 GMC Long Bed
Old 05-29-2013, 08:56 PM   #33
hahjoel
I was able to get the cab corners in last week. there is a little grinding left, but the majority of it is complete.
69 GMC Long Bed
Old 06-03-2013, 05:49 PM   #34
hahjoel
I had some issues the other night uploading pictures. I was able to get my cab corners in and welded up. I was able to get them mostly ground down. My floors all finished and everything is welded and tacked into place. its finally coming along.
69 GMC Long Bed
Old 06-03-2013, 05:54 PM   #35
hahjoel
I found a set of 68 Chevy fenders thanks to a member here in Minnesota. They were even the correct color! I blasted them quickly to get the paint mostly removed. overall they are better than what I had before. Just a few dents to repair and I may need to replace the lower quarter on the passenger side.
69 GMC Long Bed
Old 06-03-2013, 05:58 PM   #36
hahjoel
I put the hood on to make sure everything lines up. and it does mostly. Just a few modifications and they should be a good fit. I had to replace a portion of steel on passenger side of the radiator support. It appears that the battery was leaking and corroded it badly.
69 GMC Long Bed
Old 06-03-2013, 06:06 PM   #37
hahjoel
I also didn't like the way the firewall turned out, so I decided to get some 1/8 steel plate and cut what I did out and replace it. I have the drivers side in. When I get more time I will get the passenger side in as well and take some more pictures. Hopefully by the end of July I should have the truck in primer.
69 GMC Long Bed
Old 06-03-2013, 06:23 PM   #38
fastnlow
fastnlow's Avatar
it's looking good!
fastnlow is offline   Reply With Quote
Old 06-16-2013, 11:45 AM   #39
hahjoel
I finally had some time this weekend. I redid the firewall with 3/16 plate and now there is no more warping. Just need to finish the welding the top filler plate around the wire channel and it shall be done. I also welded up a battery box as well. I may make a cover for it. I haven't decided though.
69 GMC Long Bed
Old 08-11-2013, 11:12 PM   #40
hahjoel
I finally had some time do work on the truck. I welded in the step notches and fabricated a the bridge. I also welded in the bag brackets and mounted the bags and tested. Its too bad my welding sucks, I'll most likely grind down the welds so no sees them lol
69 GMC Long Bed
Old 08-11-2013, 11:15 PM   #41
hahjoel
and here are some more shots of the bridge assembly.
69 GMC Long Bed
