Old 01-30-2012, 12:54 AM   #26
rmvlt1100
rmvlt1100's Avatar
Re: 1965 C-10 LS build
Originally Posted by 66ChevyMax View Post
Shon has them in stock, check the thread below, he has set up a group purchase to help with the price.
http://67-72chevytrucks.com/vboard/s...d.php?t=500520
My engine adapter are not adjustable, that may be the next step if the DT coming don't work out.
Thanks for the info ChevyMax. If the Hooker Headers don't work I will have to dig deep into the loose change jar for the extra money for the DT headers. Again your build is looking good. Have a good night.
rmvlt1100 is offline   Reply With Quote
Old 01-31-2012, 10:12 PM   #27
66ChevyMax
66ChevyMax's Avatar
Here's a pic of the DT, they are nice.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 01-31-2012, 10:44 PM   #28
rmvlt1100
rmvlt1100's Avatar
They look good on there. How did they fit around the CPP motor perches?
I tried the set of headers from a 69 Camaro, they didn't fit very good. Looks like I am going to have to buy that style. Are they long tube?
Old 01-31-2012, 10:49 PM   #29
66ChevyMax
66ChevyMax's Avatar
They just cleared, the are not long tube they are mid.
Craig
Old 01-31-2012, 10:58 PM   #30
rmvlt1100
rmvlt1100's Avatar
A little update on the build. My gas tank came in and got it put in. I gave the wiring a little break and decided to move the battery to the drivers side. I cut in a box in the inner fender near the core support. I'm going to run the cold air intake and filter to the passenger side where the factory battery was located. I finished up the metal work on the cab and bed sides going to ship the bed sides and the hood off to the body shop on Thursday. I wanted to take a few pictures but the camera battery was dead. Will try to post some pictures on Thursday morning, after work. I sold the old motor and trans yesterday so now have some extra money for new parts.
Old 01-31-2012, 11:07 PM   #31
rmvlt1100
rmvlt1100's Avatar
Post Re: 1965 C-10 LS build
They look good. Are these the ones that Shon has in stock?
Old 02-02-2012, 11:39 PM   #32
rmvlt1100
rmvlt1100's Avatar
I was looking at different motor mount adapters and found that the ones that I used that were mark as for install the engine in the stock location (Transdapt Brand) moved the engine forward almost 2 inches. I found a set of Hooker Headers motor mount adapters that did put the engine in the stock location. About 2 inches back from the other brand.
This should help a little with headers fitting. It also gives me a little more room between the radiator and the water pump pulley.
Below is a couple of picture of where I move the battery to. My welding skills aren't as good as alot of people but the grinder will clean them up. I also posted a couple of pictures of the gas tank.
USPS dropped off some more parts the past couple of days. I delievered my bed side and the hood to a body guy today. Should have them back in a couple of weeks nice and straight and ready for some blocking and more priming.
Has anyone out there ever used Hot Rod Flatz paint? Wondering how it sprayed out? Hopoe everybody has a good night.
Old 02-03-2012, 10:49 AM   #33
66ChevyMax
66ChevyMax's Avatar
Yes, and with your current engine location I think you will be good to go.
Craig
Old 02-03-2012, 11:10 PM   #34
rmvlt1100
rmvlt1100's Avatar
Thanks for the info. Will have to save up and work a little O.T. so I can order a set.
Thanks again,
Robert
Old 02-05-2012, 09:40 AM   #35
flips72
flips72's Avatar
just checked your thread, awesome build. i love the ls motors and the are capable of some serious horsepower,since you have already cut down your inner fender that would be a great place for a turbo
flips72 is offline   Reply With Quote
Old 02-09-2012, 12:26 AM   #36
rmvlt1100
rmvlt1100's Avatar
Thanks for looking at the build. LS engines are a new adventure for me. Yea a turbo would look good right there.
Old 02-09-2012, 04:47 PM   #37
McMurphy
McMurphy's Avatar
Man that wiring is amazing!
You would have to be really good at puzzles I think...
Your build sure is coming along nice though, cant wait to see how it all turns out!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-09-2012, 04:50 PM   #38
OC 72
OC 72's Avatar
She's going to be a beauty!!
OC 72 is offline   Reply With Quote
Old 02-10-2012, 12:21 AM   #39
rmvlt1100
rmvlt1100's Avatar
Sargent McMurphy, thanks for the great comments and I can't wait till its done, I just need to be patient and take it one step at a time.
Old 02-10-2012, 12:31 AM   #40
rmvlt1100
rmvlt1100's Avatar
Thanks for the checking out my build. I just looked at your post. Your truck looks outstanding. Very clean and detailed rebuild. The tire combination is great. Can you tell me what size wheels and tire them are? Also what air ride system did you use? How do you like that system? I was looking at a Ride Tech system but there quite expensive. Thanks again, Robert
Old 02-29-2012, 10:33 PM   #41
rmvlt1100
rmvlt1100's Avatar
Haven't posted much about the build, but I did got a few things done. I finished up the passanger side rocker and got it primed. I hung the door, inner and outer fender. I had to take off a couple of the braces off the inner fender to get it to line up. I starting to find out that this after market stuff doesn't line up very good. I have a little work to do on the door gaps as well. I finished the drive by wire pedal and got it mounted. I purchase a power window kit from AutoLoc and attempted to install it with no luck. The kit I bought was a universal kit for a flat window and I think I will return it or put it on E-Bay and buy a kit made for the truck.
I have been wanting to air bag the truck and I decided to do it know rather then when it painted. I ordered bags, brackets and fittings from AVS and a "C-Notch" kit from CPP. The bed and the hood should be back soon and will send the rest of the truck to the body shop after that.
[IMG][/IMG]
Thanks for looking at my build and have a great night.
Old 03-01-2012, 10:34 AM   #42
jimmythompson1964
jimmythompson1964's Avatar
Looks like a fun build, I think LS power is the way to go if you can afford to make the leap.
jimmythompson1964 is offline   Reply With Quote
Old 03-01-2012, 05:03 PM   #43
DLOE65
DLOE65's Avatar
Looking really good! Keep it up!
DLOE65 is offline   Reply With Quote
Old 03-01-2012, 05:10 PM   #44
McMurphy
McMurphy's Avatar
that repop fander looks good!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-01-2012, 07:13 PM   #45
rmvlt1100
rmvlt1100's Avatar
Your truck build is looks great. It's neat that your using the 6 cylinder engine. I like the color of the motor. The air valves tht you have look nice and compact and a clean look set up. I may have to look into something like that when I'm ready to get mine. Again very neat build you have going there.
Old 03-01-2012, 07:31 PM   #46
rmvlt1100
rmvlt1100's Avatar
Jimmy thanks, Its been fun most of the time. The rocker panel on the passanger side was a son of b****. When you do your drivers side make sure the door is on before you do any welding. I learned the hard way. I didn't plan on the LS motor but the motor that came with the truck needed to be rebuilt so thats when I went with the LS engine. I didn't think I would cost this much more than rebuilding the engine that came with the truck. But I was wrong. The engine was cheap but everything else to make it work is the money issue. Those AFR heads you have are wonderful. I had a set of them on my 383 that was in my chevelle and those heads completely changed how the engine ran. It's crazy how much more they flow comparied to other heads. Your build looks good and keep up the good work.
Old 03-02-2012, 01:51 PM   #47
jimmydean
jimmydean's Avatar
I wanted an LS so bad, but couldn't justify the cost. For $500 more than the LS I got a whole LT1 C4.
The LS is SO worth it and your truck will love you for it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-02-2012, 02:54 PM   #48
Notch1988
Notch1988's Avatar
Subscribed. Great build, I'm always amazed by guys, like yourself, that can take on so much of a build at one time and get things done. I'd be there for years trying to restore a chassis, body and install an LS drivetrain. Great job!
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 03-02-2012, 06:19 PM   #49
rmvlt1100
rmvlt1100's Avatar
Notch1988, thanks for the kind words. It's been fun so for and very challenging at times. I like how your build is coming. Thats a nice setup that you got for your suspension. I was looking at that type before I went with the LS motor and now it has cost a lot extra then I thought it would. But I think the LS motor will pay off in the lone run. Have a good day.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
Old 03-08-2012, 11:47 AM   #50
flips72
flips72's Avatar
truck is coming along nicely, door and fender gaps look good, your going to have a sweet ride very soon at this rate.
