Old 02-02-2012, 10:04 AM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater doesn't work
yup should get some psst noise
air feed from the back
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2012, 01:37 PM   #27
crazeetxn
crazeetxn's Avatar
A LOT OF INFO HERE!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=460942
I have an '86 with A/C. Hardly any vac lines. I have a line through the firewall straight to the controller (above the radio). I run that line from my carb, through the firewall. Replaced the actuators, and presto, air goes where it's supposed to.
Oh yeah, if you take the black box off (inside of cab), might as well go ahead an replace the heater core too.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 02-02-2012, 06:57 PM   #28
Briggz29
Briggz29's Avatar
so in my 94 the heater quit working one day but i reached over with my snow brush and hit the blower motor pretty hard and the heater came back on, I know its not a good fix or the right kind of truck but its worth a try
1985 Chevy C10 swb 350
Briggz29 is offline   Reply With Quote
Old 02-02-2012, 09:51 PM   #29
sduckworth13
sduckworth13's Avatar
I was having issues with my heater last week, previous owner somewhere down the line decided to cut the power to the heater control and run it to the tach so the light would work...overachievers. I would have just ran a power to the fuse box. I ran a power wire to the battery and one to the blower to make sure it was working fine. It worked so I knew I had a power issue. That worked fine on my 1969 Chevy might be different on the newer trucks though
Scott
sduckworth13 is offline   Reply With Quote
Old 02-02-2012, 11:52 PM   #30
motornut
78K & 79C Jimmys
motornut's Avatar
check to see if the housing is bent....from leaning on it
John
Old 10-09-2012, 05:04 PM   #31
Ken 45LC
I had to bring this thread up again because it helped me out the last time. But I believe the po switched some of the vacum lines around. Does anyone have a schematic of the vacum lines coming off of the heater control switch?
Also, the flapper door that has that little white clip that usually breaks, my flapper is missing most of the rubber seal that surrounds it. I didn't see it listed as a part in LMC, does anyone know where to get it?
And finally, when I apply the brake pedal there is a clicking sound coming from the steering colum area. I can't tell for sure where, I suspect it might be something with the cruise control. Has anyone else had this occur?
Thanks,
Ken
Ken 45LC is offline   Reply With Quote
