01-20-2012, 11:36 PM | #26 |
67-72 parts collector,…
Re: 20/22 Boyd Vtwin & porterbuilt stage 2 suspension
I thought they looked familiar,...
01-21-2012, 09:27 AM | #27 |
JRods Garage
I wanna see where this goes!
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
01-22-2012, 03:51 AM | #28 |
Yes the wheels do have a bit of history to them. What i like most about them is that i havent seen them anywhere else!
Front suspension consists of a PB mild dropmember (no notching required), PB lower control arms, cpp uppers, SS7 bags and cpp modular spindles I was able to mock up the motor today. |
01-22-2012, 04:02 AM | #29 |
motor pics
01-22-2012, 05:16 PM | #30 |
JRods Garage
Just the pics I wanted to see! I notice you are running the F-Body accessory setup?
01-22-2012, 05:36 PM | #31 |
01-22-2012, 05:38 PM | #32 |
LOVE IT !! I was real close to ordering 20" v-twins for my yellow 69.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
01-22-2012, 10:10 PM | #33 |
01-23-2012, 12:40 AM | #34 |
JRods Garage
Dang! I was hoping you were gonna put the AC on... I want to see how much Im going to have to trim off for it to fit. You just decide to not have AC then?
01-23-2012, 01:06 AM | #35 | |
I do have the bracket and compressor. Ill go ahead and mock it up and get some pics this week to give you a look at the clearance while I have my motor in. Posted via Mobile Device |
01-23-2012, 05:40 PM | #36 | |
01-24-2012, 12:45 AM | #37 |
JRods Garage
Youve got to be kidding.... Like how far off from fitting is it?
01-25-2012, 03:42 PM | #38 |
You'll be able to get the bracket in but the compressor will not mount to it. The back of the compressor runs into the inner truss support on the dropmember. Its not going to fit
01-25-2012, 05:39 PM | #39 |
JRods Garage
I just talked to Nate today, and I guess the alternator gets in the way of the steering linkage to the rack and pinion. Im not too excited about this. He said the F-body stuff will not work at all
02-01-2012, 02:33 AM | #40 | |
02-01-2012, 09:49 AM | #41 |
Love the stance, nice looking truck!
Details on drive train?
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
02-02-2012, 07:39 PM | #42 | |
'69 Chevy SWB
can you give us alittle info on the valve covers. What brand are they, and where can i pick up a set? Thanks.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
02-04-2012, 03:22 AM | #43 | |
02-04-2012, 03:38 AM | #44 | |
Here's the link http://www.mastmotorsports.com/2010/...20Covers&id=49 Posted via Mobile Device |
02-04-2012, 03:48 AM | #45 |
Thanks! Motor is a 6.2L with forged internals and stock cubes, l92 heads ported and milled, custom grind comp cam and ported FAST 102 intake. Should be a pretty stout street motor. Trans is a built 4L80
02-09-2012, 11:55 PM | #46 |
True Addiction
Nice ride!
RCC |
02-10-2012, 03:01 AM | #47 |
motor exploder
Nice truck, stance, wheels and motor! Should be a beast when you're finished. Bummer about the accessory drive.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-10-2012, 04:33 AM | #48 |
VA72C10
Looking great!!!!
Looking for a 67-72 swb or blazer project in or around VA. |
06-15-2012, 10:16 AM | #49 |
A guy with a truck
Man, I like where this truck is going
Did you ever get the alternator/rack issue resolved? How close was the A/C compressor to fitting? Would using truck spacing (3/4" forward from F-body) be enough to clear?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-15-2012, 08:59 PM | #50 |
There arent any clearance issues with the alternator on the the mild DM. It clears the rack just fine. Alternator does come pretty close to the top frame rail on my 67 frame. I will be doing some light trimming to the frame rail just to be safe.
The f-body ac compressor and bracket isnt even close. Easiest way to get ac on this setup would be to go with an aftermarket top mount ac bracket. Truck accessories might be a option but I wouldnt count on it |
