#26 | |
Re: average build time? im stressed out
The wiring harness is easy! but should be done in a couple steps that sound redudant, first run all the wires where they go, but do not put connecters on them, electrical tape them together, pull everything out and heat shrink it accordingly so it looks good, then re-run all the wires and put your connectors on. I like to use stainless tubing around the engine and run my wires inside there for a nice clean look. if you decide to do this, use mig welding wire and run it through from the end that will have a connector, tape to wire and pull through, then put connector on.
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott 1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064 1930 Tudor Sedan |
#27 |
TX58, its funny to read this tonight. I was just logging on to pretty much complain about a similar/same situation. I am more so getting stuck with a lack of motivation. I have had my truck only a few months, and have done little to nothing with it. The body on my 55 is rough, but it is a running driving truck. Almost all of my glass is broken, doors are all rotted and sagging, I have no truck bed, and my gas tank is a plastic jonboat tank strapped to the frame behind the cab (PO did that one). I got it running a little better, rebuilt the carb, and parked it in the garage and haven't done much with it since. I estimated about a 5 year build on my truck, with plans to buy new sheetmetal for it each year around tax time (one fender this year, a hood the next, etc.). Then I came across a great deal on an extra truck minus drivetrain and bed. Now, my plans are to drive the one I got to satisfy my need to drive it, and do the body work on the other cab. When it's all done, swap em over and call it a day. Is that something you could maybe do on yours? Maybe find a cheap runner in the mean time that you have no intentions to rebuild? I find tri fives around my area all the time for $1500 and less. Just a thought.
#28 | |
What do you mean by drilling holes thru the hinges? Cab side or door side? Posted via Mobile Device |
#29 |
Both cab side and door side. Once the doors are aligned, drill a 1/8" "locator" hole through each hinge and hinge pillar, and through each hinge and door (8 holes total). When it comes time to put the truck back together, you start all the bolts, stick a 1/8" drill thru each hole, tighten all the bolts and your door is re-aligned!
#30 | |
Helps to make a project plan too - something with major goals followed by the minor steps require to achieve them. Kinda like: - FRAME - Strip - Repair - Prep - Spray - Install suspension / stance - pre wire - CAB - etc, etc Goals change, but having a master plan helps you keep focused... Me? I removed the front fenders, hood, grill etc to clean up the firewall & frame/suspension and install a new engine and replumb everything. That was seven years ago and I ended up with a empty cab on a frame ![]() Good new is it'll be rolling this spring. Be patient, and most importantly - remember why you bought it - to work on? to restore? to cruise? to make a show truck? etc.... Just stay focused in whatever you do |
#31 |
6 years + for me. It takes time and money. I've got more time than money!!
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
#32 | |
This might save you from buying the wrong set of wheels, steering wheel, Guages or some other item that requires a serous cash outlay and you only want to do once. |
#33 |
Active Member
My favorite part of having a project, is having a project. I say get it running and drivable and don't sweat it. Enjoy it!!
#34 |
![]() Join Date: Aug 2011
Here is what I did. 1st bought a 49 pickup that was in great shape, original, and running. Someone else did the 75% restoration (interior brakes exhaust, engine). Still has original paint and farm dents from Indy. No Cancer. See picture.
Then, I bought a non running sitting in a field for 10 years complete unrestored 49 which sits in my driveway half torn down. Should take about 3 to 5 years depending on my cash flow. When I get fustrated or out of cash I go take a ride in the running truck. |
#35 |
I'm going on my 3rd year now and plan to have it on the road this spring. Or close to...
The problem I find, is remembering where I left the damn parts and also remembering which parts I have already purchased. ![]() |
#36 |
Mine took a year and i thought it was time consuming,every weekend and late nites.But its a downer when your all done because its like something is missing even though you have a driver.So i would say take your time and enjoy the work and the fabrication because it beats laying on the couch watching tv where i find myself again !!!!!
#37 |
Enjoying left field
I just came in from the garage frustrated because things are taking so long. This thread was about the best one I've came across in a while. 3+ years??? Makes me feel better about my progress. I just really want it to be done. But I'm trying to build it to last as a daily driver in an area where they salt the roads in the winter.
Am I the only one that goes out in the garage and just stares at my project, not sure of what to do? Drives me nuts. Some times I'll stand there for half an hour. |
#38 | |
#39 | |
#40 |
Thanks for all the advice and wisdom, I know its a labor of love. I had a set back today, the doors turned out to be worst than I thought and need a lot of work. Thinking about hunting a pair down instead of fixing these. So I left them alone and started putting my engine together at least what I could. The oil pan turned out to be too dented to put on this nice engine. I will have to order a new pan soon. Even though I hit a few dead ends today it wasn't all bad, it was a beautiful day to be around the shop. My brother even showed up and checked out my progress, he's been given only months to live due to severe liver damage. Made me think, here I am *****ing about getting this truck done and here's my brother that probably wishes he could be doing something like this and live to see it finished. Now let's take our time and build this truck.
#41 |
![]() Join Date: Jul 2011
Well TX58,
I'm 4 years in and have not turned the wrench on the thing. have bought many parts. But only finished the remodel of the house early December. But I cleared out the wood scraps and all the remaining hardware an metal strapping today. I can actually get 2 cars in a 3 car garage. i have to cut some 2010 camaro part off a car next weekend. And the games start weekend after that. My goal is to be running and primed for Pismo on June 15. |
#42 |
#43 | |
#44 | |
![]() ![]() ![]() i worked construction most of my life. i have built homes, skyscrapers and football field sized machines (and lots of small stuff too). i think the major problem a lot of people have is they see a big project as just that, a big project. break every big job into smaller jobs, and that into smaller jobs, and then into smaller jobs. complete a small job as a unit, series of smaller units into a bigger unit and so on until the project is done. don't look at your truck as a truck, it's a series of parts/units. don't be looking at your gutters while working on your brakes. while i don't usually clean up everytime, a clean shop is easier to work in than some of the project areas i've seen posted. and take ample beer breaks ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#45 | |
![]() That said, where the HECK were you with this pointer three years ago when I put my doors back on my cab, by myself without a door stand! lol....sigh Makes perfect sense, lol - noted for the future! ![]() |
#46 | |
#47 |
CandyX is so right. I had to buy a truck I could take apart to get my a$$ of the couch.
#48 |
I average about 2 years. I try to accomplish at least one thing every day. I finished my 32 ford dump truck about 1 1/2 years ago and should finish my 72 this spring. It is a lot of fun and it also matters how much work is done by others. I did all of mine except the painting. That ate up 2 months at body shop. If you are not in a hurry , then take your time. I'm not happy unless I have some project in the works.
I know I can! I know i can! 72 K20 Restoration |
#49 |
#50 |
![]() Join Date: Jul 2010
I'll chip in from a different view point. A section of or business is what we call 'The Custom Shop' where we work on, maintain, and build customer projects. It is a well outfitted 4000 ft section. By far the most common car/truck in the custom shop is a 'Take-over' project. And the story is usually the same. " .. for about 6 or 10 years this has been in 3 to 5 shops, and my garage. I have lost over 2 to 10 thousand to shifty operators, and I just want to get it done right...." This is sad. Many of these projects were not realistic on day 1, and now some of the plan is outdated, or out of style. On most, wheels, tires, and body work came first, and later when it came down to plumbing, wiring, cooling.... the project stopped. We have an unlimited supply of customers with this story, and while it keeps us busy, it's not good for the customer or the hobby. I'd rather do new builds. Plan a project that you can finish and drive in three years os less. Then tinker with it, and add to it. Drive may not mean finished. If wiring and plumbing aren't your thing, find a professional and pay then to do it right. F.Y.I. - complete brake line plumbing , with valving and sst flex hoses, installed and pressure tested, in our shop runs $800 to $1200. Complete wiringis usually in the $1500 to $1800 range, parts/labor incl. Just for referance. The world would be a better place if we were driving our projects a bit more, and using them as a shelf in the garage a bit less.
P.S. I am guilty of a garage obsticle myself, just sayin'.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
