01-27-2012, 02:43 PM | #26 |
Re: Give me some help
Ya...I get that. The difference in the tire you showed me(255/40-20) and mine(235/60-15) is 2 inches in height. Wouldn't that be pushin it? Thanks for the reply.
01-27-2012, 03:21 PM | #27 |
needs more $$$
Yup...if you stick with the 40 series, you're front end should come up about an inch and the wheel will go up into the fender about an inch as well since they are about 2 inches taller than your current.
If you want the 20's, get the 20's...you probably wouldn't be happy with anything smaller. I just get them and hope they work and if not, figure out if you have 2.5 or 3 inch drop spindles and buy springs to get you a ~6" drop in the front. BTW gringo, that's the 1st time I've seen your truck other than your avatar...looks damn good! Gonna have to check out your build thread...can't believe I haven't yet.
1970 2wd Blazer |
01-28-2012, 01:27 AM | #28 |
I'll try and get some pics on here this weekend of my front setup. Might be able to get my buddys 20"s to see if it will fit.
01-31-2012, 02:41 PM | #29 |
As of now it will be 20"s. If if gotta remove the inner fenderwells then so be it. Might change my mind again so who knows.
Think my best tire combo would be a 245/40-20 front and 295/40-20 rear so that I can maintain as close to my stance as possible.?! Oh and proper backspace info needed. Any thoughts feel free. Thanks for all the continued help. As always this site solves a lot of stuff that goes haywire in my head from time to time. |
01-31-2012, 08:09 PM | #30 | |
The rear back spacing is dependent on the specific housing (narrower 6x-69 or wider 71-87). Since your truck is a 67 w/5-lug pattern you need to determine if the axles are just the original 6-lug axles re-drilled; aftermarket 5-lug units in the stock 67 housing, or was a 71-72 5-lug housing swapped in place.?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-31-2012 at 08:15 PM. |
02-01-2012, 01:57 AM | #31 |
Ya I still have to get under it and measure the rear end.
I'm sure that it's either the axle swap or entire diff swap because I don't remember seeing redrilled axles. Will try to get some pics on here too. |
02-01-2012, 12:41 PM | #32 |
Update:
Got front and rear wheel off today. Unable to get decent pics. Still tryin. Front: CPP 6102-2.....2" drop spring. Was unable to see any markings on the spindle. Rear: After measurement have come to find that I have the later model 12 bolt (57" backing plate to backing plate). Any other ways to tell what drop spindle I have? |
02-01-2012, 02:53 PM | #33 |
needs more $$$
I've never seen any way to determine which drop spindle you have by looking at it, but 3" spindles are only made for 73+ years. Based on how low you are, you at least have a 2.5" spindle, so the other .5" shouldn't be anything to worry about for now.
I'm not running inner fenders up front in my blazer...mainly because it didn't have them and I don't want to shell out the $ for a set, let alone a set of Slosh Tubz (which are perfect and hopefully will be around if/when I come to a point where I can afford them).
1970 2wd Blazer |
02-02-2012, 02:28 AM | #34 |
Ok so if I have the 2" drop spring and at the most a 2.5" drop spindle that would mean a 4.5 front drop on a 26" tall tire. Out back I have a 28" tall tire. My fenderwell lip height is as follows: 25.25" front and 25.75" rear. I state that measurement because after "big al" gave me a measurement it got me interested as to where mine sat. So correct me if I'm wrong or stupid but if I went with a 245/40-20 (27.7" tall) in the front and a 295/40-20 (29.5" tall) it would or should in my mind raise the overall height of the truck around .5" to 1.0"?
02-02-2012, 02:58 AM | #35 |
needs more $$$
Yup! Take the difference between the two tire heights and divide by 2 and that's how much it'll raise the truck... Just know that it will also move up into the fender that same amount.
1970 2wd Blazer |
02-02-2012, 02:37 PM | #36 |
Thanks for the help guys!
