#26 |
Re: H2 wheels with GMC center caps?
Also, what is this about me needing conversion lug nuts?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
#27 |
#28 |
![]() Join Date: May 2010
I know that's what you meant, and there are a lot of import caps on ebay. There are also many previously silver genuine H2 wheels that have been chromed. So, be careful unless that doesn't bother you. They are different.
#29 | |
http://www.ebay.com/itm/32-LUG-NUTS-...item462b658394 I see you have a 70. With your disc conversion you may need 9/16" in front and 1/2" in rear. Last edited by FirstOwner69; 11-04-2014 at 06:54 PM. Reason: Added link. |
#30 |
I could be wrong, but I don't think these were chrome from the factory. At least the set I bought look to have been chromed after the fact.
Don't forget the lug nuts with the correct tapered snout and the "shoulder" threads for the fake black plastic lug nuts in the center cap, they screw down onto them. I wound up getting everything except the wheels studs and the spacers I needed to clear the Dana60 off eBay. As a side benefit it (in my case) brings the rear track width out a bit, making it closer to the front. Why they had a narrower rear track than up front I cannot imagine. What possible advantage could there be? Stability? Beats me. In my case, as mentioned in the post before mine, I needed 9/16" lug nuts because I had converted to '72 front discs, and post-70 parts are the larger lug stud. If you had all 1970 equipment I don't know if you could stick with 1/2" studs on these wheels. That'd be a good thing to know, maybe FirstOwner69 can speak to that.
#31 |
![]() Join Date: Nov 2004
Wow, by far the best looking looking "modern" option I've seen for the 8 luggers.
Dave, your trucks looks awesome!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#32 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
H2 wheels were available in chrome or alloy type finish. I bought stock chrome factory wheels.
By conversion lugs I mean to be able to adapt to the external threads to mount the center caps. Since I did a front disc conversion I had to use 9/16" in front and 1/2" in rear. No big deal. I have Eaton HO52 corporate rear end. No problem fitting center caps on the rear.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#33 | ||
Are your guys' plastic as well? Just want to make sure I have a similar product before I open every package. Heres some pics:
#34 |
Plastic is correct. However, your caps appear to be aftermarket.
#35 |
Awesome, thanks for the quick feedback.
#36 |
#37 | |
#38 |
Yeah, I did. And they are aftermarket, made in Taiwan. Got them for $95, official Chevy parts had them almost $80 for one unit. Did you guys find them somewhere for cheaper?
#39 |
Got mine on ebay for $112 a couple years ago. GM in a 4-pack. The other day I saw the same for $140 http://www.ebay.com/itm/321537686276...%3AMEBIDX%3AIT . My guess is that the GM caps are not as plentiful now. Therefore, the higher price.
#40 | |
Wonder if there are any other options for center caps for these wheels? I love the bowtie in the cap, but would also be fine with something all chrome, something really simple
#41 |
Here's a picture of 1988-2000 caps on the 2001-2007 wheels our caps were made for. Not sure how deep they are, but if they fit the 2001-2007 Chevy/GMC wheels, I'd bet, at least diameter-wise, they'd fit the H2s.
#42 |
Update:
Went ahead and bought the Cooper Discoverer's from Discount Tire. Very impressed with the tread, price ($730 out the door), and Discount's customer service. Excited to see these mounted as my build up develops! PROFILE VIEWS TREAD COMPARISON (to what was on the truck)
#43 |
What size tires?
#44 |
#45 | |
#46 |
http://www.ebay.com/itm/New-Set-of-4...BXn0Zz&vxp=mtr |
#47 |
![]() Join Date: Aug 2020
Anyone found center caps that work with a 67-72 K-20? That is, having access to the front locking hubs and large caps that accommodate the rear hubs?
#48 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Dually caps, you will need a 4” or so hole saw to cut the center out of the front.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#49 | |
What is the actual front hub diameter on a 4X4?
Jim |
#50 |
SWB 4x4 Collector
I had a 14 bolt full floater on my crew cab build while starting the build. I also cut the centers out of the front caps when I wound up using them on my 1 ton 4x4.
