Old 02-20-2012, 11:42 AM   #26
suburban509
Re: slide in receiver hitch help?
Not having any luck searching for the hitch you used. Do you have the part number?
suburban509 is offline   Reply With Quote
Old 02-20-2012, 01:43 PM   #27
dugvera@gmail.com
dugvera@gmail.com's Avatar
I bought it at Walmart. Same one they had at pep boys for about $20 less.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-20-2012, 04:34 PM   #28
suburban509
Excelent. Thanks for the number.
Old 02-20-2012, 06:05 PM   #29
jj1965
jj1965's Avatar
I bought the same unit @ Autozone. Used it all last summer to pull my boat with no problems.
jj1965 is offline   Reply With Quote
Old 02-20-2012, 11:45 PM   #30
dugvera@gmail.com
Perfect! Ill be using mine this weekend glad te hear good feedback. Although I know I installed it myself and its solid its a small piece of mind knowing others are having good luck with the same product.
Doug
66 4x4 GMC Suburban
Old 05-01-2012, 01:13 PM   #31
hotroddude
Do you have the part # for the reese hitch. I have a 64 suburban & need a hitch. Thanks. Pat
hotroddude is offline   Reply With Quote
Old 05-01-2012, 01:17 PM   #32
dugvera@gmail.com
I got mine from Walmart. Looks like part#on the box says 37042.
Doug
66 4x4 GMC Suburban
Old 05-02-2012, 06:17 PM   #33
sodly
sodly's Avatar
So it looks like there's an off-the-shelf hitch to fit nearly any need. I'm still trying to figure out which hitch might work under a Barden-style bumper. Has anyone done that combo?
I'm also wondering what the preferred ball height is? Anyone know? Is there a range? Or do you just address that with an upturned/downturned ball bracket?
Also, what are people doing about trailer brakes? I'm used to bigger trucks where trailer brakes are a given. What are the rules on trailer brakes for 1/2 ton pickups pulling a boat, for instance? Do I want to rely on my single-circuit drum brakes to stop the whole show? These are some of the questions I'm pondering.
sodly is offline   Reply With Quote
Old 05-03-2012, 12:54 AM   #34
oem4me
I have not done the step bumper/hitch mod, but I don't see why It would not work. As for height, it looks best tucked up under the bumper as close as possible, adjusting to the trailer tongue with the appropriate slider. You know - straight out, big drop, little drop, or even flipped for a lift.
The brake question is one I have not tackled, but surely will before towing our boat with the Suburban and stock brakes. I must say, our dads and grandfathers must have had bigger cajones back then, barreling down mountains in these things with a big boat or trailer in tow and hardly a concern for the family in the back.
Old 05-03-2012, 08:44 AM   #35
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
If you put brakes on the trailer and do not wish to have a brake modulator mounted in your truck, you can go with the Tekonsha RF Brake Control. This is what I'm mounting on the Airstream project to hook up to the 63.
http://www.etrailer.com/Brake-Contro...sha/90250.html
Old 05-03-2012, 10:56 AM   #36
dugvera@gmail.com
My boat has surge breaks that work great behind my suburban. The system aerotruk63 is running looks cool for electric breaks. I have always been in the understanding when vehicles are rated for towing the concern is in stopping the load not pulling it.
Doug
66 4x4 GMC Suburban
