Old 02-08-2012, 08:42 AM   #26
Pick
Pick's Avatar
Re: Best rust/frozen bolt fixer concoction
Aircraft Spruce is local to me.....sorry. MSC and Grainger both carry it as well, but here again, they have retail stores that are fairly close to my location. Gunsmithing suppliers, aircraft maintenance suppliers, machine tool suppliers, etc. are all good possibilities to check in your area.
Privately-owned Napa stores, or other non-corporate-owned auto parts stores in some areas carry it as well.
I hope that helps.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 02-08-2012, 12:17 PM   #27
sir_talk_alot
sir_talk_alot's Avatar
any hunting store like a gander mountain, academy, something along those lines.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 02-08-2012, 01:18 PM   #28
Earl Junior
Cadillac power
Earl Junior's Avatar
The local NAPA store carries Kroil. I've not found it to be that superior to PB Blaster. But, I've also got a torch and not a whole lot of patience.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 02-08-2012, 01:22 PM   #29
83gmc4x4
PB Blaster, Deep Kreep, Kroil work good. Zep Oil is by far my favorite though. It kind of hard to find.
1972 Custom 1500 Long Step 250 I6, 4spd
1974 F350 cummins/4x4 conversion (hopefully)
83gmc4x4 is offline   Reply With Quote
Old 02-08-2012, 01:35 PM   #30
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Originally Posted by Willys47 View Post
Heat / torch works very well just use it safely
On nuts and bolts that are really rusty, heat the nut to the warm red glow and use some wax to quench - it'll shock it loose like water and lube the threads to back it off.
And if it ain't broke, get a bigger hammer!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-08-2012, 01:39 PM   #31
ffk
ffk's Avatar
go to a chevy dealer and buy a can of there penetrating oil ..its the best..been using it since 1977 ...
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 02-08-2012, 04:53 PM   #32
fine69
fine69's Avatar
Kroil hands down.
I cant buy it local anywhere. I just order it from the maker.
Expensive. But worth much more than it costs.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 02-08-2012, 09:52 PM   #33
grace72
70% atf /30% acitone. old family drew. works better than anything sold!!!!
grace72 is offline   Reply With Quote
Old 02-09-2012, 11:52 AM   #34
bollybib
bollybib's Avatar
I've tried most of these. I didn't know about atf/acetone until recently. It works the best and the cost is low.
Taken from Overdrive Hot Rod News, January 2012
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 02-09-2012, 01:07 PM   #35
splehigh
splehigh's Avatar
My neighbor uses Seafoam Deep Creep and says it works better than PB Blaster or anything. Its expensive though. About $10 a can I think.
http://www.seafoamsales.com/deep-creep.html
splehigh is offline   Reply With Quote
Old 02-09-2012, 02:14 PM   #36
Beat68CST
Beat68CST's Avatar
Anyone ever use S'ok? Came in a green can.
We used to use that back in the day, haven't seen it in a long time though.
Beat68CST is offline   Reply With Quote
Old 02-09-2012, 07:55 PM   #37
hjewell2
hjewell2's Avatar
Originally Posted by hounddogs! View Post
Kroil products. Every one of our maintenance guys has 1-2 cans on his tool cart.
never heard of it, where do you get it.
hjewell2 is offline   Reply With Quote
Old 02-09-2012, 07:59 PM   #38
Tkmadone
I like the CRC penetrating oil. I think it's caller Knocker Loose or something silly like that.
Tkmadone is offline   Reply With Quote
Old 02-09-2012, 08:21 PM   #39
BMERDOC
BMERDOC's Avatar
All good info but...When loosening the bolts do yourself a favor and clean off the exposed threads. Tighten the nut and clean some more. Wedging that crud between the nut and bolt can almost always guarantee a broken bolt.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-09-2012, 08:38 PM   #40
rpatowers
I like Kroil.
For you folks that shoot, Kroil is an excellent bore cleaner when you use molly coated bullets. It gets under the carbon in the barrel and lifts it off.
A little off subject but maybe it will be of interest to some of you.
rpatowers is offline   Reply With Quote
Old 02-10-2012, 12:28 PM   #41
camrycurt
camrycurt's Avatar
I've been wanting to try this and am glad to hear it works. bollybib, did you use a 50/50 mix of ATF and acetone?
And what do you use to apply it? Is the mixture thick enough that you have to use an oilcan of some sort or can you put it in a spray bottle and squirt it on?
Thanks for the help, guys!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 02-10-2012, 11:05 PM   #42
bollybib
bollybib's Avatar
I poured approximately equal quantities of atf and acetone into a small paper cup and then poured it on the part. You could use a qtip or maybe fill a small spray bottle to get it into awkward spaces. It penetrates like mad that's what I liked.
- Jim -
Old 02-11-2012, 09:52 AM   #43
Redline novdog
Redline novdog's Avatar
I got a tip from an employee at 'Big Yellow' of a test they ran on three penetrating oils and a mix.I believe this was WD40,Kroil,and one I can't remember.The mix was one part Acetone,one part automatic trans fluid.This 50/50 mix beat them all.I have no experience with this so if anyone gives it a go or if I get a chance,post up
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 02-11-2012, 10:22 AM   #44
no moa
no moa's Avatar
Originally Posted by VA72C10 View Post
I've just always used PB blaster since I found it. Spray on top and under a day or so ahead of time then again just before trying. If they're hard to get off after that I try heat if I have it...if not, I use an impact gun and wring them off (break the bolt) or use a breaker bar with a cheater if no air...
x2 Best stuff i've ever used!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-11-2012, 10:48 AM   #45
67lowered
I've used kroil for years. It is kinda red looking and stinks, maybe its atf and acetone? have to try that mix when I run outta the kroil.
67lowered is offline   Reply With Quote
Old 02-11-2012, 10:48 AM   #46
Dunenutt
Newbee
Dunenutt's Avatar
20 years of working on industrial pumps for a living, I have been through hundreds of cases of the stuff. Works great, and smells good too! You have to get it at a bulk oil dist. though.
Dunenutt is offline   Reply With Quote
Old 02-11-2012, 06:14 PM   #47
brans72
I vote for torch if you have one handy, otherwise PB blaster is good choice but lately I have beeing using In-Force from BG course I get it from my work and I think it is way better then PB blaster.
brans72 is offline   Reply With Quote
Old 02-11-2012, 11:00 PM   #48
b a king
been useing this for years. got a little trigger type oil gun can squirt this stuf full length of of truck....if i want to. for me,works better than all others
b a king is offline   Reply With Quote
Old 02-16-2012, 07:02 AM   #49
MikeyMan
Originally Posted by Pick View Post
I'm partial to Kroil as well.
I just did a quick search and found this:
http://www.kanolabs.com/google/
2 cans for 12 dollars seems like a deal to me........and WELL worth it.
Eastwood, Aircraft Spruce, and Wicks Aircraft Supply (among others) also sell it.
Hey Pick, Thanks for that link!
I went to their site and ordered the 2 can google special. They arrived yesterday.
MikeyMan is offline   Reply With Quote
Old 02-16-2012, 01:11 PM   #50
Pick
Pick's Avatar
You're welcome! I'm glad you got it!
