Old 03-22-2012, 01:49 AM   #26
c10derek
c10derek's Avatar
Location: Santa Barbara, California/Tuscaloosa, Alabama
Re: Restored original Tach dash with Air pressure
Looks great I'm installing American auto wire harnes would that be plug n play?
c10derek is offline   Reply With Quote
Old 03-22-2012, 01:52 AM   #27
VA72C10
VA72C10
VA72C10's Avatar
Should be if the harness is set up for factory gauges. You will need to run the separate tach wire (they sell one for points or HEI-not sure if it's in the harness) and need to run the air line separately.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-22-2012, 01:55 AM   #28
c10derek
c10derek's Avatar
My dad says do it, what's your PayPal info
Old 03-22-2012, 02:00 AM   #29
VA72C10
VA72C10
VA72C10's Avatar
sending pm now.
Old 03-23-2012, 12:59 AM   #30
c10derek
c10derek's Avatar
Thumbs up Re: Restored original Tach dash with Air pressure
sweet please send the without choke bezel, money is already yours,the dad
Old 03-23-2012, 03:21 PM   #31
VA72C10
VA72C10
VA72C10's Avatar
Swapped bezels. Did you determine if the harness has the tach wiring in it and which distributor are you running (points or HEI)
Old 03-23-2012, 03:21 PM   #32
VA72C10
VA72C10
VA72C10's Avatar
All boxed up ready to ship out...just need to verify what I need to do on the wiring...
Old 03-26-2012, 10:44 AM   #33
c10derek
c10derek's Avatar
I think all the correct wires are already in the new harness
Old 04-06-2012, 10:16 AM   #34
c10derek
c10derek's Avatar
thanks Jonathan, the gauge cluster is great, can't wait to get this thing done!!!
Old 04-07-2012, 10:00 AM   #35
Satin69
Jonathan,
Are you planning on doing any others? If so, I would like to put an order in for one similar to this one without the choke.
Joey
Satin69 is offline   Reply With Quote
Old 04-07-2012, 11:52 AM   #36
VA72C10
VA72C10
VA72C10's Avatar
You're welcome! Enjoy
Originally Posted by Satin69 View Post
Jonathan,
Joey
I have one more nice lens right now..that's the biggest issue is finding a nice lens since they aren't reproduced. Same 525 shipped if you're interested.
Old 04-07-2012, 07:25 PM   #37
Satin69
Yes, I am interested. Can you post a picture please? I would need it with the 80# oil and air pressure gauge.
Thanks again,
Joey
Old 04-07-2012, 08:46 PM   #38
VA72C10
VA72C10
VA72C10's Avatar
Thanks again,
Joey
I will need a few days to finish it up but can show you the parts at this point..
Old 04-07-2012, 10:57 PM   #39
Satin69
Ok, that would be great.
Old 04-08-2012, 11:11 PM   #40
VA72C10
VA72C10
VA72C10's Avatar
I'll try to get some pictures up tomorrow.
Old 04-08-2012, 11:39 PM   #41
Bethewaz
Thanks for those answers. I have a tach/air dash I put together combining light duty and heavy duty truck pieces in case I put rear bags in my '67 project. I was just curious to learn what the original use would be from factory in the 10-30 series trucks. I've only known of air pressure gauges in trucks with air brakes.
I agree,it's a nice dash.
This appears to be the same thing that you did. The air pressure guages only came in big trucks with air brakes. The guage face (not reproduced as stated) came in a big truck cluster and was removed and likely assembled in a 10-30 series dash bezel. Many of the big trucks did come with tach (as many had dump bodies with hydraulics and had recommended RPMs for proper pump pressure, etc.
Using this with an airbag system is becoming very popular and would be cool. Nice piece!
Bethewaz is offline   Reply With Quote
Old 04-09-2012, 03:12 PM   #42
Satin69
That is my hope. I just opted for the Air Ride system so my hope is to retain a factory look. My only problem is that I have two tanks and will only have one gauge. Anyone have any ideas?
Old 04-10-2012, 03:58 AM   #43
VA72C10
VA72C10
VA72C10's Avatar
Other than hiding the other gauge in the glovebox...I don't have an idea...
Not sure if you could connect the two tanks to even out the pressure between them and get the one pressure reading...
I will get pics tomorrow....today was busier than expected I'm picking up another one as well that looks to be in perfect shape if you'd rather wait for me to get that one...will just need cleaned up tins and a new bezel...
Old 04-10-2012, 09:17 AM   #44
Satin69
Jonathan,
What about making the cluster with two pressure gauges and putting volts in the glovebox? If I have to have two gauges, I would like for them to be in the same place.
If nothing else, I could use a clock cluster and put both in the glovebox? Maybe a half bottom of one cluster mounted to the top of the gb? Sorry to open air so much thought but I want to make sure and keep all sales communication in the thread.
Thanks for the help,
Joey
Old 04-10-2012, 01:36 PM   #45
VA72C10
VA72C10
VA72C10's Avatar
Jonathan,
Joey
I can't really add another one due to the lense not having a second air pressure spot. You could possibly do that with a white faced setup that lets you make a custom lens but you'd need two sets to get two air pressure labels....
If you were going to hide one I'd do aftermarket since it's cheaper and they come with mounts for single gauges...
But honestly, the easiest solution is to run a line between the two tanks. It will allow the pressure to equal out between the two tanks and you would just need the one pressure gauge then. It's not like plumbing bags together where you have air transfer issues so it's no problem to run like that.
Old 04-10-2012, 03:05 PM   #46
Satin69
I have aftermarket gauges and don't like them.
I will just take your sugestion and run a line to each tank then one line off that to the gauge. Problem solved.
Old 04-11-2012, 02:40 AM   #47
VA72C10
VA72C10
VA72C10's Avatar
Sounds good. Here are pictures of the current parts I have. SUPER SUPER nice 80lb gauge and air pressure. Lense will need some polishing and likely will still have scratches showing because the main scratches (pictured the best I can) are inside around the lettering and I don't want to buff off the lettering I am getting another tach/air dash in soon and will see if that lens is better...
Old 04-11-2012, 02:41 AM   #48
VA72C10
VA72C10
VA72C10's Avatar
I'll be using a better tach also than the one pictured.
Old 04-11-2012, 12:39 PM   #49
Satin69
OK, thank you for posting. I hope the other lens is better. That one looks pretty scratched.
Old 04-11-2012, 01:18 PM   #50
VA72C10
VA72C10
VA72C10's Avatar
It is but the picture makes it look a lot worse than it actually is...that's an extreme closeup In the overall view you can't even see them but I didn't want you thinking it was a perfect lens...
