![]() Join Date: Mar 2007
1947-53 LED dome light retro fit
First things first. I got the idea seeing OKGMC4 do something simular to his 56 truck.
This is basically a way to retro fit a 24 bulb LED panel into a stock dome light for less then $10... I started by removing the housing that holds the bulb. I simply knock it out with a hammer. The thinking was to be able to reuse if need be. Then I lightly ground down the edges of the LED panel to better if into the opening of the dome light housing. Next I used some strip calk at each end to support/hold the LED panel to the housing. This is important because you would not want the back of the board to touch metal. Then I soldered some ends on the wires. I will ground the LED panel to the cab once the dome light is screwed to the cab.... Here is an Ebay listing for the panel: http://www.ebay.com/itm/180732629773...84.m1423.l2649 Onto the pics
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
