Old 02-19-2012, 02:54 PM   #26
GRX
GRX's Avatar
Re: Hard Lines 101
Originally Posted by MagmaJct View Post
My understanding is that copper will work harden over time and crack. Does the nickel help this?
You are right about the older style pure copper lines becoming brittle. The NiCopp stuff is a Copper/Nickle/Iron/Manganese alloy which is said to be quite durable. I did some reading before buying line for my C-10 project. Many car restores swear by it and it''s all they use now. And certain European car mechanics said they have serviced Volvo and Rolls cars where the alloy lines are still in great condition after 40+ years.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-20-2012, 11:09 PM   #27
RustyBillet
Re: Hard Lines 101
Hey BB72, it was a decent show, I'm still embarrassed by my truck since I haven't had much time to do anything to it. I'm doing quite a bit now-May for Showfest, are you going out there this year? Do you ever make it to the Whataburger cruise nights in Tyler? I'd like to meet ya sometime. Enough Thread-jacking, how's the hardline experiment going?
RustyBillet is offline   Reply With Quote
Old 02-21-2012, 02:20 AM   #28
YBNORML
YBNORML's Avatar
Re: Hard Lines 101
Good thread! Some very good info in here.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-21-2012, 05:49 PM   #29
biggestjohn
Re: Hard Lines 101
Originally Posted by MrGoodpliers View Post
Double flare for steel and aluminum tubing and single flare for stainless, right?
37 degree single flare for stainless. Use AN fittings and also have to use tube sleeves.
biggestjohn is offline   Reply With Quote
Old 03-21-2012, 03:38 PM   #30
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
been practicing....
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-21-2012, 08:06 PM   #31
AusTx68
AusTx68's Avatar
Re: Hard Lines 101
Originally Posted by webfoot View Post
AN is easy, all sizes are stated in 16ths of an inch. so 6 AN = 3/8 fuel line size, 8 AN is half.
I totally agree. Especially after reading all the woes of bending hard lines. I ran -6 AN fuel lines from tank to carb. Just laid it in the frame and fastened it down along the frame with loops. It couldn't get any easier. My kit was similar to the one shown in this link: http://www.summitracing.com/parts/SUM-PUMPKIT1/
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-21-2012, 08:37 PM   #32
ray_mcavoy
Re: Hard Lines 101
Yes, 37 deg single flare w/tube sleeve if you're using AN fittings.
But if you're using stainless tubing with stock inverted flare fittings, you need a 45 deg double flare just like you would use on a regular steel tubing. And yes, stainless can be double flared ... you need annealed tubing and a really good flaring tool though.
Yeah, I've been using a lot of that NiCopp tubing lately as well. The corrosion resistance and the ease of bending/flaring it more than make up for the extra cost in my opinion. On restoration projects, I usually give it a light coat of silver paint to make it look more like the OE tin plated steel.
ray_mcavoy is offline   Reply With Quote
Old 03-21-2012, 10:12 PM   #33
gotchevys?
gotchevys?'s Avatar
Re: Hard Lines 101
I've never used the NiCopp. I'll have to look into it. I use Cunifer which sound like about the same stuff. I bought the Cunifer at http://www.fedhillusa.com/?page=home
For flaring I use one of these. http://www.eastwood.com/professional...ring-tool.html Its not very cost effective for the guy flaring an occasional brake line but man does it make nice flares. You cannot tell the difference between the flares it makes and a factory made flare.
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 03-22-2012, 06:09 AM   #34
longbed67
longbed67's Avatar
Re: Hard Lines 101
[QUOTE=gotchevys?;5266987]I've never used the NiCopp. I'll have to look into it. I use Cunifer which sound like about the same stuff. I bought the Cunifer at http://www.fedhillusa.com/?page=home
For flaring I use one of these. http://www.eastwood.com/professional...ring-tool.html Its not very cost effective for the guy flaring an occasional brake line but man does it make nice flares. You cannot tell the difference between the flares it makes and a factory made flare.[/QUOTE
Wow thats some expensive line!!!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-22-2012, 06:13 AM   #35
gotchevys?
gotchevys?'s Avatar
Re: Hard Lines 101
[quote=longbed67;5267478]
Now that you mention it, I believe it has gone up since I last ordered it. It has been a while since I ordered any.
Old 03-22-2012, 07:19 PM   #36
ray_mcavoy
Re: Hard Lines 101
Yeah, most likely the same stuff ... just a different brand name.
The NiCopp I've been using is http://www.agscompany.com/automotive...n-lines/nicopp I get it at the local independent auto parts store. It's fairly expensive but quite as high as the Cunifer.
Old 03-22-2012, 08:52 PM   #37
slikside
slikside's Avatar
Re: Hard Lines 101
subscribed
slikside is offline   Reply With Quote
Old 03-23-2012, 12:13 AM   #38
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Hard Lines 101
Here's the one I made with 3/8" line...
Here it is installed...
Here is the flare tool kit and the tubing bender I used...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-23-2012, 05:10 PM   #39
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Hard Lines 101
Gary
That looks good. You could get a side business going making them for Holley's and Edelbrock's!
