#26 |
Re: Fleetside bed patch panels
that'll buff out
![]() ![]() ![]() but seriously... your front edge is good. a little flat stock bent in a vise would fix that
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#27 |
Hollister Road Co.
You should be able to fix that with a flat sheet of 18 ga. and use part of a rocker panel to replace the edge. you can buy the rocker without the step
#28 |
That's patina, leave it.... I don't know about the front, but I know the other end (1/4 sphere at bottom of taillight corner) is the same, I used part of a 63 bed to replace my missing pieces from the original lift gate install. The step sill is a good idea but I would give the vice a try first.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#29 |
Great idea! I also happen to have a junk door with a good bottom end I could just cut it and it already follows the proper curve. Stitch it up to a piece of rocker panel and I should be good to go!
"It ain't as easy as Chip Foose makes it look" |
#30 |
Hollister Road Co.
Doors are curved differently in the front at the fender than in the back at the corner they don't look like it but they are. I found that out making a door skin / door bottom jig. Your probably better off with a flat sheet and put the curve in it
#31 |
Man it looks close from the pictures I can find.
#32 |
The Suburban/Panel parts are impossible to find. I've been looking everywhere!
