Old 10-27-2014, 01:38 PM   #26
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 1968 C10 6 cyl to V-8 conversion
Originally Posted by Fitz View Post
The trans crossmember is not a problem. My truck started out as an I6 manual and, as you can see, it grew a few new cylinders and a built turbo 400. I cut and punched out the rivets holding the crossmember in the forward set of holes...just behind the cab mount... and moved it back to the second set of existing holes....so nice of GM to provide correctly spaced holes for a motor and trans that didn't even exist in 1967!
What is on the back of that trans? Some kind of overdrive unit?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-27-2014, 02:43 PM   #27
Old Truck Man
Old Truck Man's Avatar
Originally Posted by aprilg57 View Post
Another good input.
Since I already have the engine installed and everything else matches up except the exhaust, I'm going to try a straight down exit left exhaust manifold. I have some from late 50's/early 60's cars. They have the mount holes for a generator to which I can mount an alternator bracket available from many sources.
the exhaust manifold from 63 thru 66 trucks have the alternator mount and straight down outlet.
Old Truck Man is offline   Reply With Quote
