Old 04-09-2012, 10:36 AM   #26
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Triple Down
cool upgrade...can you give us details on the bulbs, etc
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-10-2012, 01:33 PM   #27
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Re: Triple Down
Here is the finished Volt gauge installed and working!
Hard Luck is offline   Reply With Quote
Old 04-10-2012, 01:34 PM   #28
Hard Luck
Hard Luck's Avatar
Re: Triple Down
More parts to go in.
Old 04-10-2012, 01:39 PM   #29
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Went to do some cleanup around the heater and replace the gaskets. Found a bit or rust. Cut it out, made and welded in a patch, finished, painted, and seam sealed everything including inside the cowl before putting it all back together.
Old 04-10-2012, 01:47 PM   #30
Hard Luck
Hard Luck's Avatar
Re: Triple Down
The patch was a good fit. Wes recomended removing the inner fender and there was some rust on the that as well, so I cleaned it up and painted it before reinstalling. Finished product looks pretty good it I do say so myself.
Took a little extra time to clean and paint the whole firewall, inner cowl, M/C and booster to make the place a bit nicer.
While she was apart put in all new Moog steering arms and adjusters with poly boots and a new (used) 1-1/16" front sway bar from LivRat with new Energy Suspension Bushings.
Old 04-10-2012, 01:50 PM   #31
VA72C10
VA72C10
VA72C10's Avatar
Re: Triple Down
Looks great! Nice work and a really nice truck!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-11-2012, 02:44 AM   #32
Hard Luck
Hard Luck's Avatar
Re: Triple Down
They are all SMD type LED bulbs. Was turned onto them by LivRat. One thing I always hated about LEDs in old rigs was the multi-point on little dots look. While LEDs are bright, they have a very shallow viewing angle and they don't light up the bucket so there is no cool glow in the lens. These SMD bulbs are built with LEDs on the tip but also all the way around to fill up the whole taillight area.
The crazy looking back up lights are 7 watt, with a billet aluminum housing/ heat sink, and a wide view fish eye lens. They took a long time to get and time to fit but now they are a big improvement.
Old 04-11-2012, 02:48 AM   #33
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Thanks!
Old 04-17-2012, 04:32 PM   #34
Hard Luck
Hard Luck's Avatar
Re: Triple Down
All the right steering parts. And parts picked up at the swap this weekend.
The cable and cord straps are made right in Oregon and are perfect for holding tie down straps.
Old 04-17-2012, 04:33 PM   #35
Hard Luck
Hard Luck's Avatar
Re: Triple Down
More parts.
Old 04-17-2012, 04:35 PM   #36
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Big stuff, Hood, tailgate, inner fender
Some shots around Portland
Old 04-17-2012, 04:37 PM   #37
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Vancouver and Portland right off the river.
Old 04-21-2012, 08:47 PM   #38
chevy71c10
chevy71c10's Avatar
Re: Triple Down
Great looking truck! Be sure to post more pics as the goodies get installed!!
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 05-03-2012, 09:54 PM   #39
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Wheels, wheels, wheels.
Old 05-03-2012, 10:36 PM   #40
NewType72
NewType72's Avatar
Re: Triple Down
I love love love those salt flat AR wheels thay are absolutely gourgeous on anything they touch. and man I have never seen such a large selection of new parts right off the bat not really focused but the small stuff rules all. neat addition with the taillights not sure about the white/blueish tint reminds me of those little nip cars round here. super clean truck I'll be following to see the progress
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-04-2012, 12:37 AM   #41
dliving69
dliving69's Avatar
Re: Triple Down
I just put whiteish blue led bulbs in my cluster. really brightens it up at nice. Cool idea with the rear lights I tried that but I couldnt get it to work and I see that you did. Really Cool
dliving69 is offline   Reply With Quote
Old 05-04-2012, 02:22 PM   #42
Hard Luck
Hard Luck's Avatar
Re: Triple Down
What can I say? I have a plan but I am trying to get as much stuff done as quickly as I can (which turns out to be a bunch of small stuff) in between downpours and classes. Have some more of the little items comming and then a few bigger ticks off the list that won't be much to show.
Trying to get the truck into a finished "Stage One" condition before July and start on the much slower, "Stage Two" at the end of the year.
Old 05-04-2012, 02:31 PM   #43
Hard Luck
Hard Luck's Avatar
Re: Triple Down
I had to do the same with the new cargo SMD bulb as well. De-solder the base, cut the leads, add a 1/2" tube spacer, solder on wire extensions, epoxy the base, solder everything back together again.
Seems like a lot of time to spend on a $20 bulb, but now it fits and works and it at least 4x brighter than before. Put an led in the dome, for better light, less draw, and less heat in the lens, am putting leds under the dash as well for entry but I am leaving the gauges with the old 168s, I like to be able to dim them way down so I don't have all that glare on the backroads.
Old 05-04-2012, 10:16 PM   #44
Tinkermc
Re: Triple Down
very nice work on the little stuff, and 2 me that is what makes a truck my own
Tinkermc is offline   Reply With Quote
Old 05-04-2012, 11:35 PM   #45
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Exactly!
Old 05-04-2012, 11:59 PM   #46
crsweet91
crsweet91's Avatar
Re: Triple Down
Looking Great!
crsweet91 is offline   Reply With Quote
Old 05-09-2012, 05:53 PM   #47
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Going to try out a new FlameThrower dizzy. I hear good things and want to see if I notice a major improvement.
Old 05-22-2012, 08:18 PM   #48
Hard Luck
Hard Luck's Avatar
Re: Triple Down
1st mock up for color
Old 05-22-2012, 08:33 PM   #49
Hard Luck
Hard Luck's Avatar
Re: Triple Down
Copper top
Old 05-23-2012, 05:24 PM   #50
Hard Luck
Hard Luck's Avatar
Re: Triple Down
How's about gold?
