Old 03-29-2012, 09:52 PM   #26
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: LS factory cruise control hook up
I grabbed two 4 wire switches from the junk yard.. but I couldn't find a good lever assembly....
Rich
1972 K5 Blazer CST Click HERE
Old 03-30-2012, 08:57 AM   #27
ls1nova71
ls1nova71's Avatar
What kind of column do you have?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-30-2012, 10:45 AM   #28
kwin
kwin's Avatar
Thanks you have answered many questions!
kwin is offline   Reply With Quote
Old 03-30-2012, 11:18 AM   #29
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Mine is hooked up and working! now for a long road trip!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-30-2012, 01:40 PM   #30
ls1nova71
ls1nova71's Avatar
Right on!
Old 03-30-2012, 02:07 PM   #31
farmtrucks
farmtrucks's Avatar
Originally Posted by ls1nova71 View Post
Add them. You can get a wire with a terminal out of another PCM harness at a junk yard and add them to the TAC plug, then wire them up.
Do I need to wire just the TAC or the PCM also?
farmtrucks is offline   Reply With Quote
Old 03-30-2012, 06:19 PM   #32
ls1nova71
ls1nova71's Avatar
Just the TAC, provided your PCM is already wired up, brake light switch input, that sort of thing.
Old 03-31-2012, 10:02 AM   #33
Critter
Future TOTM Winner
Critter's Avatar
Aren't those levers pretty expensive. IIRC those are the ones LMC sells for $230. I have one that came out of a 1980 Suburban but it is pretty rough. Where did you get yours and where did you get the sheet of labels???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 03-31-2012, 01:55 PM   #34
ls1nova71
ls1nova71's Avatar
I don't know about LMC, I'll have to check my catalog when I get home. I think they are usually found in '81-82 trucks, but they're usually only a 3 wire switch so you have to change the switch inside of if with a 4 wire. Although I have seen a couple of them with the 4 wire switch already in them.
I had the labels made, if you want one, id sell you one for. $7 shipped.
Old 04-01-2012, 03:16 AM   #35
Critter
Future TOTM Winner
Critter's Avatar
I will probably take you up on that, let me dig up my old lever and see how many wires it has and if it is usable. Thanks!
Old 04-01-2012, 04:07 AM   #36
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed!
y5mgisi is offline   Reply With Quote
Old 04-01-2012, 10:16 PM   #37
chebyshortbox65
chebyshortbox65's Avatar
so in order to run cruise with an on off toggle and a momentary switch i need to run a jumper wire with 12v from the on off switch when its on to the middle of the momentary switch ?
chebyshortbox65 is offline   Reply With Quote
Old 04-02-2012, 03:18 AM   #38
code4
I have a toggle switch that provides 12+ to terminal A to turn the unit on/off.
I have a momentary push button that provides 12+ to terminal B when pushed to set cruise. If i hold the button in it will coast until i release the button. Terminal C i remove, everything else is the same as posted.
code4 is offline   Reply With Quote
Old 04-03-2012, 10:21 AM   #39
mcmlxix
mcmlxix's Avatar
I will probably end up with a Summit Racing aftermarket column.... for now I have the factory NON-tilt auto column shift.... So I need the one with the hole for the screw....
What did these come out of again.... 3 or 4 wire doesn't matter...
Rich
Old 04-03-2012, 04:22 PM   #40
Critter
Future TOTM Winner
Critter's Avatar
I found my lever and it is a 3 wire not to mention its in pretty bad shape. I'm going to hold off on getting a sticker from you until I can find a 4 wire setup or at least a nicer 3 wire to convert. I might even get a new one, who know.
Old 04-03-2012, 05:42 PM   #41
ls1nova71
ls1nova71's Avatar
They are usually found in "81 vans and '81-82 trucks.
How bad is it? I might be able to fix it, I've fixed some pretty nasty looking ones. Or if you get a new one and the old one isn't all that bad, I might be interested in it.
Old 04-08-2012, 05:36 PM   #42
Gunny Davis
Hey guys my cruise lever has 4 wires at the connecter Red, Brown, Green, Yelow. Pretty sure it is from Van tilt column.
I need help making the conections to my '99 Silverado cruise module.
I have transplanted the '99 5.3 / 4l60e, fuse block, and instrument cluster.
Appreciate your help
http://67-72chevytrucks.com/vboard/a...1&d=1333917353
Just need help with figuring out wich wires go were.
'99 Crusie Module Connecter:
A Gry 397 On switch Output
B DkBlu 84 Set/Coast switch signal
C Gry/Blk 87 Resume/Accel switch signal
D Brn/Wht 379 Clutch pedal switch output
E Blk/Wht 451 Engine control module ground
F Brn 41 Fused Ignition3 Output
G LtBlu 1320 Fused stop lamp feed
H Not used
(no "I" position)
J LtBlu/Blk 396 Signal engage
K DkGrn/Wht 817 VSS
My 72 Blazer Vortec Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=479956
Gunny Davis is offline   Reply With Quote
Old 04-08-2012, 06:18 PM   #43
ls1nova71
ls1nova71's Avatar
That's a switch from an aftermarket cruise control. They are usually normally closed switches and you will need to use relays to reverse them. Ackattack's thread that I have linked in my first post has instructions on how to do it. As for what wires to use for each function, you'll just have to test them to find out. You can do it with a DVM or a test light and a battery.
Old 05-10-2012, 01:54 PM   #44
farmtrucks
farmtrucks's Avatar
I got mine wired up _ but it is not working. Mine is DBW, does it need to see speedo input to work.
Old 05-10-2012, 03:21 PM   #45
ls1nova71
ls1nova71's Avatar
It has to have a VSS signal if that's what you're asking. You don't need an actual speedometer hooked up. Do you have both brake switch inputs hooked up? And do you have brake lights? It needs to see ground through them.
Old 05-14-2012, 01:42 PM   #46
ls1nova71
ls1nova71's Avatar
Pic for farmtrucks. This is a factory pigtail for the cruise switch. The gray wire is the on/off and goes to pin 14 on the TAC. Green is resume/accel and goes to pin 5. Blue is set/coast and goes to pin 4. Pink is the ignition power to the switch.
Old 05-14-2012, 09:50 PM   #47
TR65
TR65's Avatar
I have a 2005 LS2 with E40 computer DBW. Cruise does not work.
I think the problem is that the cruise is interlocked with the e-brake. The ECM has to see that the e-brake is off for the cruise to engage. (I know this is true on my 08 LS3). Problem is that the BCM reads the e-brake switch and puts the message on the low speed serial bus which the ECM reads.
(The same problem occurs for the case learn procedure. The TECH II has to see that the e-brake is on in this case for it to run the procedure.)
I am in the process of trying to get a BCM wired up with a toggle switch for the e-brake. No success yet.
Has anyone gotten cruise to work with DBW???
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-29-2012, 08:29 PM   #48
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Would 1 of these type cruise levers work with 01 6.0 DBW and cruise module? http://www.ebay.com/itm/1971-72-CADI...5e7c01&vxp=mtr
It only has 3 wires, black, blue, and brown.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-29-2012, 10:34 PM   #49
ls1nova71
ls1nova71's Avatar
It might, but you would only be able to set it, you wouldn't have an on/off or accel/resume.
If you want one of the ones I have pictured I have a few I would sell.
Old 05-29-2012, 10:54 PM   #50
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ok. Thanks. I would be happy just pushing the button and the cruise would be set. I don't need the fancy on/off or accel/resume.
