03-08-2012, 11:20 PM | #26 |
Re: Its spring time
Looks good, I like the 31's on that lift. I was going to do 31's with 2.5" front and 4" rear springs, but was wondering if it would turn out. Now seeing yours with 4" all around, I think it will look great may even do 4" front and rear. good job, keep it up.
03-08-2012, 11:24 PM | #27 |
Re: Its spring time
Like I said I think it will need a wider tire 10.5 little skinny But I like the space its gives me
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
03-08-2012, 11:35 PM | #28 |
Re: Its spring time
Yah, but I like the look of the skinny tires. On my truck I'm running 37x12.5's and looks fine, so I will go with 31x10.5 for the smaller tires. I think yours looks good how it's set up now.
03-09-2012, 04:08 PM | #29 |
Equal opportunity joke ofender
Re: Its spring time
Dave,
The shaft on the front of mine is 14.5" from weld to weld. I also measured the stock blue one and it it the`same. Who ever put the lift in the black one did not add to the shaft. Same goes for the rear. It is 26.5: weld to weld. Looks like the slip joint is not in the correct position anymore. Makes me want to drop it to 2wd 1st 2 pics are front shaft last 3 are the rear. The front shaft has a lot of play at the slip joint. The back shaft is pretty tight, no slop Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
03-09-2012, 05:20 PM | #30 |
Re: Its spring time
looks like the rear shaft is fully extended there. Thanks for the pics
