Old 03-03-2012, 03:18 PM   #26
mud.man.rj
mud.man.rj's Avatar
Re: You're going to think I'm crazy!!!!
Front axle is usually the same axle on 1/2 and 3/4 ton except hub with 8 bolt, rear if full floater is better than a 12 bolt.
mud.man.rj is offline   Reply With Quote
Old 03-03-2012, 03:30 PM   #27
Dalaigh
Canadian Trucker
Dalaigh's Avatar
The axle internals at the diff are the same, but the 3/4ton has stronger shafts and hubs. That said, if I ever do upgrade (likely won't) I'd be looking for a dana 60 from a 1ton.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 03-03-2012, 03:48 PM   #28
mud.man.rj
mud.man.rj's Avatar
I would like a Dana 60 front and 14bolt full float rear for my 71 1/2 ton but will wait till something blows as always more other things to spend on first.
Old 03-03-2012, 08:45 PM   #29
snm95ls
Not crazy at all. Trucks are usually a LOT more useful when they are closer to stock form.
I totally understand where you are coming from as I am inheriting a pretty unwieldy rig, and plan to return it to a more stockish state.
In to follow the build.
snm95ls is offline   Reply With Quote
Old 03-04-2012, 10:23 AM   #30
weider1717
Originally Posted by Dalaigh View Post
It all depends on what you need. Personally I prefer 3/4tons they are just stronger and more capable then 1/2tons.
Do you need a truck or do you need a truck capable of towing heavier loads.
When I bought the K20 I needed something capable of towing, now I don't.
The benefit of the 73-87 1/2tons is that they are a set of axles and heavier springs away from being 3/4ton capable. So if they need ever arises again I can always upgrade. Or I can just buy a 1ton, if I have the room.
But, that said, this truck is not going to get a huge lift kit (if any) and larger tires. I'm thinking that it's going to get 265's or at most 285's and no lift.
I agree with that I guess. I just a short bed man and I don't think the k20s even came in a short bed right? I like the slighty lifted sporty look of a 1500 4x4.
my 96 z71 I had came stock with a 14 bolt and an extra leaf over most z71s it had a 3/4 lef pack and rear end and I loved that truck for that.
weider1717 is offline   Reply With Quote
Old 03-04-2012, 11:39 AM   #31
hitcher
hitcher's Avatar
i also like your new truck better . im in to the whole work truck thing more than a lifted/lowered . everyone thought i was mad when i got rid of the big tires i had on my truck when i bought it and swapped for stock ones . but it was harder to handle , rubbed when turning and just not practical for working . nice ride and good luck .
hitcher is offline   Reply With Quote
