03-18-2012, 10:47 PM | #26 |
Re: 1966 C10 Fleetside Project
Nice truck, you very seldom see one with the license plate bracket on rear. Mine is missing and I'm wondering does it bolt to bumper and strip below tailgate?
Friends don't let friends drive Fords |
03-19-2012, 02:55 PM | #27 |
It bolts directly to the bumper, but it is pretty rusty. I may have to fabricate a new one. There are two panels that bolt to the rear bumper frame that are rusted out pretty bad too. I guess they are filler panels. Should be real easy to make them, I bet they are not reproduced.
03-19-2012, 03:02 PM | #28 |
nice! wish ours woulda still had the side trim when we got it
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
03-19-2012, 04:39 PM | #29 | |
03-19-2012, 08:22 PM | #30 |
wow, you stole that - I wouldn't blink twice at $1K on that truck - GOOD deal. I like your plans. Since we all love to plan OTHER people's projects - here's my 2 cents:
1. I'd do everything you said you'd like to do to it!! Then.... 2. 5/7 drop (or leave it stock) 3. CLR the whole darn thing 4. Leave the interior just like it is, it looks sweet. 5. Fresh white on the roof and in the side trim 6. Call it a day. I love these old trucks that are heavily optioned and trimmed and are all original with relatively solid body panels. Sure you need some rockers maybe, but so what - that is one way cool truck. |
03-23-2012, 12:36 PM | #31 |
I got the motor, transmission and front front suspension removed. I have cleaned up the bellhousing and transmission and have it ready to paint. Can someone tell what color these were from the factory? I have a manual 3 speed and it looked like the original color on the bellhousing is a green and had the number 53 painted on it. The transmission had no paint at all.
03-24-2012, 09:30 PM | #32 |
I disassembled the 3 speed transmission and it looks pretty good. I need to know how to get the shaft out the holds in the cluster gear. If you have to press it out does it matter which direction to press it? I do not see any clips holding it in. I'm sure that it is not a Saginaw. I did not see very much information on the site about rebuilding these.
03-25-2012, 09:00 AM | #33 | |
03-25-2012, 09:23 AM | #34 |
Nice truck, hope you get it going quick
03-25-2012, 05:50 PM | #35 |
If you are looking for a early mustang tank to relocate, check this site out:
http://www.tanks-to-pans.com/site/823208/product/F-F28E |
03-29-2012, 01:41 PM | #36 |
Ok, my 3 speed transmission is totally apart, cleaned and ready to put back together. I need a diagram and a good supplier for a rebuild kit. What color should the bellhousing and transmission be painted or does it matter? Thanks for all the help. It is a gm 4 bolt.
03-29-2012, 02:26 PM | #37 |
At $30 a set, its cheaper to buy them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-16-2012, 12:15 PM | #38 |
Rebuilt the brake\clutch pedal assembly and painted the transmission. Installing the transmission rebuild kit now. Here are some pics.
05-03-2012, 09:39 AM | #39 |
I ordered and received the Yellow Assembly Manual and I am pretty disappointed with quality and information in it. Is there a better manual out there that is specifically for 1966 C10 that has a breakdown of all the parts?
05-03-2012, 10:19 AM | #40 |
First of all, welcome, and awesome find! Sweet looking 66, and great price too. I just picked my 66 up at the beginning of March this year. Paid a lot more than that, but I am road worthy. I would love to see that 6 cylinder restored under the hood with a 5 speed, that would be sweet! Love the original valve cover!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
05-03-2012, 10:20 AM | #41 |
I too ordered this manual, and am equally as disappointed with it.
05-03-2012, 10:39 AM | #42 |
My 61 fleetside parts truck has one, I have one on me stepside also. They had two different mounts. One mounted on the bumper, the other on the back of the fender or the panel under the tailgate.
05-03-2012, 10:44 AM | #43 |
Nice job on the transmission.
05-03-2012, 12:11 PM | #44 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=522765
07-11-2012, 07:50 AM | #45 |
It has been a while since I have posted but I have been doing a lot of work on the cab. Mostly replacing rusted out metal. It has been so hot that it makes it diffucult to work very long. Here are some pics.
07-13-2012, 10:42 AM | #46 |
Here some pics of the cowl area.
07-13-2012, 11:11 AM | #47 |
Way to dive in!!!! Nice!!
08-14-2012, 04:29 PM | #48 |
I need a little help from the 3 speed transmission experts out there. First - is there a manual out there for this Muncie 318? I found one diagram on line and it's so blurry when you enlarge it you can't see it anything. The other is this, when putting it back together I install the reverse idler shaft but it is lose in the housing. Is there a pin or something that is suppose to hold it from coming out of the housing. I had to drive it out and there was no pin. It looks like the housing holds it in place at both ends. Like I said, you can push the shaft with you hand and it will fall out of the front housing. I really want to get this thing buttoned back up so any help would be appreciated.
02-04-2013, 09:12 AM | #49 |
It's been a while but I am back to work on the project. I removed the 12 bolt rear end, tore it completely apart. Took the housing down to bare metal, welded in the axle tubes and grinded down all the imperfections when it was cast. I have one issue and that is removing the pinion the gear shaft out of the housing. I removed the nut and used a puller to get the yoke off. The pinion gear shaft will not drop out of the housing. I put the nut back on it and put a 2x4 on top and smacked it several time with a hammer but it will not move. Any suggestion? I have some pics coming soon. I also sandblasted my trailing arms and then boxed them in. They turned out good. It took a lot of welding and grinding.
02-08-2013, 09:00 AM | #50 |
I still can't get the pinion shaft out of the housing. I'm going to take my die grinder and try to cut the bearing race next to the shaft. Here are some pices of my boxed trailing arms and I added exhaust cut outs in the middle crossmember. The frame is going this weekend to the sand blaster.
