Old 03-28-2012, 04:46 PM   #26
mineralgrey01gt
Re: bagged 84 c10 single cab swb
Originally Posted by made2drag View Post
ok, thanks again
You head down to scrapin the coast in June any? If so look me up ill have the truck out there and more than likely the only Kool Whip sticker on the coast
mineralgrey01gt is offline   Reply With Quote
Old 03-29-2012, 11:42 AM   #27
made2drag
made2drag's Avatar
yeah hopefully, i usually go every year with my best friend. i'll look for your truck and also justpball's body dropped suburban. he's been entering his there the last few years and he says he's going going to be there this year too. im sure there will be a ton of other members there too.
made2drag is offline   Reply With Quote
Old 03-29-2012, 11:47 AM   #28
made2drag
made2drag's Avatar
here's his burban: http://67-72chevytrucks.com/vboard/s...d.php?t=383055
Old 03-30-2012, 07:51 PM   #29
mineralgrey01gt
thats one sick burban! ill be looking forward to meeting some of yall there hopefully. i may have to drive mine the 150 miles from my house to there. Should be interesting lol.
Old 04-25-2012, 07:07 PM   #30
Ford Assassin
Ford Assassin's Avatar
Did you have to run any spacers on the front Boss 338's? Do you know if you have the 1.00" (light-duty) or 1.25" rotors?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 04-25-2012, 07:19 PM   #31
mineralgrey01gt
No spacers needed and yes I have the 1" light duty rotors. There is also no need to dent in the dust caps either as I have read some people do
bagged c10 a.k.a 1lo8fo
2006 gmc sierra crew cab
2007 ltr450 a.k.a hell on wheels
Old 04-25-2012, 07:28 PM   #32
Ford Assassin
Cool, thanks.
I have 20x10's for the rear, I hear I'll need an adapter/spacer for them, I guess we'll see. I am still collecting the pieces I want for my 2wd conversion.
Cable
Old 04-25-2012, 07:38 PM   #33
mineralgrey01gt
the 20x10's I believe will fit without them to be honest. It also depends on what your doing with it, my bed and such is cut and set up to where they can fit. Good luck with it and post some pics of it!
Old 04-25-2012, 08:12 PM   #34
Ford Assassin
I plan on doing a 4/6 drop, 3" drop spindles up front with cut stock springs, the rear I'll be changing to the 2wd rear spring hangers, reusing my 4x4 springs (might remove a few leafs), 3" in frame C-notch, 6" axle flip kit, and maybe lowering shackles (if needed). I am still going to use the K5 for towing my camping trailer, etc, so I can't get too crazy. Worse case I'll bag the whole truck.
Cable
Old 04-25-2012, 10:38 PM   #35
maxxxy
maxxxy's Avatar
Very cool build. The back of the truck is very smooth. I can dig it. Keep it up!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-25-2012, 11:12 PM   #36
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
cool build!!!! I dig it
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 04-26-2012, 11:08 AM   #37
made2drag
made2drag's Avatar
if you have the 338's with the push in centercap with the o-ring....those are the redesigned ones that should fit with 1 inch or 1 1/4 inch rotors. so when you order your stuff like spindles and things either should work. i have the o-ring center cap 20x8.5 on mine with 1 inch rotors and i didnt have to dent my wheel bearing dust cap either. im on stock spindles but may go with drop spindles soon.
Old 04-26-2012, 12:02 PM   #38
Ford Assassin
I'll have to look at them. I bought them about a year ago and they have never left the boxes. I know they did a redesign at some point in the past, I bought them for my Roadmaster Wagon, but decided to keep the wagon on Rallyes and put the 338's on my K5 after converting to 2wd. I plan on buying 3" drop spindles and new slotted/crossdrilled rotors anyway, I might as well buy the 1.00" rotor version just to make sure I won't have any issues.
Cable
Old 04-27-2012, 05:18 PM   #39
made2drag
made2drag's Avatar
another idea is to bring one of your wheels in to like autozone or whatever and see if they can take a 1 1/4 rotor out of the box and you can see if it fits before you bought it. of course, my light duty 1 inch rotors have plenty of stopping power so it would be just personal preference at that point. just make sure you can get 3 inch drop spindles for the 1 inch rotor. i know they make 3 inch spindles for 1 1/4 rotors.....i have that combo on my 67 c10
Old 04-29-2012, 08:58 PM   #40
Ford Assassin
I have the 1.25" rotors and I checked the wheels and its a no go. The lip in the rotor hub will not allow the rim to sit flush. I am checking on having a machine shop removing the lip.
Cable
Old 05-10-2012, 10:58 AM   #41
melks
melks's Avatar
trucks lookin sweet man, keep us posted!
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 05-10-2012, 11:03 AM   #42
mineralgrey01gt
Actually the truck is about to go up for sale. I never use it and it needs to be used. I just brought a Saleen mustang so it's getting all the attention now
