03-16-2012, 11:00 AM | #26 |
Re: 1966 C20 8 lug disc swap
Posted via Mobile Device |
03-16-2012, 11:02 AM | #27 |
The picture before was of the riviera mirror I found at a swap meet
These are almost in. Just a few more welds and holes to drill Posted via Mobile Device |
03-16-2012, 11:04 AM | #28 |
There is a chrome bumper I scrounge CL for on it's way. Posted via Mobile Device |
03-16-2012, 11:11 AM | #29 |
The 78 350 chevy. I have under $1500 in the whole truck. Posted via Mobile Device |
03-16-2012, 11:12 AM | #30 |
I also found a guy putting a late taurus electric fan in his C20 so I may be trying that just because I can't find a shroud anywhere.
03-18-2012, 11:17 AM | #31 |
So I found a place that was in Sacramento that dismantles the 67-87 trucks, and bought the whole K member and suspension from an 3/4 ton 73 pickup all for 100 bucks.
It's pretty light weight for what I expected. I'm starting to wonder how big of a sway bar I could find and rig up to work now. What did the big C50 pickups or whatever come with in terms of a sway bar? I'm not interested in buying any kit or new sway bar, anything I can rig up from the junkyard will work. Posted via Mobile Device |
03-18-2012, 11:44 AM | #32 |
Turning Wrenches Daily
Hey Cutty,
I am working on a rear 8 lug disc conversion myself using newer truck parts here is the thread still working on brake lines and such for it right now. http://67-72chevytrucks.com/vboard/s...ion&folderid=6 this one is using 2008 parts for the rear. do you have the eaton axle or the dana? Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 |
03-18-2012, 12:16 PM | #33 |
I have the eaton out back.
I found a place that sells the mounting brackets for 70 a pair, I think I'm going to use those because it can use front calipers off an 3/4 front or 76-78 eldorado rears with the mechanical parking brake which sounds very slick. http://diy4x.com/cart/index.php?rout...&product_id=35 I'll check out that link. Posted via Mobile Device |
03-18-2012, 12:26 PM | #34 |
The link you had posted didn't work for some reason.
03-18-2012, 12:50 PM | #35 | |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-18-2012, 01:05 PM | #36 |
So the later frames aren't wider correct?
I remember trying to use the later style motor mounts to install the motor but they made it sit up really high and clearance in the trans tunnel became an issue. So needless to say I went with factory mounts for that year but It makes me wonder what the difference was. Posted via Mobile Device |
03-19-2012, 01:09 AM | #37 | |
60-66 Nut
Yes the frames are the same width. The difference is in the height. That is whay you had issues with the '73-'87 motor mount brackets. Whay you need is the brackets from a '73-'87 C20. The frames on the '73-'87 C20 are shorter, closer in height to the '63-'66 truck frames. The frames on the '73-'87 C10's are taller. That is why the motor mount brackets from those are too tall and require a spacer on top of the frame. However, member protrash64 sucessfully used the C10 brackets on his big block install in his Burb.
For a sway bar, the C20 Camper Specials and the C30's used a 1.250" sway bar. That's the largest diameter bar that will bolt up to a pickup front suspension without modifications. Most of the C40 and bigger trucks have a straight axle with leaf springs. Quote:
03-19-2012, 01:34 AM | #38 |
Well the interesting part was that the truck I got the motor mounts from initially were from a 78 454 powered C20.
Oh okay, I kinda figured the C40's had a different front suspension. I'll go looking for one of those. Thank you for the input. Posted via Mobile Device |
03-19-2012, 01:40 AM | #39 | |
60-66 Nut
Hmmmm, those should have fit fairly well. All the C20 brackets I have had in hand fit the '63-'66 frames nicely.
03-19-2012, 01:46 AM | #40 |
They fit, but they moved the motor upward in the front substantially, enough that it hit the trans tunnel.
Who knows, I got the right mounts now from a 66 truck so it's not an issue. That makes me feel better about the frame width, now all I need is the right master cylinder and I'm set. Know of any that bolt up? Posted via Mobile Device |
03-19-2012, 01:56 AM | #41 |
60-66 Nut
Are you going with manual brakes or power? If manual, a '71-'77 or so pickup manual master will bolt to the firewall. But you may need to lengthen the pushrod. If you are wanting power brakes, there are not any factory or aftermarket boosters that will just bolt up without an adapter bracket
03-19-2012, 02:23 AM | #42 |
Ah sweet, I didnt want to modify the firewall so that makes me happy.
I'll probably buy one from an auto parts store just because that part is very important in the system Posted via Mobile Device |
03-19-2012, 02:24 AM | #43 |
Oh and I'll be keeping it with manual brakes.
Simpler, less cluttered in the engine compartment. Posted via Mobile Device |
03-24-2012, 01:21 AM | #44 |
Anyone know if the guy with a 50 something chevy pickup is on here?
He has a twin turbo 455 olds tucked in the bed of it. I had talked to him on real olds power. Also anyone tried to take a big truck eaton drop out and stick it in the 3/4 or 1 ton housing? Posted via Mobile Device
1971 Cutlass 1975 Trans Am 1992 Celica GT 1966 C20 long bed fleetside 1967 Chevelle |
