Old 03-23-2012, 06:13 PM   #26
lwb66step
lwb66step's Avatar
Re: rear end stuck in the air
What shocks? I want em now not next week so that limits me to stock on hand at advance or oriellys
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline   Reply With Quote
Old 03-24-2012, 12:34 AM   #27
rustyrodknocker
I cut the shock mount off and relocated it to the top of the frame. then I cut the bump stops off. 6 years on the road every day. rides nice. the issue I had was shocks that would be short enough. the ones that were on it only had 1/2" of travel left. then at an inch the bump stop would limit travel.
rustyrodknocker is offline   Reply With Quote
Old 03-24-2012, 04:26 PM   #28
bama63
bama63's Avatar
got this from a previous post hope this helps. this is a 3" drop front and 5" drop rear
You can go the Monroe Monro-Matic Plus route:
Fronts: 33033 or 1"shorter#37187
[67-86 C15/C1500 Pickup;;66-86 C25/C2500 Pickup;;67-86 C35/C3500 Pickup;;87 R1500 Pickup;;87-89 R2500 Pickup;;87-91 R3500 Pickup] Monro-Matic Plus Shock Absorber;;Economical Price;;Ideal Balance Of Comfort And Control
Front- Monroe 33033
Rear- Monroe 32301
Monro-Matics have a great deal of travel over other shocks 10.0 inches collapsed
The KYB's 6" rear drop are part # 344067
you dont need drop shocks with just a 2" coildrop in the front, most front shocks will fit rear up to 5"drop
Front stock=Extended Length: 15.00 in.
Collapsed Length: 9.95 in.
Stroke: 5.03 in (mount @ 12.5")
Rear stock length=Extended Length: 20.48 in.
Collapsed Length: 12.62 in.
Stroke: 7.86 in ( mount @ 16.5")
Rears: 31000
87 Toyota Pickup Series Rear Monroe Monro-Matic Plus Shock Absorber-31000
around $20-$30, depending on where you find them...or, an economical cross reference.
Rear: I have 5” CPP lowering springs on the rear. All shock dim’s are from eye to eye:
Rear Axle Hanging Free, Tires off the ground: Shock Length = 17-1/2”
Ride Height, Shock Length = 15-1/2”
Rear axle Bottomed Out on Custom Snubber: Shock Length = 12”
Rear axle Tube Bottomed Out against Frame: Shock Length = 11-1/4”
3” Suspension Travel Before Contacting Custom Snubber
3-3/4” Suspension Travel Before Axle Tube Contacts Frame (No Snubber)
Front: Previous Owner heated the stock coil springs. All dim’s are from eye to eye:
Front Suspension Hanging Free, Tires off the ground: Shock Length = 14”
Ride Height, Shock Length = 11-1/4”
Lower Control Arm Bottomed Out on Custom Snubber: Shock Length = 9”
Lower Control Arm Bottomed Out, No Snubber = 7”
2” Suspension Travel Before Contacting Snubber
4” Suspension Travel with no Snubber
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 03-24-2012, 05:18 PM   #29
lwb66step
lwb66step's Avatar
Thank you! ^^^^
I hate all fords.
Old 03-24-2012, 05:25 PM   #30
lwb66step
lwb66step's Avatar
Aight. I fiddna take this rear apart and install jeep springs will post pics
I hate all fords.
Old 03-26-2012, 02:52 PM   #31
lwb66step
lwb66step's Avatar
Sooo fo shocks, are you saying use front shocks in the rear of my lowered truck?
I hate all fords.
