Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-12-2012, 01:11 PM   #26
Rannos
Rannos's Avatar
Re: help with ideas mod
Pro Topline heads are great heads and the XE274H cam is a decent little stick. Your valve size should be 2.02 and 1.60. You will need a new set of rockers as the slot in your stock rockers isnt long enough for the lift of the cam. I would suggest doing a 1.6 full roller rocker but 1.5 roller rockers are good to.
Rannos is offline   Reply With Quote
Old 04-12-2012, 05:45 PM   #27
felon c10
Originally Posted by INSIDIOUS '86 View Post
Ok well you guys can cover the engine stuff.
If you want to go faster you also need better gearing. This alone will make the biggest difference. If your truck is all stock it prob has 2:73 gears or 3:08s with that kind of gearing even if you have a strong engine grandmas Camry is still going to be tough to beat at the stoplight. Next you need a higher stall converter. And the shift kit. If your truck is a 700r4 also pair that with a corvette servo as well
And I agree but I have to first get the engine going so I can find out what kind of stall to get.same thing with the trans kit because then I can adjust the trans to the tire and power am making.But your right after am done with engine ill be asking you guys for gearing advise
felon c10 is offline   Reply With Quote
Old 04-12-2012, 05:50 PM   #28
felon c10
Thanks buddy 1.6 it is
Old 04-13-2012, 01:38 AM   #29
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can't adjust the transmission like that. Only build it to handle more power. And only one way of finding out when it's not good enough. But yes once the engine is built then decide on the stall. But 3:55 and 3:73 gears with a posi are what you will be looking at
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-07-2012, 12:20 PM   #30
felon c10
on a 87 chevy c10 what is the number of teeth on flexplate? it has a 350
