Old 03-01-2013, 02:38 AM   #26
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Speedo cable leaking?
And I thank you soo much for doing that. Just remember whenever ya need good deals on New parts I'm down the street, oh and the Speedo is more like 15 to 20 miles off, gotta find some time to get that bullet out and take it to the tranny shop. Hopefully I can start on it in the afternoon
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 03-01-2013, 10:56 AM   #27
68gmsee
Active Member
68gmsee's Avatar
Re: Re : Speedo Gears & Ratios ?
Originally Posted by VWNate1 View Post
Who's got a link to that chart ? .
My TH350 is reading almost *exactly* 10 MPH too fast.......
I just need a link but any other comments or helps would be great too .
TIA ,
My 68 with a 3 speed saginaw was showing somewhere around 53-55 at 60 mph. With a little luck and doing some reading I got mine right on the money without having to change the drive gear inside the transmission. I just counted the teeth on the driven gear and tried one with the next fewer teeth.
Example; The speedometer reads 66 MPH at an actual 60 MPH. 66 divided by 60 is 110% or 1.1. That means the driven year is rotating 1.1 times too fast. To slow it down, we must increase the number of teeth on it by 1.1. If it is a 40 tooth gear initially, a 44 tooth gear will be correct.
Conversely, if the speedometer is reading too slow, the driven gear speed must be increased, and less teeth on the gear would be required. In John's case, the speedometer was accurate before the gear change and the error caused by the gear change is known. 3.42 divided by 3.08 = 1.11. John needs to increase the driven gear's teeth by 1.11. If he has a 40 tooth gear, 40 x 1.11 = 4.44. Therefore, he would need a 44 tooth gear. http://www.bafb.org/1968firebird.org...articles16.htm
More reading...
http://www.thegearbox.org/catalog/it...82/3697857.htm
http://www.transmissioncenter.net/sp...n_______va.htm
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-01-2013, 11:11 PM   #28
VWNate1
VWNate1's Avatar
Thumbs up Re: Speedo cable leaking?
Great info ! THANX ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 03-02-2013, 03:23 AM   #29
midniteblues
midniteblues's Avatar
thank you for the info
i'll havta take hs truck for a ride with a gps too get some real #'s an go from there
that is after he fixes the window
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-23-2013, 11:14 PM   #30
JointTech
JointTech's Avatar
Is this something that should have been replaced in a rebuild? Im leaking at the speedo cable as well. TH400. I just had the tranny rebuilt. I noticed the cable was loose so I tightened it up, i must not have tightened when i reinstalled the tranny. but I noticed another drop and some fluid on the crossmember.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 08-24-2013, 09:18 AM   #31
midniteblues
Im only guessing here but if a trans is rebuilt then a rebuild kit was ordered for it.
an once again i'm only guessing that the bullet seals shoulda been in the kit.
i've never rebuilt a trans but it only seems logical to replace all the seals.
even if it was supposed to be replaced i would still go back too the rebuilder an ask for either the seals (2 of them) or a complete new bullet.
be sure too count the teeth on the speedo gear or better yet take it with you most times the leak comes from a ring worn on the gear shaft.
these parts are/should be fairly inexpensive.but if you dont have a trans shop nearby they could be a lil' difficult too locate locally new.
of course they are availible everywhere online.
Old 08-24-2013, 12:03 PM   #32
oldgoalie
T-400 only uses a aluminum speedo gear housing, about 1 1/2 in diameter. There are different ones depending on the # of teeth the speedo gear has. They take just a small rubber seal which does come in a o/h kit. The gear will get a groove in it where the seal rides and seep a little. You can double up the seal, which will help. Best is to find a new gear. New housings are getting a little harder to find, it has been about 25 years ago GM quit building the 400 and most parts aren't being produced any more such as speedo housings. It is NOS or used. That being said I am sure the trans shop would fix it for you.
oldgoalie is offline   Reply With Quote
Old 08-24-2013, 01:06 PM   #33
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
This is the seal that goes in a Th350 speedo bullet. Two bucks from Rockauto. The old and new seals on the box with part number. Made is USA seal too.
O ring for outside of the bullet. Tractor Supply in the hydraulic section. A baggie of them is under 2 bucks.
I press the seal in on my press to slip it in nice and straight without trauma to the seal. Bonus points for using an antique S-K Wayne socket as a press tool.
A dollop of grease on the gear.
Fresh o ring.
