05-29-2012, 08:23 PM | #26 |
Re: 68 camaro vs. 06 GTO hybrid
here is the donor car, and the new dash/ interior being retro fitted in.
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
05-29-2012, 08:27 PM | #27 |
first thing i did was to fit the center console in, since the shifter was in the spot i wanted in, once i had the console where it needed to be, i made a mounting plate for it... drilled and tap the plate for the console to mount to...
05-29-2012, 08:34 PM | #28 |
once i had the console mounted, this gave me the reffrence as to how much of the dash i was going to have to cut off, the GTO dashes were way longer then the camaros were...here are a few pics of how i trimmed the dash.... once i had it trimmed, i removed the dash cap, so i could work on making mounting points for the underlieing structure...
05-29-2012, 08:36 PM | #29 |
and the dash pad installed, you get the idea of what it is going to look like...
05-29-2012, 08:45 PM | #30 |
since this is going to be a cruiser, it has to have a/c and heat, so that massive heat/ a/c unit was removed from the donor car..... more brackets were made, and some trimming here and there, and i managed to get that beast installed (kinda see it hiding under the dash)....
05-29-2012, 10:20 PM | #31 |
Still Learning
Very cool idea Don. I love all the custom fab work.
06-23-2012, 11:35 AM | #32 |
once i had the dash bolted in, i turned to getting the steering column in, the brake pedal, and the gas pedal installed...i had to smooth the driver side of the firewall, to get that clean look we were after, and to delete all the unused holes.... here are a few of the process pics
06-23-2012, 10:18 PM | #33 |
I dun gradjiated collij!!!
WOW!... I'll be watching this one closely...
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
07-08-2012, 08:38 PM | #34 |
Cool build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-12-2012, 09:14 PM | #35 |
once i got the pedals figured out, i started in on the seats....the back seats the loop that went across the head rest had to come off, cause it interfered with the convertable top going up and down....the seat frame was narrowed and modified to sit/attach to stock mounting points of the camaro... here are some pics of this
12-18-2012, 07:58 AM | #36 |
Cool build.... I have a 2005 GTO so this is very interesting
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
12-20-2012, 10:12 PM | #37 |
here are a few updates pics of some things ive done to the camaro...i moddified the front seat brackets and frames to mount them in the car, while keeping them powered... i also moddified the stock 68 camaro trunk latch to make it powered poped, like the GTOs.. also to slide the radio in, it interferred with the a/c assy. so i had to cut a piece out, fab a metal filler, and bond it all together... here are a few pics
12-20-2012, 10:14 PM | #38 |
12-20-2012, 10:15 PM | #39 |
looks like pooo there, but i sanded it down and painted it flat black..
12-20-2012, 10:18 PM | #40 |
started laying out the GTO body harness in the camaro
12-21-2012, 09:23 AM | #41 |
Still Learning
Very nice work as always Don! looking forward to updates.
12-24-2012, 03:27 PM | #42 |
thanks, mcbassin..
here is a little more of a update... moddified the stock GTO master/booster assy., cut the mounting brackets off the stock camaro booster, redrilled a couple of holes, clearanced a little bit, and was able to make it a bolt on deal...then i put a adjustible wilwood proportating valve in there, rean some hardlines, and bled the system....
12-24-2012, 03:30 PM | #43 |
also installed some wilwood disc brakes in the rear with e-brake
12-24-2012, 03:35 PM | #44 |
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 Last edited by 68 short step; 12-24-2012 at 04:08 PM. |
12-24-2012, 03:49 PM | #45 |
installed a rock valley stainless fuel tank with a walbro 255 pump, we went with the proper sending unit for the GTO...we ran -6 AN line, and used a corvette fuel pressure regulator near the tank...finally got to use my GM fuel connect flare tool too..
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 Last edited by 68 short step; 12-24-2012 at 04:19 PM. |
12-24-2012, 03:50 PM | #46 |
also did the steering, i had to do a intermediate u-joint, to get clearance around the header, but it turned out nice... once i had everything welded on, i painted the ujoints black, and kept the nice nickle finish on the steering shaft.i made a bolt on carrier bearing for the shaft to go through...
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 Last edited by 68 short step; 12-24-2012 at 04:31 PM. |
12-24-2012, 03:50 PM | #47 |
made some radiator supports so i could use the GTO radiator, a/c condensor, and electric fans...
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 Last edited by 68 short step; 12-24-2012 at 04:42 PM. |
12-24-2012, 07:27 PM | #48 |
Can you post up more details on the flare tool you're using for the fuel connects and the hard line you're using? I'm almost to that point on my build.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
12-24-2012, 09:30 PM | #49 |
6>8 Plugless........
68 short step, awesome build you have going on here!
Bluejeep, I have a similar hydraulic flaring tool and I love it. Mine is from Matco tools. http://www.matcotools.com/catalog/pr...RING-TOOL-KIT/
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-12-2013, 09:50 AM | #50 |
Hey Don, how's this build coming? Make any new progress on it?
81 GMC C15 RC SWB 5.3L 4L80E project |
