05-20-2012, 11:24 AM | #26 | |
Newbee
Re: Shocks+Shock Boots= Premature failure???
Having the shaft's sandblasted is way more damaging than a little mud. I have always had great luck with Rancho 5000 series shocks. Been using them since the 80's, and never had an issue ( other than self inflicted). Anything more hard core than a trail truck, gets Fox shocks though. |
05-20-2012, 11:13 PM | #27 | |
05-30-2012, 08:47 PM | #28 |
Resident of Here
I dont use boots because of exactly what the salesman said. I came up with the conclusion myself though. Because I've seen pitting on shocks and I didn't want it on mine.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
06-04-2012, 09:09 AM | #29 |
No boots on mine either, i think boots are just for show anyways. Take a look at the big construction equipment that get in the mud on a regular basis, i don't see any boots covering the hydraulics on them. Anything that keeps them from drying in my mind would be a bad thing. And a grease filled CV joint boot is a lot different than a shock boot, and those boots are sealed up a whole heck of a lot tighter than a boot for a shock.
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 "The price of Freedom is Eternal Vigilance" |
06-04-2012, 11:01 PM | #30 | |
Resident of Here
06-06-2012, 08:56 AM | #31 |
I really don't think it matters either way. And,I base that on over 35 years of experience with 4wds. I have never had a problem with corroded shock shafts from boots. I've run them both ways. I removed shocks with 200,000 miles on them that had no dampening left in them at all,but there was no rust on the shafts from the boots. I have had shafts rust with no boot due to the vehicle sitting for a few years,which isn't good for anything. I believe the theory for boots was to keep abrasive materials away from the seals. They ran boots on Baja 500 race vehicles that certainly cycle their shocks constantly all day long (and built up heat). Eventually they came up with remote reservoir shocks...many years later. Once the showy guys started into 4wds,then the boot colors came about and that's when they became about looks. Many things are learned over the years and the common goal of the 4- wheeling public shifts. The magazines fool this and depending on where you hopped on,they views are different. I like the more serious nature of 4 wheeling the magazines finally came around to. But,much of it is hype and in most of our real worlds what may be said to be not good enough or "you need this" really doesn't apply. You have to weed through it and find what works best for your needs. This coming from a guy who's school of thought has always been "over-build and you can't go wrong".
09-04-2014, 08:29 PM | #32 |
I know this is an old thread but I thought I might add my 2 cents. I ride dirt bikes so we know a thing or two about mud and dirt.. The rear shock does not use a boot cover over the piston and they hold up fine, so I imagine you'll be better off without them.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
09-07-2014, 02:11 PM | #33 |
One of the First
I've always ran boots on my shocks and steering dampner, DD and medium off roading. Never had top seal blow or shaft rust out. I ride 'em until they feel spongy, relpace with the same or try something different. Now, if your running a mud truck or extreme off road and have to wash your rig down when you return from the woods, swamp or mountain, then yeah - no boots.
The only issue I have with shocks is the cheap paint they spray them with. Down here, within a few months the start picking up rust spots, so when new, I will scuff, epoxy prime and paint with white poly paint. No rusty spots.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
09-13-2014, 10:15 AM | #34 |
I will add to this as well, even though its really old.
Ryan. dont run shock boots. EVER. we can't be friends if you do... hahaha. the claims are true. i have witnessed it firsthand and have heard from many an offroader/4x4 owner the same. so since it is always a point of contention, the fact that it may happen is good enough reason to me. worrying about dinging the shaft is a moot point. shock shafts are very hard on the surface. they are high grade steel anyhow and then have hard/smooth plating process after that. a little rock or sand will not do much to it by being flung by the tires. the shaft seals are meant to be wipers so they will clean the shaft before it gets to the pressure seal. if you leave a boot on there that can collect enough dirt, it will leave the stuff piled up on the shaft and slowly start wearing grooves in the shaft. if the moisture collects in the boot then we get rust. usually that is less of a problem in the normal wear zone as the wiper seals keep it clean, but if you dont use all of the shock travel much, rust can start to eat at the shaft and when you bounce it hard or force the shaft past the regular down the road wear zone it will eat the seals. shocks do get hot from regular use. that is why external res shocks are better at long term heavy use racing. just driving down the road can get them plenty warm to cause condensation. especially if you live somewhere with crappy roads. and lastly, they are ugly. that one is opinion but i think its a good one! funny this topic came back to the top. i have a tab open to the bilstien site right now looking for shocks. |
09-13-2014, 11:28 AM | #35 |
Bilstein 5100 series with the F-250 shock tower up front is what I am using. (ORD) Educating myself on the geometry right now. Interesting about the boots and heat. Did you check out the Bilstein 5100 series video? They have the boots on the bottom.
72 K10 |
09-16-2014, 03:30 PM | #36 |
I did a lot of wheel'n when I had my 84 chevy. I had issue with the rubber boots with a set of Ranco RS5000 the mud got hung up in the boots and rusted out the shafts and thus the shocks failed to do the job. The 2nd set I installed RS9000 and left the boots off and lasted a long time.
09-28-2014, 11:57 AM | #37 |
I've run Bilsteins for many years on all types of trucks and vans , expensive ? Yes, worth it ? In my opinion yes.
