06-14-2012, 01:40 AM | #26 |
Re: 65 LB Full Poterbuilt
Is the frame done yet? If its in Delmos hands it should be!
Can't wait to see more! Tony from Norcal Posted via Mobile Device |
06-14-2012, 07:31 AM | #27 |
Funny you asked I was just up there yesterday dropping off the motor and trans. Delmo has it all fitted except the trans, just needs to finish welding it all up. I forgot to snap a pic. He says it will be at powder coat in a week. I'll get some pics posted next time I'm up there.
07-24-2012, 08:56 PM | #28 |
Here some updates get some better pics later
07-24-2012, 09:20 PM | #29 |
chevy only
very nice! del was telling me about this frame dig it with the shiny black & blue suspension
CHEVY ONLY... Nothin Else ! |
07-24-2012, 09:36 PM | #30 |
Thanks Master!!! LOL
07-31-2012, 11:07 PM | #31 |
C10 CLUB Y QUE!
another longbed YES!!!!!
i dig it.... keep us posted.. oh and SUBCRIBED! |
08-01-2012, 12:20 PM | #32 |
Lookin good!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-01-2012, 02:12 PM | #33 |
Long beds rock... check out " NO PAINT" also a full Porterbuilt set up and Delmo Smoothies....
edited by staff Last edited by kart34; 11-11-2012 at 08:13 PM. |
08-01-2012, 02:21 PM | #34 |
This is the longbed delmo was telling me about cant wait to see how this one turns out
08-02-2012, 10:54 PM | #35 |
What gas tank is that?
08-02-2012, 10:57 PM | #36 |
Square
suspension looks sweet! frame looks killer! gonna be a bada$$ ride!
Squarebody Syndicate |
08-02-2012, 11:20 PM | #37 |
sweet color combo on the frame/suspension!!! gonna be a sick ride
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
08-05-2012, 03:08 AM | #38 |
Registered Loser
Indeed
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
08-24-2012, 01:47 PM | #39 |
Rob,
wheres the updates???? Drove right by Hank today, I could have gave him your high hump, Trucks lookin good bud. |
08-24-2012, 04:49 PM | #40 |
Lookin good, nice and shiny!
09-20-2012, 09:52 PM | #41 |
Wow , sorry guys I havent checked my post in awhile as I havent got **** done on this sled.
My welder got the big back widow kit in and started filling holes. Firewall, dash vents, High hump and Shaven and smoothin whatever we can. |
09-20-2012, 10:19 PM | #42 |
Very nice
09-20-2012, 11:54 PM | #43 |
Chevy Only Tx
Looking good!... Are u running long tube headers?
Chevy Only Tx......... |
09-22-2012, 08:47 AM | #44 |
No, I'm using the Hooker that Potorbuilt listed. Looks like I might struggle when it comes to install steering linkage.
Hooker Header part# 2466HKR for the painted steel Hooker Header part# 2466-1HKR for the ceramic coated __________________ |
09-22-2012, 09:08 AM | #45 |
With this power rack, what will you do for a pump? The Chevy pump's output pressure is too high for the Mustang rack, right? Just curious how people are matching them up these days.
09-22-2012, 01:20 PM | #46 |
I had the same issue with a rack I had in my camaro.ended up using a part from detroit speed. this thing goes right in line on the pressure side of pump.makes the steering alot less twitchy.
09-23-2012, 09:17 AM | #47 |
I didnt even know about this issue, Ill do some homework
09-24-2012, 08:32 PM | #48 |
Registered Loser
I didn't have any issues with the power steering pump pressure on mine. I'm using an 88 Mustang rack and used a hose set from Summit and the only issue I had was hooking the hoses up wrong...which was very interesting. If you do run into pressure problems I think Speedway sells a regulator for that.
09-25-2012, 08:30 AM | #49 |
I was not aware of the differential in pressures between the MII r&p and Chevy pump until the night I spun my '40 Ford on a wet road as I zigged to miss an opposing driver on a curve who was zagging on the center line of a narrow road. That is why I brought the subject up as I will be facing the issue again when I modify my '65 as you have done.
09-25-2012, 09:57 AM | #50 |
KRC power steering has a mulitude of valves avaiable to tweak the feel. From their website:
Flow Ratings 7.2cc Aluminum Pump Part No. Pump Flow KRC 25304000/25404000, ID:4 1.05 GPM KRC 25305000/25405000, ID:5 1.32 GPM KRC 25306000/25406000, ID:6 1.58 GPM KRC 25307000/25407000, ID:7 1.84 GPM KRC 25308000/25408000, ID:None 2.11 GPM KRC 25309000/25409000, ID:B 2.37 GPM KRC 25310000/25410000, ID:C 2.64 GPM KRC 25311000/25411000, ID 2.90 GPM KRC 25312000/25412000, ID:E 3.17 GPM 13.5cc Cast Iron Pump Part No. Pump Flow KRC 25304000/25404000, ID:4 1.5 GPM KRC 25305000/25405000, ID:5 1.75 GPM KRC 25306000/25406000, ID:6 2.00 GPM KRC 25307000/25407000, ID:7 2.25 GPM KRC 25308000/25408000, ID:None 2.50 GPM KRC 25309000/25409000, ID:B 2.80 GPM KRC 25310000/25410000, ID:C 3.10 GPM KRC 25311000/25411000, ID 3.45 GPM KRC 25312000/25412000, ID:E 3.70 GPM There are four valves that reduce assist and increase feel (KRC 25304000-25307000), and four valves that allow more assist, but lessen feel (KRC 25309000-25312000). KRC has two packages that include four flow valves, allowing you to have the appropriate valve to tailor your power steering system. KRC 25300407 is a less assist, more feel kit, while KRC 25300912 is a more assist, less feel kit.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
