#26 |
Re: I hate my Dana 60
Yes, if you hate Dana 60s get rid of that old truck now!
The new 2500hd will be so nice! Also sounds like the 60 is junk so how about 100 bucks for it. ![]() ![]() ![]() Cross over steering and NO lift block will fix it. Posted via Mobile Device Posted via Mobile Device |
#27 | |
Wow |
#28 |
The crossover and high steer according to the very credible interwebs says it puts more stress on the frame in certain areas.... nothing a little boxing or adding some metal can't fix but that just what a decent amount of people said not me as i don't run it because i currently run with the lift block on 38s and the death wobble lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#29 | |
I'm currently frustrated as well with what seems like a low speed, hit a bump in the road a certain way death wobble with my dana 60 front. I'm not sure what thread it was in, but someone posted pics of the tapered kingpin cones that weren't nylon, but machined from brass I believe. what's the story with those? |
#30 |
Has anybody tried adding a little more caster?
#31 |
Still investigating this, mostly because I keep seeing 37" Humvee takeoffs dirt cheap. havent found H1 wheels yet, but they should be available local cheap as well. Re: the above quote, according to the 14 Bolt Bible the difference if I were to change the hubs to SRW would be 2" on either side. So wouldn't I be better off simply putting 2" bolt on adaptors on? Is 2" enough with H1 wheels? That would be ideal, keeping my existing C&C 14 bolt, and if I ever want to go back to dually I can just change the wheels and remove the adaptors..It just doesn't seem like 2" would be enough because the H1 wheels have 2" negative offset and 7" backspace..
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
#32 |
I guess my question was already answered. So I should change to Srw hubs AND get the spacers. bummer, I was hoping to make it a quick change 4 to 6 wheeler
#33 |
See if I can remember everything. You say you have 6" front springs on your truck now? Well that is equivalent to 8 inches. The frames on 1 tons are 2" taller than 1/2 and 3/4 tons, both 2 and 4wd. So with 8" of lift, that is more than pushing it with regular push/pull style steering. You should go with crossover. It will steer better, and has no side affects handling wise.
As for the death wobble, it's a 60. Been there, done that. Bout the only thing that I can think of is pinion angle. Not sure if it's called caster or camber, seems I can never remember which is which. Anyways, I built a truck that had a GM 60 in it. Completely rebuilt everything other than the gears/bearings. All steering was rebuilt, as new TREs and DREs. I had 36" swampers on it, they weren't balanced, but never could tell they weren't, they rode pretty good. Then had 40" boggers, could tell pretty easy that they weren't balanced, but with a bogger you don't get a great ride anyways. But, every now and then I would get DW. Speed up or slow down, it would go away. This was with the GM 60. I then swapped to a HP60 from a 78/79 Ferd. ALL the steering stuff was the same. I swapped from the knuckles out between the two. I had 15" wheels, and can't run that size wheel on a Ford, wasn't about to spend more money when didn't need to. After I swapped, no more death wobble. Place I used to work had a set of railroad tracks that went across the road, they were on an angle, and every time I went across them with the GM60, it shook bad. After the swap, it never shook again. I would hit the tracks at different speed, couldn't get DW. I came to the conclusion that is the only thing it could have been is pinion angle. Everything else stayed the same. I also noticed with the crossover arm, on the Ford 60 is was pretty much level with the ground. When the GM60 was in, the same arm was pointed up, indicating pinion angle was pointed down. I would get some shims and try that. Also, replace the bolts on the pass side with studs. I got some all thread from the hardware store. Drove the truck for couple years and never came loose. I even had chrome lug nuts on the crossover cap, with a spacer and they never came loose. IIRC, 14ff rears are 67" wide, and C+C are 63". They are the same axle, but use different brakes, both drums and backing plate, and like said wheel hubs. I wish I had a truck, want something to play in the mud with and haul the 4 wheelers around....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#34 |
havent suffered from death wobble since I added a dual steering stabilizer using two extra-heavy duty stabilizers. Today I used it to haul a ton of pellets 2 miles from Lowes, when I turned onto my street I heard a loud snapping/clicking sound that seemed to be coming from the left front. No idea what it is, but I did notice the stupid steering block is loose again. I did actually bu ya dropped pitman arm, havent gotten around to installing it yet. But the noise seemed to be something coming from in the wheel or hub, it was with road speed, not engine speed. Brakes, calipers, wheel bearings all new. Axleshaft u-joint appears ok, I think maybe something let go in the auto locking hub, unless something simple like the inner brake pad...IDK. Raining and muddy snow and ice in the driveway, I'm not about to work on it right now. And I'm not driving it 6 miles like that to work with my kid with me, loaded, to use a lift at work.
If I have ONE more Dana 60 related problem, I swear this truck is going up for sale!
